Pack a headlamp, an independently powered backup light, enough usable power for your planned nights plus a delay, and a whistle you can reach. Choose the batteries and cables for those exact devices. Add camp lighting only when it solves a separate task and fits the weight you can comfortably carry.
- 1. TL;DR
- 2. Build the nighttime kit around independent light
- 3. A printable backpacking checklist in ten categories
- 4. Why should a backup light have a separate power supply?
- 5. Choose a main lamp, a compact backup, and a signal
- 6. Budget power for one, three, and five nights
- 7. Count charging paths and cell sizes
- 8. Compare three complete lighting combinations
- 9. Weather, red light, lockout, and small packing omissions
- 10. What should I pack for a 7-day backpacking trip?
- 11. What are the must-have items for backpacking?
- 12. What are 10 essential items you need to take with you when backpacking?
- 13. Resupply and conditions that change the plan
- 14. Frequently asked questions
TL;DR
Count hours in the lighting mode you expect to use, then add time for an unplanned night. Keep the backup ready without borrowing the main lamp's battery or charger. Pack the complete system, including its headband, spare cells, cables, and protective storage, before comparing weight.
| Job | Recommended type | Minimum practical requirement | Example to consider |
| Walking and camp chores with both hands free | Adjustable headlamp | A usable beam and fit for your route, with enough runtime in the selected mode | Perun 3 |
| Finding gear and dealing with a failed main lamp | Separate compact light | Its own working battery and controls, accessible without the main lamp | i3E EOS for short backup tasks |
| Signaling without drawing electrical power | Whistle | Reachable while wearing the pack, with operation familiar to the user | Olight Titanium Emergency Whistle |
| Extending the main lamp's use | Matched energy supply | The exact approved battery or working charging path for that lamp | Select after calculating the trip's lighting demand |
This is the lighting portion of a backpacking gear checklist. Your shelter, water, food, navigation, clothing, and other essentials still need their own space and weight allowance. A larger lamp cannot compensate for an unsuitable shelter or a route that exceeds the group's ability.
Start with the longest stretch between dependable charging opportunities. That stretch might be one overnight, an entire five-night route, or the days before a staffed campground. An outlet shown on an old itinerary does not become available power until access, opening hours, and permission line up with your arrival.
Give each item a specific task. The headlamp handles movement and hands-on work. The small backup lets you find a battery, read a label, or organize gear if the headlamp stops working. A second full-size lamp makes sense when the backup must also support a substantial walk out. Decorative light belongs farther down the packing list.
The National Park Service organizes its Ten Essentials guidance around systems, including navigation, illumination, repair tools, food, water, and shelter. It recommends a headlamp for hands-free use and extra batteries. Use those categories to check coverage, then add the overnight equipment and personal supplies your route requires.
| Check | System | Pack and verify |
| [ ] | Navigation | Route information, map and compass skills, downloaded information where appropriate, and a backup to electronic navigation |
| [ ] | Sun protection | Suitable clothing, hat, sunglasses, and sunscreen |
| [ ] | Extra clothing | Insulation, rain protection, and dry layers for the conditions |
| [ ] | Illumination | Main headlamp, independent backup, matched power, and necessary cables |
| [ ] | First aid | Trip-specific supplies, personal medications, and access instructions |
| [ ] | Fire | Permitted fire-starting supplies and an understanding of local restrictions |
| [ ] | Repair tools | Equipment-specific repair materials and the tools that fit them |
| [ ] | Nutrition | Planned meals, appropriate storage, and extra food for a delay |
| [ ] | Hydration | Carrying capacity, known water opportunities, and appropriate treatment |
| [ ] | Emergency shelter | Suitable shelter and protection if the outing takes longer than planned |
For an overnight trip, check the sleeping bag or quilt, sleeping pad, shelter components, and food preparation equipment alongside these systems. Count poles, stakes, fuel where needed, and the small parts that make the larger items usable. Keep personal hygiene and waste supplies on the same final packing sheet rather than relying on memory.
Assign shared equipment to a named person. A group can share a stove or a suitably planned charging resource, but each hiker still needs access to light when separated by a short distance in camp. Confirm who has the water treatment, repair supplies, and emergency communications equipment before closing the packs.
Print the checklist and write the actual items beside each category. Include the number of nights, any expected early starts, and the longest section without resupply. A checked box should mean the item works, its power supply is ready, and its location in the pack is known. Buying the item is only one part of that check.
A backup should still work when the main light's immediate power source or charging connection fails. Two lamps that take turns using one battery leave you with the same single point of failure. A second lamp stored empty while its only cell sits in the first lamp also creates a difficult battery change in the dark.
