When it comes to finding the perfect rail-mounted light for your firearm, the PL Turbo Valkyrie, or PL Turbo for short, stands out as a secure and convenient choice. With a maximum output of 800 lumens and an impressive throw of 515 meters, this tactical accessory is designed to offer both an intense spotlight and ample floodlight simultaneously. Let's dive into the details that make the PL Turbo a top choice among professionals and enthusiasts.
The PL Turbo Rail Mounted Light: A Closer Look
The PL Turbo Valkyrie is all about providing exceptional illumination and versatility. Its one-of-a-kind design allows you to easily observe both distant and nearby surroundings with ease, making it an ideal tool for outdoor search missions, self-defense scenarios, or law enforcement use.
Key Features of PL Turbo Rail-Mounted Light
The PL Turbo packs a powerful punch with its remarkable features:
✅Long Focus & Wide Angle Simultaneously: What sets the PL Turbo rail mounted light apart is its ability to provide an intense spotlight while simultaneously offering ample floodlight. With a maximum output of 800 lumens, the PL Turbo tactical light is designed to light up even the darkest of environments. It doesn't stop there; it offers a throw of 515 meters and an astounding 66,300 candela, allowing users to observe both distant and nearby surroundings with ease.
✅100+ Compatible Builds: The PL Turbo tactical light is not limited to a specific setup. Thanks to the innovative sliding block within its rail clamp, it accommodates a wide range of short and long configurations with both Picatinny (MIL-STD-1913) and GLOCK rails, which make it used as a Glock light or Picatinny light. The rail clamp's screw-locking mechanism ensures a secure and reliable attachment, providing peace of mind during use.
✅Battery Options: While the PL Turbo rail mounted light comes with two CR123A batteries, it's also compatible with aftermarket CR123A batteries or Olight rechargeable RCR123A batteries. This versatility ensures that you can easily find replacement power sources, whether you're out in the field or stocking up for extended use.
✅Rugged Durability: Constructed from durable anodized aluminum and featuring an impact-resistant tempered glass lens, the PL Turbo rail mounted light is built to withstand the rigors of real-world use. Its scratch and corrosion-resistant body ensures longevity and reliability.
Expert Testimonials
To truly understand the PL Turbo's performance, let's hear what experts in the field have to say:
👨Sootch00's Take:
"PL Turbo is an 800 Lumen Light but has an impressive beam distance of 515 meters. It has a great hot spot and a nice spill."
👨Mrgunsngear B Channel's Review:
"I'm quite sure that the high-candela PL Turbo at such a price will be extremely marketable in that its counterparts are being sold at a very high price. Most people will attach it to long builds due to its incredible 66,300 candela."
👨704 TACTICAL's Perspective:
"It has a good center spot and flood light around the edges. Very bright but still usable inside. Very versatile and fits a lot of builds."
User Feedback
🌟User feedback is equally valuable, and the PL Turbo has garnered positive attention:
🌟Great. Good balance of size and output. Exactly what was needed for my 4.6' 10mm for outdoors.
🌟I wouldn't change anything, everything works like it should and the improvement on the throw is impressive. There is a ton of light from a little light.
🌟I really have enjoyed the Pl Turbo so far. The design and durability of the product is great.
🌟Good snug fit on my Sig and didn't move after a box of ammo. Light is decent for my basic needs. Switches are easy to activate.
🌟The locking mechanism is pretty good. more secure for sure.
🌟I like the combination of flood and throw of the weapon light. It's great. Keep working on getting them smaller and lighter.
🌟The light works well and the build quality is fantastic. As a weapon mounted light, it uses enough candela to identify and distract potential threats. I'll be buying more.
🌟Works as expected. The switch and battery cover are solid. The improved mount lock is great.
🌟Great weapon mounted light and super bright. The adjustability is great for different size firearms and hand sizes. The new locking style is a lot more minimalist and super secure.
🌟Once I received it, I couldn't wait to use it. Went outside after it got dark, the brightness and throw were amazing. Fit my full size pistol perfectly.
🌟I can definitely assure you that if you purchase this light you will not be disappointed. The PL Turbo is a well built and balanced weapon light that has the right amount of weight. The design fits my Prodigy perfectly. The buttons on the PL Turbo function better the the TLR-1 HR that I used to have mounted. You can’t go wrong with this light.
The PL Turbo is a rail-mounted light that not only meets but exceeds expectations. With its exceptional brightness, impressive throw distance, and versatile design, it's no wonder that both experts and users alike sing its praises. Whether you're on a critical mission or safeguarding your home, the PL Turbo will be your essential lighting tool, offering reliability when you need it most.
