Rail mount lights are weapon lights mounted to your rifle, pistol, long or shotgun. Having a hands-free flashlight in your weapon provides you with the ability to identify targets or react to any stressful situation at night. Explore rail mount lights that are best for your project is full of significance. Olight provides a wide variety of available rail mount lights for your choice. The following are the 3 best rail mount lights for your weapon. You can pick one perfect for your needs.
Sigurd Angled Grip Light
Sigurd is Olight first 2-in-1 angled foregrip light for your long-range setup. It looks a lot more modern. Unlike conventional vertical foregrips, the innovative Sigurd angled foregrip help you more effectively manage recoil and facilitate faster, more accurate follow-up shots. Its integrated Picatinny mount and small size allow optimal placement on a variety of handguards while still leaving space for other accessory mounts. It is also available on M-LOK rail by simply installing a section of the appropriate Picatinny rail adapter. With two light settings, Sigurd delivers the highest output of 1450 lumens and low output of 290 lumens. Excellent both in close quarters and long-range illumination.
Sigurd's design is heavily influenced by natural body mechanics and ergonomics, providing a comfortable user interface that reduces fatigue and allows for more precise control. Its unique combination of heat insulation material, anti-slip grooves, and finger stops ensure a confident grip during fast-paced, extended use. With switches positioned on both sides, Sigurd is truly ambidextrous.It can be activated by either hand with equal ease. This allows shoulder transitioning and other advanced close quarters techniques to be performed smoothly and quickly. Rechargeable with Olight's signature USB magnetic charging cable so your weapon mount light is always ready for action. No more expensive single-use batteries to buy so as to save cost.
PL-3 Valkyrie Tactical Light
PL-3 Valkyrie is a compact weapon mounted light with adjustable sliding block. Compared to PL-2, its white light output goes up to 1300 lumens and is complemented by a low 200-lumen setting, meeting your needs in a variety of scenarios. The industry leading adjustable sliding block allows for more flexible positioning of the light on the rail, making it compatible with a wider range of short builds. With two rail adapters included, PL-3 Valkyrie weapon mount light can attach securely to both Picatinny and Glock accessory rails (GL Rail Adapter / 1913 Rail Adapter).
Powered by 2x CR123A batteries, this weapon mount light provides a max runtime of 270 minutes. You don't need to wait for a recharge any more, just replace them and go! Its dual ambidextrous switches allow you to quickly and easily choose between momentary and constant-on modes with either hand while also giving access to the strobe. PL-3 Valkyrie tactical light features secure screw locking mechanism. You can simply unlock the screw locking device by hand, with a hex wrench, or using a coin, and then push it and slide the locating block at the same time to position the light. When the installation is complete, the light will remain stably mounted shot after shot.
We conducted an extreme reliability test on a random sample of 10 individual PL-3 Valkyrie. In the very high recoil(approximately 37 ft-lb or 50J) simulated shooting test, all 10 examples remained intact and fully functional after 45,000 continuous rounds. Bright, dependable. and truly ambidextrous, PL-3 Valkyrie provides an advantage in any tactical situation.
Baldr Mini Tactical Light with Green Laser Sight
The Baldr Mini is an ultra-compact white light and green beam combo, integrating the compatibility of the PL-Mini 2 and the accuracy of the Baldr Pro. Two types of rail adapters are provided to fit both Glock and Picatinny rails. Featuring an adjustable sliding rail, the light can be easily adjusted forward and backward into the position that suits you the best. Though at a compact form factor, it delivers 600 lumens of bright white light, along with highly visible green beam for greater accuracy. You can select among white light, green beam, or green beam & white light combined.
The BALDR Mini is powered by a built-in lithium polymer battery, which can be charged through our signature magnetic charging port for extended runtime. The low battery indicator alerts you when it’s time to recharge. The dual rear switches permit smooth momentary-on or constant-on activation by either hand with equal ease. The quick attach and release mount and the slim switch make the Baldr Mini extremely easy to manipulate for everyone.
End Words
Whether you're military personnel, law enforcement or simply want to get in some nightly target practice, these 3 tactical rail mount lights are the best to enhance your visibility in dark areas. If you want to learn more Olight tactical lights, please click here.
