How many of you use flashlights in daily life? Well, not many because most of you rely on your smartphone flashlight. Cell Phone flashlights are not bad but still have some limitations.
If you are camping in the wilderness or going night hunting, your smartphone will only be good for capturing photos, making calls, or texting someone but not for lighting purposes. You can use your phone for illuminating small areas but for outdoor activities and for fixing repairs in the darker area of the house, you will need a dedicated multi-function flashlight. The reality is, most of you do not have a multi-function flashlight somewhere around your house.
In this post, we highlight 5 uses of Multi-Function flashlights in our daily life and how they can come in handy in many different situations.
1. Power Outages
An obvious use of a multi-function flashlight is during a power outage. People living in a well-lit area such as Time Square in New York might rarely experience power outages but for people in living coastal areas such as Florida, power outages are common.
Regardless of where you live and how frequently you experience power outages, you should have a multi-function flashlight by your side. You can use it to light up the room, navigate through the dark or check on other family members or colleagues during emergencies.
Multi-function flashlights such as Baton 3 Pro can come in handy for signaling help if the power outage is caused by a fire breakout or during a zombie apocalypse if that happens.
2. Camping
Ask any camping guru to tell you the three most important tools for camping. Without a shadow of a doubt, I can tell you that multi-function flashlight will be on the list. Yes, multi-function flashlights are that important during a camping trip.
Multi-Function Flashlights come in handy for illuminating the trails and navigating to the campsite or finding your way back to the camp after dark. You can also use it for setting up your tent, cooking, or even reading maps and books.
If you’re hiking to the campsite, it helps you avoid obstacles and potential hazards such as rocks, roots, snakes, spiders, and other deadly crawlers.
If you’re planning to go for night fishing, again you’ll need your Multi-function flashlight. It will help you navigate to the fishing spot, help you tie lures and baits and even attract fish by shining the flashlight on the water's surface.
3. Automotive Repairs
Whether you are a car mechanic or someone whose car broke down in the middle of nowhere at night, a multi-function flashlight can make your day.
multi-function flashlights such as Baton 3 Pro are compact in size and can be used to illuminate hard-to-see areas under the hood, find the source of a strange noise coming from a vehicle, read repair manuals, or check fluid levels.
Whether you’re trying to diagnose a problem in a tight space of your car or working on a repair that needs a closer look, a reliable flashlight will always be the best source of light for you.
4. Home Repair
Once in a while, we all encounter small damages here and there around the house. Some damages can be easily fixed while some need light to be properly inspected. Multi-function flashlights come in handy for investigating and repairing tight and hard-to-see areas such as behind the walls, in attics, or in crawl spaces.
Sometimes to fix a problem you have to find the source of a problem, for example, leakage, drafts, or other issues that may be affecting your home’s energy efficiency. With the help of an Multi Function flashlight, you can shine the light in various areas of the house to pinpoint the problem and determine the cause of the issue.
5. Self-Defense
Do you know you can use flashlights for self-defense? Nowadays, both tactical and multi-function flashlights come equipped with strobe functions and striking bezels, which you can use to disorient an attacker and escape or defend yourself.
You can also use the strobe mode to send emergency signals. Even police and firefighters rely on flashlights to help them navigate and perform their duties in dark and dangerous environments, so having one in your pocket is vital.
A flashlight is a versatile tool For Everyday Need
As smartphones become mainstream people have forgotten the need for a separate flashlight. What they don’t realize is that Multi-function flashlights are brighter, have better beam distance, and last much longer than a smartphone.
Flashlights are a reliable tool that can make your life much easier. Whether you’re hiking, need to fix something around your house, or just want some light for an evening walk, a Multi-function flashlight is all you need.
If you haven't owned a flashlight yet, click here to grab the deal. Baton 3 Pro gives you all the features that you need in a multi-function flashlight at a minimal cost.
