In the field of mobile lighting, tactical lights have a role that cannot be ignored. The existence of tactical lights is to assist users in identifying targets in low-light environments so that law enforcement officers or military and police personnel can use weapons to aim the target accurately and illuminate the tracked target, which can temporarily blind the target and lose a sense of direction, and have plenty of time to react.
Introduction of products
Olight Baldr mini is a small tactical light suitable for self-defense, military and police duty and rescue. The small size will likely be the main consideration for the clientele of the Olight Baldr Mini. Dimensions are a svelte 2 ¼ inches long, 1 ¼ inch wide, and weight with the integral 230 mAh battery is just a bit over three ounces, its machined aluminum casing adding minimal weight to the desired firearm home. These dimensions place the Baldr Mini roughly in the same overall dimensions as the familiar aforementioned Streamlight and Surefire products – and that’s about where the similarity ends. The Baldr Mini is very bright at such a small size that combines both highly visible green beam and white light, integrating the compatibility of the PL-Mini 2 and the accuracy of the Baldr Pro.
Then, the barrel of the Olight Baldr mini is made of AL6061-T6 aviation aluminum alloy and has undergone three-level hard oxygen treatment, which is very wear-resistant and fall-resistant, and the waterproof level is IPX4. The lamp head adopts a tempered glass lens with a double-sided translucent coating so that the light transmittance reaches 99%. Baldr mini has a maximum output of 600 lumens and a range of 130 meters. On a full charge, the Baldr Mini boasts about 40 minutes of runtime on just the white light and 30 minutes of continuous-on with the laser running at the same time as the light.
The Baldr mini even has a red light on the side to let you know when the battery is at 10%. At the same time, the built-in 3.7V230mAH lithium polymer battery can be charged through the magnetic MCC charging cable without removing the battery, which is very convenient. The magnetic charger is a fun and durable way to charge the battery, it magnetically attaches to the charging port of the light, followed by a green (charging) or red (charging) indicator light for a very clear view of the charging status.
Green laser
Olight Baldr mini is also a tactical light with a 5nW green laser sight. The green laser and white light are output from the same light cup. The product designer set the laser in the light lens, and the installation position is very hidden and will not be visible. And the light beam emitted by the green laser is clearly visible in the dark, the light spot is small and perfectly circular, it can also adjust and position the laser through the two small holes on the side of the Baldr mini, which helps to maintain the zeroing of the laser over longer periods of time without needing additional zeroing. Turn the rear screw to adjust horizontal (left/right) alignment, and turn the front screw for vertical (up/down) alignment. Though at a compact form factor, it delivers 600 lumens of bright white light, along with a highly visible green beam for greater accuracy. A green beam is added for greater accuracy and there are more options to select among white light only, green beam only or both combined depending on the different tactical environment.
Adjustable rails
As for the rails, the Olight Baldr mini is equipped with its own pioneering patent-adjustable rails, which can eliminate the structural differences between different transmitters effectively. Mounted on the transmitter with Pic rail or Glock, it can be installed or removed in 1 second easily. The adjustable rails are attached to your weapon securely, and you slide the Baldr mini forward or backward simply to the position that best fits your finger, then lock it. The quick attach and release mount make the BALDR Mini extremely easy to manipulate for everyone. Special note: Olight's tactical lights are all original lights equipped with real iron. The operation of the Baldr mini is also very simple, the dual rear switches permit smooth momentary-on or constant-on activation by either hand with equal ease.
Packaging
You can refer to the table below for the contents of the package and the accessories associated with the Baldr mini.
IN THE BOX | Baldr mini weapon light(battery built-in) x 1 Picatinny (Mil-std-1913) Rail Mount x 1 HM2.5*4.5 Socket Cap Screw x 2 MCC (Magnetic Charging Cable) Special Edition x 1 H1.5 Allen Wrench x 1 User Manual x 1 Oval Point Set Screw x 1 and Cone Point Set Screw x 1 |
In a word, the Baldr Mini is a compact weapon light, and if you are looking for a more precise laser, smaller size and lighter weight, the Baldr mini is your choice. Now, the Baldr mini is also sold in combination with the i3T EDC flashlight, which has a bigger discount. Come and buy it now! Thank you for reading.
