When you talk about the night, what do you think ofit?
When you search and rescue the target group in the long darkness, what will you need?
What can give you a sense of security when you face all kinds of complicated situations when you are hiking alone in the middle of the night?
When you are hunting covertly at night with your shotgun, what can help you observe the movement of the prey?
It's it-Strong light long-range search and rescue flashlight: Javelot pro2 and Javelot turbo
You may be thinking: What excellent performance does a flashlight need to be worthy of my trust and purchase and finally become my partner? In this regard, there are many factors that you need to consider, but I emphatically select the following points for your reference:
1. Reference factors
(1) Brightness
From the most basic function, the flashlight is the basic lighting tool in the dark, so brightness is the basic requirement of the flashlight. Therefore, you need to understand several criteria related to brightness:
1. Luminous intensity: The most basic is the luminous intensity Candela, the symbol is cd, which is used to indicate the intensity of the light source in one direction.
2. Luminous flux, unit-LM. Luminous flux is the amount of light energy that arrives, leaves, or passes through a curved surface per unit of time. In order to facilitate understanding, I propose a metaphor that may not be appropriate here. Luminous flux is like force in mechanics. It is the brightness emitted by the luminous body.
3. Illumination intensity, unit lux (lux) "Illumination intensity, referred to as illuminance. Illumination/illuminance on a surface irradiated by light is defined as the luminous flux illuminating a unit area." The analogy to luminous flux, we will illuminate Ratio is the pressure in mechanics. It is the brightness of the light on the object. Learn more!
Javelot pro2 Long Distance Flashlight VS Javelot Turbo Spotlight Flashlight product demonstration:
MAX OUTPUT | 2.500lumens | 1.300lumens |
Light Intensity | 217.400 CD | 422.500 |
(2) Lighting mode
Most of the OLIGHT flashlights can be set with a variety of lighting modes, and the lighting of different gears can match your needs in different scenarios. When you search and rescue outdoors, the light of 150LM will make you feel that you can't see the search and rescue target. And when you only use it in an emergency at home, the light of 1300LM will be too much when it is lit indoors, and it may even cause damage to the eyes.
It is necessary to choose the right lighting gear on the right occasion, and it is also convenient to choose a multi-stage lighting flashlight suitable for your own use.
Javelot pro 2 Long Distance Flashlight VS Javelot Turbo Spotlight Flashlight product demonstration:
MODE 1 | 2500 ~1000~600LM/5+180+27Min/1050M | 1300 ~800~500~150LM/10+140+30+110Min/1300M |
MODE 2 | 600~150 LM/420+42Min/510M | 500~150LM/350~130Min/900M |
MODE 3 | 150 LM/32H30Min/255M | 150LM/27H/480M |
MODE 4 | 15LM/12Days/85M | 15LM/318H/140M |
(3) Running time
Running time is one of the factors that affect the user experience. People holding handshake phones are very afraid that their flashlight will suddenly power off and cause trouble to their work.
Therefore, it is very necessary for people who use flashlights to understand the operating time limit of each gear. At the same time, increase the power indicator function and inform related information about charging, so that people will arrange a time and timeto charge the flashlight. Ensure that the daily schedule goes smoothly.
Javelot pro2 long distance flashlight VS Javelot Turbo spotlight flashlight product demonstration
Running Mode | MODE 1 | 2500~1000~600LM/5+180+27Min | 1300~800~500~150LM/10+140+30+110Min |
MODE 2 | 600~150 LM/420+42Min | 500~150LM/350~130Min | |
MODE 3 | 150 LM/32H30Min | 150LM/27H | |
MODE 4 | 15LM/ 12Days | 15LM/ 318H | |
Rechargeable | ✓ | ✓ | |
Charging Cable | MCC3 USB Magnetic | MCC3 USB Magnetic | |
Battery Type ( Included ) | Integrated Battery Pack ( Two 3.6V 5000mAh 21700 Rechargeable Li-ion Batteries ) | Integrated Battery Pack ( Two 3.6V 5000mAh 21700 Rechargeable Lithium Batteries ) | |
Battery indicator |
(4) Durability
Surface material: Black is very common as the classic color of a flashlight, but different flashlight colors are more ornamental. While paying attention to the aesthetics of the surface, it is also necessary to pay more attention to whether its surface treatment is strong enough to prevent scratches and damage, such as aviation aluminum alloy shell, the surface is three-level hard oxidation.
