Generally speaking, it’s not everyone needs a weapon light, however, for hunters who are used to carrying a rifle to shoot the target, it is useful and important to get a weapon light that can empower your weapon in dark situations. Some difficult situations usually happen in low light or no light situations, so if you can find a nice, compact weapon-mounted light to give you brighter light than other ambient light, it can be your helpful tool to save you in some crucial moments. To get a complete guide on weapon-mounted lights, Here is a list of highly recommended reviews of Olight best weapon light for hunting. Please read it carefully and take it as a reference.
Basic hunting knowledge
Bring a useful hunting tool: weapon mounted light
Among many hunting equipments, a weapon-mounted light is a small but powerful flashlight that mounts to the rails of your pistols or long gun. This hands-free light can produce a bright beam to enhance illumination in low-lit areas while simultaneously aiming at your target. During the hunting journey, it’s significant to bring it for some reasons. It can bring you clearer visibility while aiming for your target at night. When you use a premium weapon-mounted light, you can also easily identify your target before you pull the trigger. What’s more, it can help you to make quick decisions and ensure your light source can focus directly in front of your firearm at all times. In some difficult conditions, bright weapon-mounted light can help you get out of trouble and direct you to the right place. Above all, it mainly reduces your burden of spotting the animal and catches it as soon as you can.
How to choose a weapon-mounted light
Before we pick a proper hunting flashlight, it is also crucial for us to know which factors can affect looking for a quality product. First, the output of the beam is one of the important factors to measure the brightness of its performance. If the candela rating is sufficient, you don’t need to look for the best lumens product. Otherwise, you’ll have to find out more than 800 lumens flashlight for hunting. Next, each experienced hunter knows that an easy mounting can save time and energy. If you bring a rifle, you should plan where you mount the light and how much space you need between the light and switches. Last but not least, you should also consider choosing one which has multiple switches as it can give you access to different brightness levels with a few clicks.
Practical survival equipment review: The 8 best weapon-mounted light
Odin GL Mini Tactical Flashlight
Among the weapon-mounted light list, Odin GL Mini Tactical flashlight should be the top option for its accuracy in aiming at the target. Emitted by both white LED light and GL beam, Odin GL Mini flashlight can sport a maximum of 1000 lumens output and reach up to 180 m beam distance, which adds clearness of locking the objects at any time. With less weight and a compact size of only 5.06 inches, it is designed to be stored in a safe or case easily. Activated by a single press, you can easily toggle through its brightness levels including momentary, constant, low, and high. Plus, the batteries are rechargeable and can last for 250 minutes at the lowest settings. Therefore, it is perfect for hunting in terms of its decent performance.
Odin GL M Tactical Flashlight
None of the other lights have a special beam as the Odin GL M tactical flashlight has. Combined with white light and an intense GL beam, it enhances the visible accuracy of aiming day or night. If you are the GL beam junkie, this one would satisfy your need. With a throw distance of 215 meters, it has 1500 lumens of power and can run for 6.5hours on it, which is good for short-range. Just pressing the remote dual-button control, you can easily get access to its settings of four modes which include momentary, constant, high, and low function. You can tap to have it stay on and hold the button to shut off when released. Overall, this light is pretty much awesome and offers you the chance to select different options of light.
Odin Tactical Light
In case you are seeking an ultra-bright and exquisite product, Odin Tactical light is truly one of the best series that has been listed in many best-selling light options in the market. The most impressive feature is that it can rate for a brightness output of up to 2000 lumens. Equipped with a PMMA optical lens, this wonderful light can offer a throw distance of up to 300 meters, which can identify every threat and be on top of the situation. Powered by single rechargeable batteries, it can last for up to 8 hours at the lowest mode. With the activation of a revolutionary remote switch, it features a locking function for a tight fit. When you quickly slide to attach the light, it gives access to you swiftly illuminating and dominating the target area.
Odin Mini Tactical Flashlight
At the size of a regular tactical flashlight, the Odin Mini Tactical Flashlight is a small, yet powerful and long-range flashlight, delivering a maximum output of 1250 lumens and up to 240 meters beam distance. Operated by the included magnetic remote switch, it features an innovative push-to-lock function for a tight fit, which can stay safe in command at all times. Moreover, the multifunctional tail cap can ensure tactical handheld operation, which makes dual high and low outputs adapt to all conditions. Designed in an ultra-solid but compact outlook, the Odin mini has an extremely stable output throughout the 5-hour runtime. In a word, Odin mini is one of the most featured-packed weapon-mounted light options on the market.
