The existence of tactical lights is to enable some law enforcement officers or military and police personnel can be better identified in the dark environment and with a certain role in self-defense. The tactical flashlight, although its principle and structure and ordinary flashlights are not fundamentally different, tactical flashlights need to adapt to the requirements of use in a variety of harsh environments, its performance is much higher than the ordinary flashlight.
Nowadays, tactical lights are becoming more and more widely used, and even some tactical lights can be used as everyday flashlights, mounted on weapons for better lighting, clearer vision, and easier tracking of targets, so tactical lights are always evolving. Next, I will recommend 3 Olight tactical flashlights, they can definitely meet your needs.
Warrior X 3 Tactical Flashlight
The Warrior X 3 is an upgraded version of the Warrior X Pro tactical flashlight and is packed with great tactical features. Its max output is increased by 400 lumens to 2,500 lumens and its max beam distance reaches 560 meters. Like its predecessor, it has a dual-stage tactical tail switch to access high/low output either momentarily or constantly.
The tail switch accepts an optional lockable, dual-button magnetic remote switch and supports Olight’s signature magnetic charging. Powered by a customized 5000mAh 21700 Li-ion battery, it can be recharged via the MCC3 charging cable and the longest endurance time reaches 8 hours. The Warrior X 3 has been upgraded with 3 zirconium beads embedded in the strike bezel which helps break glass in an emergency. The included Warrior Ring and silicone tactical grip ring provide better control of the flashlight during stressful moments. When the power is low, the internal motor silently vibrates to remind you to charge the battery. Rugged aerospace-grade aluminum alloy body with Type Ill hard anodizing, stands up to tough conditions and features an IPX8 waterproof rating and 2-meter drop resistance. With all-around tactical features, the Warrior X 3 delivers expert-level tactical performance.
It is worth emphasizing that the warrior X 3 tactical flashlight can be used with our latest two-level remote switch sRod-7 and gun clip E-WM25, which can better meet your remote tactical operation needs. The new two-level remote switch can access high/low output momentarily or constantly, activate with a single press.
Packaging:
IN THE BOX | Warrior X 3 (Battery Included) x 1 Warrior Ring x 1 Silicone Tactical Grip Ring x 1 MCC3 USB Magnetic Charging Cable x 1 Holster x 1 User Manual x 1 |
Odin mini Tactical Flashlight
The Odin Mini tactical flashlight is a brand-new compact offering in our revolutionary Odin weapon-mounted light series. It features our innovative rotate-to-lock slide rail mount for maximum convenience and rigidity on your rail so that you could attach and detach the rail quickly(Compatible with Picatinny rails with the optional Pic Rail Adapter). Its innovative remote switch comes with a locking function to remain securely fastened. Just push the lock ring forward until you hear a click that signals a solid and tight fit. The Odin Mini tactical flashlight also includes some of our most popular features like the vibration battery indicator, silent stainless-steel tail switch, and magnetic charging. Powered by a single customized 2040mAh 18500 rechargeable lithium battery and equipped with an optical PMMA lens, the Odin Mini delivers a maximum output of 1,250 lumens and a 240-meter beam distance, the longest endurance can be up to 5 hours. With its compact size, incredible performance, and ultra-solid build, the Odin Mini is one of the most feature-packed weapon mounted light options on the market.
Odin also has a remote switch that goes with the Rod-7, so please don't choose the wrong accessory! It is different from our new remote switch. Of course, Odin has another accessory: the Finger Grip Ring, which gives you more maneuverability with your tactical light, even if you're using Odin mini from a small pocket, keeping the flashlight in the best position for quick draw and hold.
Packaging:
IN THE BOX |
Magnetic Remote Switch x 1
H3.0 Allen Wrench x 1 M-LOK Socket Screw x 2 User Manual x 1 Pressure Switch Mount x 1 Self-locking band x 2 MCC 3 magnetic charging cable x 1 |
Baldr mini Tactical Light
The Baldr mini is a Tactical Light with Green Laser Sight Combo, integrating the compatibility of the PL-Mini 2 and the accuracy of the BALDR Pro, it was our best-selling tactical light last year. Baldr mini has four features: Swift & Smooth Operation, Adjustable Rail, Bright white light & Green Laser and Rechargeable light.
Two types of rail adapters are provided to fit both Glock and Picatinny rails. Featuring an adjustable sliding rail(fits both GL and PIC rails), the light can be easily adjusted forward and backward into the position that suits you the best, you could install and remove it quickly. And The dual rear switches permit smooth momentary-on or constant-on activation by either hand with equal ease.
Though at a compact form factor, it delivers 600 lumens of bright white light and 130 meters beam distance of bright white light, along with a highly visible green laser for greater accuracy. You can select between white light, green beam, or green beam & white light combined. The Baldr mini is powered by a built-in lithium polymer battery, which can be charged through our signature magnetic charging port for extended runtime, and the low battery indicator(<10%) alerts you when it’s time to recharge. The quick attach and release mount and the slim switch make the Baldr mini extremely easy to manipulate for everyone.
Packaging:
IN THE BOX | Baldr Mini (Battery Built-in) x 1 Picatinny (MIL-STD-1913) Rail Mount Adapter x 1 HM2.5*4.5 Socket Cap Screw x 2 MCC (Magnetic Charging Cable) Special Edition x 1 H1.5 Allen Wrench x 1 Oval Point Set Screw x 1, Cone Point Set Screw x 1 User Manual x 1 |
These are the 3 main recommended tactical lights from Olight now, I believe they can meet your different needs and can play a powerful role in your different weapons. And Baldr mini tactical light has a sale activity recently, you also can enjoy a discount to buy a bundle of Baldr mini and i3T EDC flashlight, take action now! Learn more!