Different power systems can reduce a shared charging failure. A rechargeable main lamp plus a small AAA-powered light gives you a second route to usable light if a cable is lost. The tradeoff is another cell size to manage. Two rechargeable lamps can also provide useful redundancy when each starts charged and retains enough independent reserve for its assigned job.
Think about storage failures as well as electrical ones. Keep the backup where you can reach it while wearing the pack, and protect it from accidental activation. Store spare cells in a suitable case with their terminals protected. Putting every light, every spare, and the only cable in one loose outer pocket makes a single dropped pouch much more consequential.
The backup's required capability depends on the route. Finding gear inside a tent needs less reach and hands-free support than descending a rocky trail after dark. For remote travel, plan the backup around the movement you might need to make, not just the smallest lamp available. Practice holding or wearing it before deciding it can perform that role.
Perun 3 for the main hands-free role
Perun 3 provides white and red lighting, a headband, and an MCC3 magnetic charging cable. Its published specifications identify a customized 3.6-volt, 5,000 mAh 21700 lithium-ion battery. That combination makes the actual charging cable and the specified battery part of the packing decision. A generic USB cable alone does not connect to the lamp's magnetic charging contacts.
Perun 3 in OD Green, shown with its front holder and overhead headband strap.
Olight lists a 120-lumen Medium mode with a 25-hour runtime and a 30-lumen Low mode with an 89-hour runtime. The 3,000-lumen Turbo listing uses staged output: 3,000, then 800, then 600 lumens over the published sequence. Use the mode that suits the task when budgeting time. The maximum output number is not a promise of continuous maximum brightness throughout an evening.
Fit matters over several nights. Adjust the headband with the hat or hood you expect to wear, confirm that the beam stays where you need it, and check that the controls remain accessible. When comparing a headlamp, include its worn support and charging needs as well as the lamp body. A comfortable setup encourages deliberate use of a suitable lower mode.
i3E EOS for a separate AAA-powered backup
i3E EOS uses one AAA battery and a twist-head control. Olight lists a 90-lumen output and a weight of 19.4 grams. Its simple power arrangement can provide a separate source for finding a cable, reading a battery label, or locating equipment when the main lamp is unavailable. Pack the battery type specified for the light, with any spare stored separately and protected.
i3E EOS in the Palm Breeze finish, shown with its key ring.
A keychain light should be reachable without emptying the pack. A familiar zippered pocket can be more useful than an elaborate attachment that leaves the light buried beneath clothing. Check that the selected carry position keeps the light secure and that operating the head does not drop small parts into loose ground or water.
Treat this compact format as a defined backup role. It has different controls and handling from a headlamp, and the listed output alone does not establish that it is suitable for every trail or every length of walk. If your emergency plan calls for sustained hands-free travel, choose and carry a backup arrangement that can actually provide that capability.
A whistle that does not consume the lighting reserve
The titanium whistle weighs a listed 7 grams and measures 2.09 inches long with a 0.35-inch diameter. It adds a non-electrical signaling tool without drawing from the phone or lamp battery. Keep it attached in an accessible place using a method appropriate to your clothing and pack, then confirm that you can reach and operate it.
Olight Titanium Emergency Whistle shown with its chain.
Agree on the group's communication and emergency plan before the trip. A whistle does not provide a location display, guaranteed reception, or contact with emergency services. Carry the communications equipment appropriate to the route, and leave trip details with someone who is not traveling with the group. The whistle fills a distinct role alongside those preparations.
Begin with hours, because nights alone hide large differences in use. A late camp setup, an early start, and a planned evening walk all add demand. Separate the time spent walking from the time spent eating or sorting equipment. Use a mode that gives adequate visibility for each task, then record the likely hours before selecting the amount of power to carry.
The following example assumes three hours of Medium-mode lighting per night and adds one extra three-hour evening for a delay. It compares those hours with Perun 3's published 25-hour Medium runtime. These are planning calculations using a product specification. They are not battery-percentage readings, energy measurements, or guarantees of performance in a particular environment.
| Planned nights | Scheduled use at 3 hours per night | With one additional 3-hour evening | Share of the listed 25-hour Medium runtime |
| 1 | 3 hours | 6 hours | 24% |
| 3 | 9 hours | 12 hours | 48% |
| 5 | 15 hours | 18 hours | 72% |
For one night, a full main battery may cover a modest evening schedule with substantial listed-time headroom. Still carry the independent backup. A charging cable can remain unnecessary weight on a short route if there is no usable source to connect it to, while a late arrival or an unusually long night could justify a different plan.
