Before suggesting any actual small lights, I need to make sure you're aware that:
👀Smaller = less bright.
👀Smaller = shorter-lasting.
👀Higher max brightness = lower sustained brightness.
👀Higher max brightness = shorter-lasting.
the absolute best of all worlds in the Flashlight universe
There is no such thing.
Max output, sustained output, runtime, and size. You can only find your personal favorite balance point in between these factors.
My EDC flashlight preferred
One very popular and balanced choice is the Olight Baton 4 Premium Edition
Best Quality Small Flashlight❓
The best quality small flashlight in my opinion would be the Baton 4. It is a compact flashlight that uses a 16340 battery and features a two-way clip, TIR optics, and a side switch. The body of the flashlight is made of durable aluminum, ensuring its longevity.
One of the standout features of the Baton 4 is its durability. It can withstand being dropped from a height of 1.5 meters without any functional issues. This makes it a reliable choice for outdoor activities or situations where accidental drops may occur.
Furthermore, the Baton 4 has an IPX8 waterproof rating, which means it can be submerged in water without any damage. It can withstand prolonged submersion under normal use conditions. You can confidently use this flashlight in rain or water without worrying about it getting damaged.
If you still have questions about product quality, Olight offers a lifetime warranty! You can buy with confidence and rest assured of the quality
Brightest Flashlight❓
At 1,300 lumens, the Baton 4 is bright enough for many tasks, including most objects around the house, garage, yard, and more. Due to its small size, this is a perfect pants pocket flashlight. I usually carry a 1000-lumen flashlight and the Baton 4 is smaller but more powerful than most 1000-lumen flashlights.
Looking for a slim and dim flashlight?
It even has a 0.5-lumen moonlight mode, perfect for reading in low light without disturbing anyone.
Let’s take a look at Baton 4’s lumen-level settings:
Five modes:
· Moonlight, Low, Medium, High, Turbo
Available blinky modes:
· Strobe
From OFF:
· Press and Hold 1-2 sec: Moonlight
· Press and Hold >2 sec: Lockout
· Single click: Turn On
· Double click: Turbo
· 3 clicks: Strobe
From ON:
· Press and Hold: change modes (Low > Medium > High)
· 1 click: Turn Off
· Double Press and Hold: activate the timer
· 3 clicks: Strobe
Mode memory:
· If you turn the light back on within 1 minute of turning it off in Turbo or High, it will come back on in the High
· After 1 minute of being off, Turbo and High modes revert down to Medium mode
· Moonlight, Low, and Medium modes will be completely memorized
· Strobe mode cannot be memorized
Shortcuts:
· To Moonlight: press and hold 1 second from Off
· To Turbo: double click (from Off or On)
· To Strobe: triple-click (from Off or On)
Low voltage warning/protection:
· There are 3 indicator dots (LEDs under the laser micro perforations) that light up accordingly:
· All 3 LEDs: >= 60%
· Two dots: 10% – 60%
· One green dot: 5% – 10%
· One red dot: <5%
Strobe/blinkies
· There is a strobe mode that can be activated with a triple click from Off or On
Lock-out mode:
· Electronic lockout mode is enabled by holding the button down for 2+ seconds while the light is off
Additional/summary info on the UI:
· There is also a neat Timer mode, as seen on other Olight models.
· With the light on and in your desired mode, double-click + hold (press & release, press & hold) until you see a blink.
· One blink means that you activated a 3-minute timer.
· Two blinks mean that you activated a 9-minute timer.
· To switch between the 3-minute and 9-minute timers, after you’ve activated the timer, do another double click + hold.
· While the Baton 4 is docked in its charging case, the case’s display also serves as a button for controlling the flashlight. Some of the options available are:
· Single click the button: turn the flashlight on or off
· Press and hold 1-2 sec from Off: moonlight mode
· Press and hold from On: stepless dimming
· Close the lid: turns the flashlight off automatically
Small Flashlight❓
I think so, now let's look at the actual measurements:
Baton 4 Flashlight:
2.48 x 0.83 x 0.83 in (63 x 21 x 21 mm);
Baton 4 Premium Edition Charging Case:
2.56 x 1.26 x 3.46 in (65 x 32 x 88 mm)
Holding it in your hand, you can tell from the length that it is small enough. Even the premium version of the charging box is not that wide and can still be carried easily.
Next, let’s look at the weight:
Baton 4 Standard:
1.85 oz/52.5 g (including battery);
Baton 4 Premium:
6.84 oz/194 g (including charging case and battery)
The Baton 4 is made from high-quality aluminum, this aluminum flashlight weighs as much as a car key in your hand.
In addition, there is a magnet on the tail, so you can fix it on the hood of your car if you need to free your hands while working. If you're looking for something absolutely lightweight, the Baton is an obvious choice due to its balance of weight and size.
Long Lasting❓
Baton 4 runs at mid-range 60 lumens for 8 hours
Not satisfied with the run time?
Okay
For those looking for the absolute smallest everyday carry a flashlight with no compromises on brightness and battery life, Olight has you covered with the new Baton 4 Premium Edition.
Baton 4 premium version, which includes the Baton 4 flashlight and a charging box. The casing contains a 5000mAh 21700 lithium-ion battery, and charging takes approximately 2.5 hours. The charging box can charge Baton 4 up to five times. It's great to see that the case now supports two-way USB-C charging, which allows you to charge your devices as well. Its capacity and output are sufficient to fully charge the iPhone 15 Pro Max.
The charging case has also been updated with new features. There is now a button on the case that activates the flashlight when the lid is open, and numbers indicate the remaining battery power when charging and discharging. You can also click to see the current battery level. This is a very useful feature to see the precise battery level.
Choose a high-quality small flashlight that suits you
The Baton 4 from Olight is an exceptional flashlight that excels in its small size, lightweight design, and long-lasting performance. It is a reliable choice for everyday use and I highly recommend it.
The compact size of the Baton 4 makes it incredibly convenient to carry around. Whether you need a flashlight for camping trips, outdoor activities, or emergency situations, its small form factor ensures that it won't take up much space in your bag or pocket.
Despite its small size, the Baton 4 doesn't compromise on quality. Its high-quality construction guarantees durability, allowing it to withstand accidental drops without any functional issues. This makes it a dependable option for various situations where reliability is crucial.
One of the standout features of the Baton 4 is its long-lasting performance. The flashlight is designed to provide consistent brightness and illumination, ensuring that it serves you well in low-light conditions. You can rely on it to light up your surroundings effectively and efficiently.
In conclusion, the Baton 4 is a solid flashlight that offers excellent functionality, durability, and convenience. Its compact size, lightweight design, and long-lasting performance make it an outstanding choice for anyone in need of a reliable flashlight for everyday use.