Warrior X Pro Tactical Flashlight - Black
If you’re looking for the one which has the strongest output, Warrior X pro Tactical flashlight should be one of the most fabulous weapon lights on the list. Equipped with a tail switch, it can generate a 2100 lumens beam of light and can reach up to 500 meters throw, which assures you can see clearly in any harsh condition. Powered by a customized lithium battery, the Warrior X Pro features a max runtime of 8 hours, which supports longer runtime than the original Warrior X. Besides, with the super-efficient MCC3 charging cable, it can get a faster charging than others. With the tactical ring and aggressive bezel, it is an ideal choice for outdoor hunting.
Warrior X Turbo Tactical Flashlight - Black
In terms of the throw of distance, if you favor a far-reaching product, the Warrior X turbo tactical flashlight in Black deserves you to take a look. Blasting a maximum of 1100 lumens output, it can deliver a super-far throw up to 1000 meters, which is perfect for all variable outdoor conditions including hunting, rescue, and other emergency conditions. Powered by a high-capacity battery, the Warrior X Turbo can last for 12.5 hours at the lowest settings. Mounted on a long barrel and controlled by a remote pressure switch, it is great for professional use. You may consider it a pro or con, but at least you don’t have to buy a bunch of extra accessories once you get it.
Javelot Turbo Spotlight Flashlight
According to many customers' reviews and dependable comments, Javelot Turbo Spotlight flashlight fully deserved a useful and professional hunting tool. Providing a blast of 1300 lumens output, it can reach up to a maximum throw of 1300 meters, which outperforms any other hunting flashlight. Additionally, on a single charge with two batteries, it can guarantee for 8-day runtime.
Unlike other weapon-mounted lights, it owns a dual switch. One is a tail switch and the other is a slide switch, which can activate 4 modes covering from Turbo to Low setting by a single press. Thanks to the IPX 8 water resistance and one-meter shockproof rating of this light, you can expect it to perform well in any harsh conditions. Though it may not be the highly-affordable one, it still is a valuable and multifunctional weapon-mounted light.
Javelot Pro 2 Long Distance Flashlight
For many weapon-mounted lights for hunting, this Javelot Pro 2 packs a paunch. Starting with this Javelot Pro 2, it gives you an incredibly bright light at 2500 lumens with an extreme 1050 meters beam distance and lasts for an impressive 12 days at that brightness. More importantly, it can give you stability and superior performance than any other hunting light can’t do before. There are two color options for this edition of Javelot Pro 2. One is black and the other is desert camouflage, and you can choose which you like. Besides holding it in your hand, you can also install it on your long setups. As for the hunting flashlight, this is a contender for the best weapon-mounted light.
Other advice for hunting
Make full preparation
Even carried with the key weapon light equipment, hunting is still a suffering thing for most people. First, you need to carve a lot of time to make a plan in case of some accidence. Before the hunting season come, you need to practice shooting your bow for hours every day, which can ensure the effectiveness of a rifle hunt to the greatest extent. Next, you need to prepare yourself to engage in the hunting process. It is doomed to be a tough thing but you have the right to choose which kind of suffering can fit your desires. You can choose to bow hunt antelope in Wyoming or gets a fourth-season rifle tag for elk. Finally, before you hunt, please remember to check your equipment such as maps, compass, guns, knives, etc.
Choose an animal
Another crucial step is to pick an animal you want. Harvest rates differ widely by species and state. In most cases, the percentage ratio of harvested animals to total hunters is in the teens. Take this factor into consideration, which means that you should pick your target animals in terms of your surroundings. Even though you may have never seen this animal, you can still spot the place and the relevant species you may expect. For example, you should select pheasants or other upland birds if you plan to stay in undulating prairie grasses. If you like climbing mountains, you can choose elk and mule deer. This method may not be the most constructive but it can be the most practical as you can try to make expectations.
Ask for other help
Hunting is hard and you have to endure this difficulty, however, you can find a mentor who can give you advice in needy if you are full of anxiety and worries. Sometimes a virtuous mentor can help you out when you are stuck in complex circumstances, particularly in the wilder hunting. There is no common advice for finding your mentor. Therefore, what you can do is just keep asking questions and be humble when you’re given breadcrumbs of hunting knowledge. You can try to look for help from your local shop retailers who is passionate and friendly. You can also message on Instagram or your friend who is exactly a hunter. To be brief, try to be open-minded and put yourself somewhere people know more than you.
To facilitate your hunting journey, you need to bring the core weapon-mounted flashlight from what we have reviewed here. You can choose according to your taste. No matter which weapon-mounted light you choose, it will have its special characteristic than others and limitations at the same time. But you can determine it by choosing the most appropriate hunting ways. With a rifle, you may need to shoot the animal for at least 100 years or more, which means you need a long-range weapon-mounted light. But if you just bring the bow then you just want the short-range but bright flashlight which can offer a great output of beam. For more juicy details, have a look around Olightstore. Come to see which light fits you best.
