For a backpacking kit built around tape, cord, and small adjustments, choose scissors first and add pliers only for a specific repair. NexTool Micro Sailor S0 suits a light scissors-focused kit; Mini Flagship F12 adds compact pliers and a locking blade. OKNIFE LK suits hikers who specifically need a folding knife with integrated light.
TL;DR: Match the tool to your equipment before comparing function counts. Check the complete packed weight, the fit of each driver, and how comfortably you can use the cutting tools. Keep repair materials with the tool, protect sharp edges, and maintain a separate plan for hands-free lighting. A small, well-matched kit is easier to justify than several overlapping tools.
| Your main requirement | Starting choice | Published tool weight | Decision that matters |
| Cut tape, cord, and packaging; make small adjustments | NexTool Micro Sailor Scissors S0 | 35 g | Choose scissors and small implements when pliers are unnecessary |
| Add light gripping jobs and a locking knife blade | NexTool Mini Flagship F12 | 79 g | The extra 44 g over S0 should cover a real equipment need |
| Carry a folding knife with integrated illumination | OKNIFE LK | 86 g | Choose the knife-and-light role deliberately; it does not supply pliers or scissors |
| Repair equipment requiring greater leverage or a specific bit | A suitably sized dedicated tool or larger multitool | Check the exact model | Confirm fit and permitted use before accepting the extra mass |
- 1. What is a good multitool for hikers?
- 2. Build the repair list before the shopping list
- 3. Three compact tools with different jobs
- 4. Scissors, blades, and the cuts in your kit
- 5. Pliers and drivers need an exact job
- 6. Count the complete kit in grams
- 7. A practical three-day use record
- 8. Carry, rain, and maintenance
- 9. Locking blades and air travel
- 10. Are there better multitools than Leatherman?
- 11. Which repair parts belong with a backpacking multitool?
- 12. Frequently asked questions
A good hiking multitool covers the small repairs your actual gear can require, fits the relevant parts, and stays accessible in its protected carry position. Start with scissors if you mainly cut repair tape and cord. Add compact pliers when a known gripping task justifies them. Choose a larger tool when a specific repair needs its size or leverage.
The National Park Service includes tools and repair materials in its Ten Essentials guidance. Its repair-kit examples include tape, a knife, scissors, and a multitool, with additional tools selected for the activity. That is a useful planning principle: the equipment and trip determine the repair kit. A longer implement list does not automatically improve it.
Lay out the gear that will travel together. Look at the pack, shelter, cooking equipment, footwear, and any equipment with small fasteners. Identify which issues you could reasonably address in the field. A missing replaceable buckle calls for the matching spare. A loose screw calls for the correct driver. A long tool list cannot supply an absent replacement part.
Keep a distinction between inconvenience and a trip-ending failure. A ragged piece of tape can wait until you reach a stable place to work. Damaged equipment carrying an important load deserves a more cautious decision. Consider whether an appropriate spare, a different route, or returning to the trailhead is the better response. Buying more implements does not turn every repair into a sensible field project.
Write a short list of likely jobs in ordinary language. “Trim a patch” is useful. “Have survival capability” is too broad to help you select a tool. Beside each job, record the material, required implement, and any consumable or replacement part. This turns the shopping question into a set of checks you can perform before departure.
For a damaged pack buckle, first establish the buckle's design and whether the manufacturer offers a compatible field replacement. Some replacements can be fitted without sewing; other assemblies require work better done at home. Carrying pliers does not establish that the buckle is serviceable. Check the replacement and its instructions against the actual webbing and attachment before packing it.
For repair tape, think about the backing as well as the adhesive. A tool can feel comfortable while cutting paper yet handle sticky tape awkwardly. Prepare manageable pieces where appropriate and keep the remaining material protected from grit. Avoid cutting directly against the pack or shelter fabric you are trying to preserve. A stable work surface gives you more control than a hurried cut beside a tensioned strap.