For three nights, write down where the nine planned hours occur. If several hours require a higher mode, do not substitute the Medium runtime for those hours. Either change the schedule, use a suitable lower setting for stationary tasks, or provide additional supported power. The extra evening is a deliberate allowance for delay, not permission to spend the reserve on optional lighting.
For five nights, the example consumes more of the published runtime. Weather, battery condition, and the chosen mode can change the practical margin. Add a dependable recharge or a correctly specified spare when your route needs it, and keep a shorter alternative available. A long runtime at Moonlight does not answer a question about walking at a brighter setting.
Keep planned use and emergency use separate on paper. Reserve enough capability to make the decisions your route may require if the itinerary slips. The correct margin depends on the terrain, distance to help, and the group's ability to stop safely. A fixed percentage copied from another trip cannot capture all of those conditions.
Write a charging path as a complete connection: source output, cable, device input. For Perun 3, that includes the MCC3 magnetic lead and a compatible supply at the lead's USB end. For a phone, it includes the phone's actual connector and a working cable. Confirm both paths with the exact equipment you will pack before deciding that one bank can support everything.
Read the power bank's instructions and account for competing uses. Phone navigation, photography, communications, and other electronics can draw from the same bank you expect to recharge a lamp. Name the priorities in advance. Reserve communications power where the route requires it, and keep optional charging from consuming the supply intended for essential devices.
Compare battery capacity in compatible terms. Milliamp-hours describe charge capacity, and the voltage matters when comparing different battery systems. A lamp battery and a power bank can both display a large mAh figure while storing different amounts of energy. Charging also involves losses, so a label-to-label mAh ratio is not a reliable count of complete lamp recharges.
AA supplies only belong with AA equipment
The Ostation Series AA/AAA Batteries Pack includes an AA selection listed as 2,100 mAh Ni-MH batteries. An AA pack belongs on the checklist only when the trip includes equipment that accepts the specified AA cell type. Check that equipment's instructions for chemistry and charging requirements before including the cells as a useful spare.
The selected official gallery shows the AA 2,100 mAh four-cell pack, separate from the page's AAA options.
These AA cells do not fit the AAA requirement of i3E EOS, and they do not replace Perun 3's customized 21700 battery or its magnetic charging path. If those are the only battery-powered lights you carry, adding an AA pack does not increase either light's reserve. Removing an unmatched spare saves weight without taking away a working power option.
Label the small storage cases by the device they support. Keep spent cells distinguishable from ready cells, protect terminals, and follow the cell and charger instructions. Recharging a battery successfully at home does not make it compatible with a different size or chemistry in the field. Avoid improvised adapters or charging arrangements in a backpacking power plan.
Weigh the equipment as you will carry it: installed batteries, headband, spare cells, cable, storage, and any required charging source. Olight lists Perun 3 at 150 grams and i3E EOS at 19.4 grams. Adding those published figures gives 169.4 grams, but that arithmetic is not a complete packed-kit measurement and does not establish what every accessory or spare weighs.
| Combination | Useful role | Redundancy question | Weight items to include |
| Headlamp plus keychain light | Main hands-free work plus brief independent backup tasks | Can the small light support the actual fallback task? | Both lights, batteries, headband, spare cells, cases, and any charging gear |
| Headlamp plus small handheld flashlight | Main work plus a more capable handheld fallback | Can you move safely with one hand occupied? | Complete handheld setup, carrying method, batteries, and any second cable |
| Two headlamps | Hands-free lighting remains available after a main-lamp failure | Does each lamp retain its own usable power? | Both complete headbands and lamps, separate reserves, and the charging system |
The lightest combination depends on the fallback job. A keychain light may be a sensible way to locate gear during a short interruption, while a second headlamp may justify its additional bulk for a route with a substantial dark exit. Compare equipment that can meet the same required task before treating a lower weight as an improvement.
Also compare the number of failure points you can manage. Matching chargers can simplify packing but make the one retained cable important. Different cell systems can improve independence while increasing sorting and resupply work. Keep the plan simple enough that every person who may need the gear understands which battery, connector, and control belongs to each device.
A weather rating on a lamp does not protect the rest of the charging system. Perun 3 is listed at IP68, but the bank, cables, battery cases, and open connections need their own protection and instructions. Organize charging in a sheltered, dry setting. Dry and inspect wet equipment according to its instructions before connecting it to a power source.
