As much as electricity has transformed the world, so do flashlights. Though electricity is widely available today, it still has some limitations. It can’t reach every corner of the world, but your flashlights can as long as it’s in your backpack or pocket.
If you have watched the Man vs. Wild show on Discovery channel you know who Bear Grylls is and what he does for a living. In most of his episodes, I am sure you have seen him using flashlights.
The flashlights that he uses might not be the best flashlights on earth but their importance in survival situations is more than that of electricity. I admit electricity has become one of our primary needs but when you’re out into the wild, you need something more reliable than electricity.
Every individual should have at least one flashlight ready to be used by their side. Today we’ll look at the three most popular flashlights from the Olight Baton series.
Comparison between Baton 3 1200 Lumen Flashlight, Baton 3 Pro 1500 Lumen Flashlight, and Baton 3 Pro Max 2500 Lumen Flashlight
By the name itself, you can tell which flashlight is the most powerful because it has a similar pattern to the iPhone. When it comes to the iPhone everyone wants the Pro Max version but in the case of flashlights, the “Max” version might now be best and ideal for everyone.
Let’s find out why?
Olight Baton 3 1,200 Lumen Rechargeable Flashlight
This is an upgraded version of the S1R Baton II, which is again one of the best flashlights. Though Baton 3 is the smallest flashlight in the Baton series the amount of lumen it can produce is amazing. Let’s look at its amazing features.
✅Performance - This tiny yet powerful flashlight uses a high-performing cool white LED and TIR optic lens. It can deliver a maximum output of 1200 lumens and a beam throw of up to 166 meters.
✅Battery Life - The runtime is solely dependent on the lighting mode. In high settings, it can run up to 95 minutes and in low settings, it can run up to 20 days. If you buy the Baton 3 premium version you also get a mini portable power bank that can recharge the flashlight up to 3.7 times.
✅Brightness Setting - You get 5 brightness settings and a strobe mode. You can use the mode to your needs and different situations.
✅Durability - Almost all the best flashlights have sturdy construction, and so does the Baton 3. This flashlight is made of aluminum alloy, has IPX8 waterproof rating, and can withstand drops from up to 1.5 meters.
✅Additional Feature - It has a battery level indicator that tells you when to recharge your flashlight. The tail cap allows you to use the flashlight hands-free. Let’s not forget the finely-milled new texture body for better grip.
The unique thing about this flashlight is its compact size; it’s smaller than Baton 3 Pro LED Flashlight and Baton 3 Pro Max brightest flashlight. And you also get a portable power bank in the premium version, which you don’t get with the other two Baton flashlights.
Olight Baton 3 Pro 1,500 Lumen LED Flashlight
Baton 3 Pro LED Flashlight is again an upgraded version of the S2R Baton II, which is again one of the best flashlights on the market. Anyone looking for a brighter and longer beam flashlight than Baton 3, this one's for you.
✅Lumen and Beam - Baton 3 Pro LED Flashlight can produce a maximum of 1500 lumens, which is an increase of 30% from the S2R Baton II and Baton 3. The beam can travel up to 175 meters.
✅Runtime and Battery - It runs up to 120 days on a low-mode setting and can be charged fully in 3.5 hours with the MCC3 USB magnetic charging cable.
✅Brightness Setting - Similar to Baton 3, Baton 3 pro LED Flashlight also offers five brightness levels, which you can adjust to match your specific needs. And yes, it also has a strobe mode for emergencies.
✅Durability - Baton 3 Pro LED Flashlight is also designed with high-quality aluminum alloy, making it reliable and long-lasting. Similar to Baton 3 it also features IPX8 waterproof rating and a 1.5-meter drop test.
✅Additional Features - You get two color temperature options, a larger side switch, a battery level indicator, a magnetic tail, and a magnetic L-stand.
Some of the differences between the Baton 3 and Baton 3 pro LED Flashlight are the lumen output, beam distance, runtime, and color temperature options. Other than that there’s not much difference between the two.
If you’re looking for the best flashlight for outdoor activities and general use, both are good options.
Olight Baton 3 Pro Max 2,500 Lumen Brightest Flashlight
For anyone looking for a compact-size flashlight, Baton 3 is a good option. If you want a powerful flashlight and don’t care much about the size, go for Baton 3 Pro LED Flashlight.
For users who require the maximum brightness and longest battery life, the Baton 3 Pro Max Brightest flashlight could be the best option.
Again, this might not be the best flashlight for everyone. Here’s why?
✅Lumen and Beam - This little champ can deliver a maximum output of 2500 lumens, which is 2.08 times more than Baton 3 and 1.66 times more than Baton 3 Pro LED Flashlight. But the beam can only reach up to 145 meters, which is less than the two Baton flashlights mentioned above.
✅Runtime - Baton 3 Pro Max brightest flashlight is powered by a 5000mAh battery which makes the flashlight runtime last up to 60 days. Similar to Baton 3 Pro LED Flashlight, this flashlight can also be fully charged with its MCC3 charging cable.
✅Brightness Settings - Again brightness mode is the same with the above two Baton flashlights, five brightness levels, and a strobe mode.
✅Durability - Unlike the previous two versions, this one is made of Magnesium alloy(Desert Tan). This is also the first Olight flashlight made with this metal. This metal is lighter than aluminum, excellent impact resistant, and recyclable. This flashlight also features IPX8 like the others.
✅Additional Features - Three color temperature options, magnetic tail, enlarged and recessed side switch, upgraded proximity sensor, and battery level indicator.
When compared to the other models in the Baton series, the Baton 3 Pro Max brightest flashlight is the best flashlight for those who need maximum brightness and the longest battery life.
However, for users who do not require the maximum brightness but need a longer beam distance the Baton 3 or Baton 3 Pro LED Flashlight may be a more economical option.
Final Thought
If you’re looking for the best flashlight that is long-lasting, has multiple brightness levels, and has a sturdy construction that can withstand heavy use and harsh conditions, the Baton 3, Baton 3 Pro LED Flashlight, and Baton 3 Pro Max brightest flashlight are all excellent options.
The three models mentioned above are best made for everyday carry, it has all the things that you’ll need in an EDC flashlight. If you’re looking for a specific feature in a flashlight, you can check out the Olight store for more options.
It doesn’t matter which model you choose until and unless you go for an Olight flashlight, you can be confident that you are getting a reliable and long-lasting tool that will provide you with the light you need.
