Baton 3 Pro Max
![Baton 3 Pro Max Powerful EDC Flashlight With A New Experience](https://oweb.olicdn.com/image/1-pjy5qh.jpg@1920w_1080h_90q.webp)
![Bright EDC Flashlight Baton 3 Pro Max Outputs 2,500 Lumens](https://oweb.olicdn.com/image/jpy-pc-02-jrmtfp.jpg@1920w_1080h_90q.webp)
With a max.output of 2,500 lumens,Baton 3 Pro Max has the power
required for even the most demanding situations
![Baton 3 Pro Max Can Run For A Long Time, Up To 60 Days](https://oweb.olicdn.com/image/jpy-pc-03-an9mj2.jpg@1920w_1080h_90q.webp)
Long Runtime
Its included 21700 5000mAh battery provides a runtime of up to 60 days in Moonlight mode(1 lumen)
and more than 5 hours in High mode,
plenty for your longest workdays or backcountry adventures.
![Baton 3 Pro Max Uses An Upgraded Proximity Sensor](https://oweb.olicdn.com/image/jpy-pc-04-3mnfjo.gif)
The optical system has been optimized through tireless effort,
and the hidden proximity sensor helps
protect you without being oversensitive or affecting the light's beam pattern.
![Give Baton 3 Pro Max A Quick Shake To Activate Its Battery Indicator](https://oweb.olicdn.com/image/jpy-pc-05-5qvu6n.jpg@1920w_1080h_90q.webp)
Shake to Awake Battery Indicator
Give Baton 3 Pro Max a quick shake to activate its battery indicator.
There's no need to turn it on to check,
and it's even easier to find the side switch in the dark.
![Powerful EDC Flashlight Baton 3 Pro Max Has A More Friendly User Interface](https://oweb.olicdn.com/image/jpy-pc-06-40ub8d.jpg@1920w_1080h_90q.webp)
More User-Friendly Interface
The enlarged,recessed side switch is now even easier to operate,
and it simultaneously reduces the chance of accidental activation,
providing an improved user experience.
![](https://oweb.olicdn.com/image/jpy-pc-07-yy3kav.jpg@1920w_1080h_90q.webp)
Olight's First Magnesium Alloy Flashlight
Baton 3 Pro Max Magnesium Alloy Desert Tan is Olight's first Magnesium Alloy flashlight.
Magnesium alloy is a mixture of magnesium and other alloying metals,usually aluminum,
zinc,silicon,managanese,cooper,and zirconium.It has the reputation of being a green
and very 21st Century material,as magnesium is very abundant and can be obtained
from many ores as well as seawater.Magnesium alloy is currently used in the aerospace,
motorsports,and car manufacturing industries.
It also shows great promise a s a metal of choice for future industries as well.
![](https://oweb.olicdn.com/image/jpy-pc-08-2ctbyy.jpg@1920w_1080h_90q.webp)
Things You Should Know About Magnesium Alloy:
1.Magnesium alloy is about 1/4 the density of steel and 2/3 that of alumimum.
2.It is the lightest of all structural metals,and it is 33% lighter than alumimum.
3.Magnesium alloy has excellent impact resistance and heat dissipation properties.
4.It dissolves naturally and is recycalbe.
5.It is very eco-friendly and sustainable due to magnesium's widespread natural occurrence.
![Weight Contrast Between Three EDC Flashlight Models](https://oweb.olicdn.com/image/jpy-pc-09-y7rfwp.jpg@1920w_1080h_90q.webp)
Weight Contrast Between Three Flashlight Models
![The L-bracket Included With The Baton 3 Pro Max Is Made Of Magnetic Stainless Steel](https://oweb.olicdn.com/image/jpy-pc-10-9gm6ds.jpg@1920w_1080h_90q.webp)
Always Easy to Find
Made of Magnetic stainless steel and backed
with strong adhesive,the included L-stand
is very convenient for storing the Baton 3 Pro Max
so that it is always easy to find.
And the curved side,a humanization design,
protects you from injury
if knocking against it accidentally.
![Three Color Temperature Options For Baton 3 Pro Max](https://oweb.olicdn.com/image/jpy-pc-11-6lvwo9.jpg@1920w_1080h_90q.webp)
(For black model only)
![Bright EDC Flashlight Has A Stylish And Comfortable Grip And Is Easy To Carry](https://oweb.olicdn.com/image/jpy-pc-12-fsr0xa.jpg@1920w_1080h_90q.webp)
Stylish and
Comfortable Grip
The knurling pattern is both more non-slip
and comfortable to grip.
It gives a cool and stylish vibe to the light,
as well as providing
a unique and effective gripping surface.
Carry with Confidence
The two-way clip is more secure
on your pocket or backpack,
and it is made using thicker steel
for greater durability
and resistance to deformation.
![Baton 3 Pro Max is IPX8 Waterproof](https://oweb.olicdn.com/image/jpy-pc-13-87bpmh.jpg@1920w_1080h_90q.webp)
IPX8 Waterproof
Rated to withstand being submerged in up to
2 meters(6 ft 6 in) of water for 30 minutes,
the Baton 3 Pro Max is at home in even the
harshest environments.
Easy,One Step Charging
Rechargeable with Olight's signature USB
magnetic charging cable.
Just snap it on and start charging!
![](https://oweb.olicdn.com/image/12-6-8j6dm3.jpg@1280w_566h_80q.webp)
![Baton 3 Pro Max Powerful EDC Flashlight](https://oweb.olicdn.com/image/12-1-oeawoj.jpg@1280w_566h_80q.webp)
![](https://oweb.olicdn.com/image/12-2-cxnci0.jpg@1280w_566h_80q.webp)
![](https://oweb.olicdn.com/image/12-3-0k0g72.jpg@1280w_566h_80q.webp)
![](https://oweb.olicdn.com/image/12-4-t94l12.jpg@1280w_566h_80q.webp)
![](https://oweb.olicdn.com/image/12-5-tk1ayl.jpg@1280w_566h_80q.webp)
![](https://oweb.olicdn.com/image/baton-3-pro-maxgkzy-1920x671-1-go8v7k.jpg@1920w_1080h_90q.webp)
![](https://oweb.olicdn.com/image/baton-3-pro-maxcpcsdbt-1920x650-l45g9z.jpg@1920w_1080h_90q.webp)
![](https://oweb.olicdn.com/assets/images/olight-logo.png)