Use lower brightness when it gives adequate visibility for a stationary task. Perun 3 offers red modes as well as white modes; learn the controls before the trip rather than cycling through unfamiliar settings beside sleeping companions. Aim light at your task and away from faces. Switch to an appropriate white mode whenever you need to judge details that are difficult to see in red light.
Learn the exact model's transport-lock procedure if it has one, and confirm the packed light cannot switch on under pressure. Do not invent a universal button sequence for different lamps. Before departing, check the actual stored state by unpacking and operating the lamp, then returning it to its protected carrying arrangement.
Check the headband, mounting parts, and the way the lamp fits over weather layers. A replacement strap or small repair item can be useful if it matches the equipment and the consequences of failure justify carrying it. Keep loose components together in a designated pouch. Several nights of power will not restore hands-free use if the only mounting part is missing.
Pack the complete overnight system, route-appropriate food and water supplies, suitable clothing, navigation, repair and first-aid items, and a lighting plan for the actual nights away from reliable power. A seven-day trip may include six nights or seven, depending on the itinerary. Count the nights and expected dark travel directly instead of treating seven calendar days as seven identical evenings.
At the example's three hours per night, six nights require 18 scheduled hours. One extra three-hour evening brings that to 21 hours, or 84% of the listed 25-hour Medium runtime. Seven planned nights plus the same extra evening total 24 hours, or 96%. Those comparisons leave different amounts of listed-time headroom, even before other demands change the plan.
A longer route therefore needs an explicit decision about replenishment, a correctly specified spare, or a different lighting schedule. Establish where replenishment can happen and what happens if it fails. Reassess food, water, weather, and travel time at the same point. Reaching a charging opportunity does not make the rest of the itinerary workable automatically.
Spread critical functions across the group thoughtfully. Each person should know where their light is and how to use it, even if some power equipment is shared. Keep a plan for an early stop or a shorter route if the remaining supply cannot support the next section. Carrying more optional camp light is a poor substitute for resolving that gap.
Bring the equipment that keeps you oriented, sheltered, appropriately clothed, supplied with food and water, and able to respond to foreseeable problems on your route. Add the sleeping system and other overnight supplies required by the conditions. For lighting, the practical starting point is a main hands-free light, an independently powered backup, and a complete plan for usable energy.
Choose the kit around the least experienced person who must use it. Show the backup's controls, the location of spare cells, and the intended charging connection before leaving home. A neatly organized pouch that only one person can identify is less useful when another hiker needs to retrieve it during a problem.
Fit and access deserve the same attention as specifications. Check the loaded pack with the weight distributed as planned, place frequently needed items where they are reachable, and keep essential equipment protected. Remove items that duplicate an optional function before removing the independent reserve that makes an essential function available after a failure.
Think in ten systems: navigation, sun protection, extra clothing, illumination, first aid, fire supplies where appropriate and permitted, repair tools, nutrition, hydration, and emergency shelter. A system may require several items. The illumination box, for example, can include the lamp, its headband, a backup light, spare power, and the cable that makes a recharge possible.
These categories are a completeness check, not a fixed ten-object limit. A cold or wet overnight can require more layers and shelter than a warm short outing. Your route may also call for permits, food storage, communications equipment, or other specific supplies. Read destination requirements and adapt the packing sheet to the actual trip.
Review the categories once by function and once by access. Confirm that the items are packed, then confirm that the light, whistle, rain layer, and other time-sensitive supplies can be reached when needed. Leave a clear trip plan with a trusted contact. The final check should describe a usable system rather than a collection of unchecked specifications.
The NPS Hike Smart guidance recommends checking weather and park alerts, leaving a trip plan, preparing an alternative, and setting a turnaround time. Apply those principles to your lighting plan. A delayed day can consume both time and power, particularly when camp setup moves past sunset or the next morning begins before daylight.
Define the decision points before the trip. Examples include a missed charging stop, a light that will not reliably operate, a wet or damaged charging connection, or insufficient usable reserve for the next section. Reassess while you still have a manageable alternative. Do not wait until every device is nearly empty to decide how far the group can continue.
Check resupply details at the destination rather than assuming a standard battery size will be available. Store hours, stock, access, and whether a parcel can be collected all matter. If a required item is uncertain, arrange a dependable alternative or shorten the section. An unconfirmed shop stop should not carry the same weight in the plan as a charged battery already in the pack.
Review the remaining reserve at a consistent time in camp. Reduce optional use when appropriate, check whether the next day's schedule still fits daylight, and discuss a changed route with the group. Keep safety decisions tied to the whole situation, including weather and physical condition. A functioning flashlight does not make a closed trail, dangerous crossing, or unsuitable storm forecast acceptable.
