If you're an Obulb orb light fan, you absolutely have to check out the upgraded Obulb Pro S! With so many functions you’ve come to rely on, the newly added features will be the icing on the cake. Not only is it more convenient and easier to use than the original orb light, but you’ll have no problem coming up with uses for this colorful new addition to the Obulb family. With so many colors to choose from, how can you choose just one?
Big Power in a Convenient Size
With a maximum output of 240 lumens, this powerful little orb light will exceed your expectations! It features a new stepless dimming feature that can be accessed by pressing and holding the bottom switch, which is so much more convenient than some of the earlier models! Weighing in at just 3.7 ounces and having a diameter of 2.56 inches, the Obulb Pro S orb light is not only handy, but it’s like having your own personal sun in your pocket!
Quick Charging and Long Runtime
The one-step magnetic charging cable will have your Obulb Pro S orb light up and running with a full charge in 3 hours. Not only does it power up quickly and easily, but one charge will last up to 6.5 days! With almost one week of runtime, the possibilities are endless! Whether using as a fun nightlight, or taking it along to light on your next outing, the Obulb Pro S orb light has your back!
Magnetic Base, Sturdy Build
Not only does the magnetic base come in handy for charging, but you can also use it to attach your Obulb Pro S orb light to almost any smooth metal surface, allowing you a multitude of mounting options! If you’re needing to attach it to a non-metal surface, you can use the included adhesive metal badge to stick it wherever you may need it. Pair that with the IPX7 waterproof and 1.5 meter impact resistance ratings, the Obulb Pro S orb light is ready for whatever environment or adventure you may have in mind!
New App Controlled
Saving the best and most fun new features for last! The Obulb Pro S multi-color orb light can be controlled by the Olight Hub app via Bluetooth connection. You can turn it on/off, change the brightness level or modes, change the color using the color wheel, and you can check your remaining battery level…all on the app! No more pressing the bottom button repeatedly to get to your desired color and function; now you can change any of those with just the tap of your finger! So many more fun functions are now available as well, such as: group controlling, music rhythm, countdown, etc. You can also use the family management option to allow you to share your Obulb Pro S orb light with others. All these colorful new possibilities and a bright, powerful flashlight, all in one!
Usage Scenarios
With so many possibilities, the better question might be: what CAN you do with the Obulb Pro S orb light?
If you love outdoor adventure, take it with you on your next camping trip to illuminate your tent, place it on your table as a fun light show for your friends, or grab it for a portable light to brighten your path to your car or the facilities nearby.
Need to light up a small space? The convenient magnetic back allows you to attach the Obulb Pro S orb light to virtually any surface, such as the inside of a cabinet or closet to help you find what you’re looking for. No more searching around for a light switch, or fumbling around in a dark closet or shelf, just press down on the Obulb Pro S to quickly illuminate your area.
Do you have a little one who loves to read? The Obulb Pro S orb light makes a fantastic reading light, or even a handy nightlight to keep next to their beds. The fun light show will give them a sense of security, and you can turn the light off or set a timer from your phone app to save on the battery at night. Plus, should they need to get out of bed in the middle of the night, they can grab their Olight Pro S orb light to show them the way!
You can never have too many Obulbs in a storm or power outage! Use them to light your rooms as a much safer alternative to candles!
Not only do the size, weight, and brightness make it a super handy palm-sized flashlight, but the uses of the Obulb Pro S orb light are truly endless! Don’t miss out on this fun new addition to the Obulb family!
👉Buy 1 item, 20% off. Buy 2 items, 30% off. Buy 3 or more items, 40% off. >>>Act Now
Giveaway
![Obulb Pro S Multi-color ORB Light: Smart and Colorful [Giveaway!]](https://cdn.olightstore.com/image/obulb-pro-s-916x516-po0vl9.jpg@920w_518h_75q.webp)