For footwear and cord, separate replacement from repair. A suitable spare lace may solve the immediate problem more simply than modifying the old one. Keep enough relevant material for the job, and know how the equipment is supposed to be secured. Avoid adding specialized implements for an imagined repair while leaving the basic replacement at home.
Personal-care supplies deserve their own place. Scissors may help prepare the backing of a dressing or trim repair material away from the body. Keep dirty repair tools apart from clean first-aid supplies, and use the medical instructions supplied with those materials. A backpacking tool comparison is not a reason to improvise treatment with a knife.
NexTool Mini Flagship F12: compact pliers with scissors and a blade
The NexTool Mini Flagship F12 is listed at 79 g. Its official description identifies reinforced pliers, NexScissors 2.0, and a locking main blade made from 8Cr14MoV steel. The combination gives it a broader repair role than a scissors-focused tool when your equipment includes a suitable light gripping task.
NexTool Mini Flagship F12 shown with its plier jaws open.
Choose F12 when you can name a job for the pliers as well as the cutting tools. Check that its jaws can reach the relevant part without obstructing the work. Small pliers can be useful around small components, but fit and the manufacturer's permitted use matter more than the presence of a plier icon on the packaging.
The locking blade adds another selection and carry consideration. Learn its locking and closing procedure from the exact instructions before the trip. Keep fingers clear of moving joints and cutting edges, and put the tool away safely between jobs. A lock helps retain the blade in its intended working position; it does not make an awkward grip or excessive force a good choice.
NexTool Micro Sailor S0: a scissors-focused light kit
The NexTool Micro Sailor Scissors S0 is listed at 35 g. Its official description centers on serrated scissors and lists additional small implements, including tweezers, a file, screwdrivers, and a bottle opener. It is the starting choice here when cutting small materials matters more than carrying pliers or a separate knife blade.
NexTool Micro Sailor S0 shown with its scissors and additional implements open.
The published difference between F12 and S0 is 44 g, calculated as 79 minus 35. Decide what that difference buys for your trip. If you have identified a suitable gripping task, F12's pliers may justify the added mass. If your repair kit is based on tape, cord, and a few small adjustments, S0 may cover the work with fewer overlapping implements.
Check the handle space and cutting position with the materials you intend to carry. A compact tool still needs enough room for your fingers. Gloves, cold hands, and a crowded pouch can change how conveniently you retrieve and hold it. Make that assessment in a calm setting before deciding that its small packed size is an advantage for you.
OKNIFE LK: choose the knife-and-light role separately
The OKNIFE LK combines a folding knife with a USB-C rechargeable flashlight. Its official description lists an 86 g weight and a 400-lumen white main light. This is a different configuration from F12 or S0: select it for the knife-and-light combination rather than expecting the repair functions of a plier or scissors multitool.
OKNIFE LK shown folded, with the light and controls facing forward.
An integrated light can help illuminate a nearby task, but plan where the light must point while both hands work. A separate headlamp can illuminate the repair area without tying the light's position to the tool in your hand. Check illumination with the actual equipment arrangement, especially when the repair needs one hand to hold the material steady.
Include charging equipment in the LK packing decision. A USB-C port tells you which connection the product uses; your trip still needs a suitable cable and available power. Keep the knife's safe carry and operating procedure distinct from the light's controls. Choose an arrangement you can manage without opening an implement merely to obtain useful illumination.
Scissors often suit a kit built around small, controlled cuts in tape, fabric, and cord. A knife has a different cutting action and may suit other tasks. The right question is which materials you actually expect to cut and how securely you can hold them. There is no need to claim that every backpacker uses scissors more often than a blade.
Start with repair tape. Check whether the scissors can reach the edge cleanly and whether adhesive builds up on the cutting surfaces. A satisfactory cut should produce a usable piece without forcing the handles or pulling the material out of position. If the tape behaves poorly, consider preparing suitable pieces at home rather than assuming a larger cutting tool is the solution.
Cord introduces another set of conditions. The diameter, construction, and tension matter. Practice only on loose sample material appropriate to the tool. Keep the cutting task separate from any cord supporting equipment or securing a load. A tool that handles one thin sample does not establish performance across every rope or line in a packing list.
