Are you an avid outdoor enthusiast looking for the perfect headlamp to accompany you on your adventures? Look no further than the Olight Array 2 Pro rechargeable headlamp. This powerful and versatile lighting solution is a must-have for anyone who enjoys spending time outdoors, whether you're camping, hiking, fishing, or hunting. In this article, we'll explore the features and benefits of the Olight Array 2 Pro headlamp that make it such a great choice for outdoor enthusiasts.
Multiple Light Modes and Brightness
The Array 2 Pro headlamp features three kinds of light sources and multiple brightness levels to suit your lighting needs. It offers white LED floodlight, combination of floodlight and spotlight, red LED light mode, and SOS mode, achieving outstanding versatility.
The floodlight and spotlight combined setting delivers a maximum output of 1500 lumen to vividly light up your immediate vicinity even in total darkness. The combination of a floodlight and spotlight can provide wider and brighter illumination than a single beam. This can be especially useful in a variety of situations, from close-up tasks to illuminating distant objects.
The single flood light setting provides 800 lumen high light, 450 lumen medium light, and 50 lumen low light. The red light setting delivers 200 lumen high light, 100 lumen medium light, 45 lumen low light, and an SOS. The red light helps preserve night vision when navigating in the dark or when stargazing. It is also less likely to disturb wildlife or other people around you than a white light.
A headlamp with an SOS function can provide an emergency signal that can help you attract attention and call for help in case of an emergency. This can be useful in a wide range of situations, from outdoor adventures to unexpected accidents.
Simple Operation with Dual Control System
Array 2 Pro headlamp features dual control systems which makes operation super simple. There is a switch on top of the headlamp for one-button control. You can click the button to turn the headlamp on/off; Double-click the button to switch light modes; Long press the button to adjust brightness level; Triple-click the button to start SOS setting.
In addition, the Array 2 Pro headlamp also comes with a smart motion sensor. It means that you can wave your hand in front of the motion sensor area to switch light modes and adjust brightness level. Waving your hand left and right is able to switch the light mode, and waving your hand up and down can adjust the brightness level. However, this cool function is not applicable in switching light mode between red and white lights, SOS mode, or low-power lock mode. If the headlamp battery is lower than 20%, the hand waving sensor is unavailable.
Rechargeable Battery Pack with Long Battery Life
When it comes to battery life, the Olight Array 2 Pro headlamp doesn't disappoint. Its large 3350 mAh battery pack is conveniently located on the back of the headband, providing 27.5 hours long battery life without weighing down your head. You can easily recharge the battery using a USB-C port. Additionally, the battery pack's LED indicators serve a dual purpose by functioning as a battery level indicator and a safety light, enhancing your visibility and safety in low light conditions.With a weight of just 4.76 oz and compact dimensions of 2.4″x 1.22″x0.96″, the headlamp is effortless to carry with you on your outdoor adventures.
Durability and Comfort
The Array 2 Pro headlamp is designed to be both durable and comfortable to wear. Its seamless one-piece aluminum is built to withstand harsh outdoor conditions. It has a water-resistant rating of IPX 4, which means that you can use it in wet or damp environments without having to worry about damage.
The Array 2 Pro headlamp is also designed to wear comfortably. The adjustable headband is sweatproof, removable for cleaning, and perfectly fits most head sizes. In addition, the 60° tilting mount design provides the range of motion needed for clear visibility whenever and wherever your adventures take you.
The Array 2 Pro headlamp is a must-have for anyone who needs a reliable and powerful lighting solution. Whether you're camping, hiking, working in low-light environments, or just need hands-free lighting, this rechargeable headlamp is a perfect choice. If you like it, don't miss out on the chance ( Olight March Flashsale) to enjoy up to 30% OFF.
