Welcome to our in-depth review of the Olight Arkfeld Pro, the latest addition to Olight's impressive line of flashlights. Unlike traditional flashlights, this model boasts a white LED, a green laser, and a UV LED, making it a versatile tool for various scenarios. Olight's commitment to quality and attention to detail is evident in the design and construction of the Arkfeld Pro.
In this review, we'll delve into the Arkfeld Pro's design, features, and performance to give you a comprehensive understanding of this portable EDC light.
Packaging and Initial Impressions
The Arkfeld Pro comes in a well-designed package that strikes a balance between presentation and practicality. Upon unboxing, you'll find the flashlight, a magnetic charging cable, and a manual. The simplicity of the packaging aligns with Olight's commitment to delivering quality without unnecessary frills.
Design and Build Quality
The Arkfeld Pro continues the legacy of the Arkfeld series with its distinctive design. Resembling a compact remote control, the Pro model is flat, rounded at the edges for a comfortable grip, and features textured sides for better traction. The two-way clip enhances portability, making it an ideal everyday carry (EDC) flashlight.
While the Pro model shares similarities with its predecessors, it has undergone dimensional changes. It's larger in every direction, accommodating the addition of a white LED, green laser, and a UV LED. The switch, consisting of an outer ring and a center button, allows seamless transitions between the light sources. The build quality is top-notch, constructed primarily from AL6061-T6 aluminum with an anodized coating.
An impressive update to Olight's warranty policy(effective September 16th, 2023)makes the Arkfeld Pro even more appealing. With a lifetime warranty covering products purchased after January 1st, 2023, users can enjoy long-term peace of mind, especially considering the built-in battery that was previously a concern for some users.
User Interface and Modes
The Olight Arkfeld Pro boasts a user-friendly interface that seamlessly integrates the control of its white LED, green laser, and UV LED. The UI is designed to cater to both novice users and flashlight enthusiasts, offering versatility and ease of use.
The UI revolves around the selector ring and the central e-switch button. The outer ring, referred to as the "selector," allows users to switch between the white LED, green laser, and UV LED effortlessly. Three distinct positions on the ring correspond to each lighting option. Pointing the selector to the left activates the UV light, the middle position engages the green laser, and turning it to the right illuminates the white LED.
The central button, an e-switch, handles standard functions such as turning the flashlight on/off, mode changes, and lockout. Pressing and holding the button for one second while the light is off activates the moonlight mode, providing a low-level illumination ideal for preserving night vision or discreet use.
Available Modes:
✅Moon, Low, Med, High, Turbo: Adjust the brightness level based on your requirements.
✅Strobe: A triple click activates the strobe mode, providing a disorienting flashing light for emergency situations.
Mode Memory:
✅If you turn the light back on within 1 minute of turning it off in Turbo or High, it will return in High mode.
✅After 1 minute of being off, Turbo and High modes revert to Medium mode.
✅Moon and Low modes are completely memorized.
✅Strobe mode cannot be memorized.
Battery Status Indicate:
Four LED spots below the selector ring display the battery level.
✅4 green LEDs lit: >75%
✅3 green LEDs lit: 50-75%
✅2 green LEDs lit: 25-50%
✅1 green LED lit: 10-25%
✅1 red LED lit: <10%
LED and Light Sources
The Olight Arkfeld Pro is equipped with a combination of advanced LEDs, providing a versatile lighting solution for a range of scenarios.
White Light Led: OSRAM P9
The white light source for the Arkfeld Pro is the OSRAM P9 LED. While not particularly groundbreaking, the OSRAM P9 is known for its reliability and efficiency. The LED is capable of delivering a focused and powerful white light, contributing to the flashlight's 1300 lumens output in Turbo mode.
Olight's decision to offer both Cool White (5700-6700K) and Neutral White (4000K-5000K) options caters to users with different color temperature preferences. This flexibility enhances the overall user experience, allowing individuals to choose the lighting tone that suits their needs.
UV LED: Luminus SST-10-UV
The Arkfeld Pro features a UV LED, specifically the Luminus SST-10-UV. With a wavelength of 365nm, this UV LED is well-suited for various detection scenarios. The Arkfeld Pro's UV light is particularly useful for tasks such as currency validation, stain detection, and other applications where UV light can reveal hidden details.
Green Laser
Adding to the flashlight's versatility, the Arkfeld Pro incorporates a green laser module. The green laser serves multiple purposes, from presentations to feline playtime. The brightness of the laser, especially in the Class 3R variant, ensures visibility in various conditions.
Charging and Batteries
Equipped with a built-in battery, the Arkfeld Pro supports convenient recharging through Olight's magnetic charging cable. The 5.55 Wh battery boasts a capacity of 1500 mAh, and the 1-amp charge rate ensures a quick 2-hour recharge. The introduction of a magnetic charging system adds to the overall user-friendly design.
The Olight Arkfeld Pro stands as a testament to Olight's commitment to innovation and quality. With a unique combination of features, robust build, and an updated lifetime warranty policy, the Arkfeld Pro is a reliable and versatile EDC flashlight. Whether you need powerful illumination, UV detection, or a green laser for various applications, the Arkfeld Pro delivers with style and functionality.