In addition, flashlights with waterproof and drop-proof performance are less likely to cause damage when you go out on an adventure or accidentally fall.
Body craft | Aviation aluminum alloy shell with three-level hard oxidation on the surface | Aviation aluminum alloy shell with three-level hard oxidation on the surface |
Waterproof | IPX8 | IPX8 |
Drop test | 1 | 1 |
After talking about the conditions for identifying flashlights, you will find that Javelot pro2 and Javelot Turbo can be regarded as excellent Strong light long-range search and rescue in terms of brightness, lighting mode, running time, portability, and durability. flashlight representative.
2. Parameter Comparison
If you haven't figured it out yet, you can look at the general comparison chart below (javelot pro is specially used in this article) for comparison
Javelot Pro2 VS Javelot Turbo VS Javelot Pro product demonstration:
(Discontinued) | ||||
MAX OUTPUT | 2.500lumens | 1.300lumens | 2100LM | |
Light Intensity | 217.400 cd | 422.500cd | 291.600 cd | |
MAX RUNNING TIME | 12Days | 318H | 8Days | |
Length | 110.20in/259mm | 10.20in/259mm | 9.72in/247mm | |
Head Diameter | 2.48in/63mm | 2.48in/63mm | 2.48in/63mm | |
Body Diameter | 1.02in/26mm | 1.02in/25.8mm | 1.02in/26mm | |
WEIGHT (Including Battery ) | 14.92oz/423g | 14.40oz/408g | 13.4oz/380g | |
Running Mode | MODE 1 | 2500 ~1000~600LM/5+180+27Min/1050M | 1300~800~500~150LM/10+140+30+110Min/1300M | 2100 ~1000LM/5+145Min/1080M |
MODE 2 | 600~150 LM/420+42Min/510M | 500~150LM/350~130Min/900M | 600LM/5H/540M | |
MODE 3 | 150 LM/32H30Min/255M | 150LM/27H/480M | 150LM/23H/270M | |
MODE 4 | 15LM/12Days/85M | 15LM/318H/140M | 15LM/8Days/90M | |
BODY MATERIAL | Aluminum Alloy | Aluminum Alloy | AL6061-T6 Aluminum Alloy | |
Operate Mode : Side Switch & Tail Switch | A side switch to select 4 different modes during daily use ; A dual-stage tail switch for tactical operation. | A tail switch to access 1.300-lumen or 15-lumen output directly; A side switch to cycle through 4 output settings | The tail switch deliveries 2.100 lumens high mode and 15 lumens low mode. The side switch can turn thelight on or off and cycles through the following modes: 2.100 lumens, 600 lumens, 150 lumens and 15 lumens. | |
Body craft | Aviation aluminum alloy shell with three-level hard oxidation on the surface | Aviation aluminum alloy shell with three-level hard oxidation on the surface | Aviation aluminum alloy shell with three-level hard oxidation on the surface | |
Rechargeable | ✓ | ✓ | ✓ | |
Charging Cable | MCC3 USB Magnetic | MCC3 USB Magnetic | Magnetic USB charging cable MCC5 | |
Waterproof | IPX8 | IPX8 | IPX8 | |
Drop test | 1 | 1 | 1 | |
Battery Type ( Included ) | Integrated Battery Pack ( Two 3.6V 5000mAh 21700 Rechargeable Li-ion Batteries ) | Integrated Battery Pack ( Two 3.6V 5000mAh 21700 Rechargeable Lithium Batteries ) | I ntegrated battery pack | |
IN THE BOX | Javelot Pro 2 (Battery Pack Included) x 1 | Javelot Turbo (Batteries Included) x 1 | Flashlight x 1 | |
Javelot pro2 or Javelot turbo , which one do you think is more suitable for you? Learn more!
