Odin is OLIGHT’s new tactical flashlight, professionally designed for PICATINNY mounts, with a refined and textured appearance. It brilliantly follows the Warrior X low power vibration indication, metal silent switch, and magnetic charging the classic features.
Innovative mechanical locking quick-release slide, two installation positions can easily achieve 90 degrees to change the installation of forward and reverse direction installation, on-demand, enhancing user experience. Innovative magnetic wire switch with locking function lightly pushed to lock, more tight and secure. Standard with single section customized 5000mAh 21700 rechargeable lithium battery and optical grade PMMA lens, with output up to 2000 lumens and 300m range.
Odin also has a unique vibration feature that feels similar to the tactile feedback you get on your phone screen. The purpose of this is to tell you if the light is on/off or to communicate the battery level. This feature seems useful when the light is in your hand but seems less useful when mounted on a weapon, as you can't feel the slight vibration through the weapon or while you're focused on more important things.