For thin line, visibility and control can matter as much as size. Work over a surface where the cut end and small offcuts remain visible. Gather scraps before they disappear into grass or campsite soil. Record whether the tool gave you a clean, manageable result with the line you use, rather than turning one convenient cut into a broad performance rating.
Keep food preparation separate from dirty repair work. Adhesive, grit, and lubricant can remain on a tool after it is folded away. Decide whether the kit needs a separate food-safe utensil, and clean the equipment according to its instructions. A multipurpose design combines implements; it does not remove the need to keep working surfaces appropriate for the task.
Before choosing pliers, identify the part you intend to grip. Check access, jaw shape, and the space around the component. A small tool may reach a narrow area conveniently while offering less comfortable hand space for a difficult task. A larger handle may improve grip but add mass and bulk. Choose based on the actual equipment rather than assuming either size is universally better.
Small drivers deserve an equally careful fit check. Match the tip to the fastener and the permitted adjustment in the equipment instructions. A tip that is close enough to enter a screw head may still be a poor fit under pressure. If the gear needs a specific bit, retaining that bit can be more useful than carrying several integrated drivers that do not match.
Keep field adjustments within the equipment maker's instructions. Some fasteners have specified torque, thread treatment, or service procedures. Others hold an assembly that should not be opened during a trip. Make a list of permitted adjustments while planning the kit, and keep specialized service work out of the routine campsite repair plan.
For cooking equipment, identify the correct maintenance procedure before departure. Let equipment reach the safe state specified by its maker before handling or adjusting it. Carry the required service accessory only when the instructions support field maintenance. A general multitool should not encourage improvising on a hot, pressurized, or fuel-containing assembly.
Grip strength also changes with the working position. Try holding the item and tool at a table where you can see both. Notice whether another implement presses into your palm or whether the tool twists as you apply ordinary hand pressure. If the task demands bracing against your body or forcing the joint, reconsider the tool and the repair rather than carrying that problem into the backcountry.
Compare the load that actually enters the backpack. Published tool weights provide a useful starting point, but your pouch, protective holder, spare parts, tape, bits, and charging cable contribute to the finished kit. Weigh the assembled arrangement in its travel condition. Use the same definition for every option so a bare tool is not compared with a fully packed alternative.
The three listed product weights help frame a decision without pretending the functions are equivalent. S0 is 35 g, F12 is 79 g, and LK is 86 g. F12 adds 44 g over S0. LK's listed mass is 7 g above F12, but it fills a different role. A small numerical difference cannot answer whether you need scissors, pliers, or integrated light.
Carrying both F12 and S0 produces a calculated listed-tool subtotal of 114 g before their carry accessories. That may be justified if two people need separate cutting tools or the second tool solves an identified problem. Otherwise, examine the repeated functions. Removing an unnecessary second tool can save more weight than debating a few grams between two individual models.
Use a scale on a stable surface and check that it reads zero with the weighing container in place. Record its unit and resolution. Repeat a reading after lifting and replacing the kit if you want to confirm that your setup is stable. Keep the original readings in your own record instead of rounding different configurations in ways that favor a preferred choice.
| Configuration to weigh | Include in the reading | Add a note about |
| Scissors-focused kit | Tool, pouch, tape, cord, and relevant spares | Cutting tasks covered and any omitted gripping task |
| Compact plier kit | Tool, holder, matching repair parts, and any necessary bit | Exact component requiring the pliers |
| Knife-and-light kit | Tool, safe carry arrangement, cable, and repair materials | Separate lighting and scissors needs |
| Larger tool or dedicated repair set | Complete carried tool set and accessories | The specific repair that earns its added mass |
A short use record can improve the next kit more than another feature comparison. During an appropriate trip, write down each job, the implement used, and whether the result was useful. Include work completed without the multitool, such as fitting a ready-made replacement part. That shows which functions solved a problem and which repairs depended on supplies instead.
Separate planned checks from unexpected failures. Opening packaging every evening is a different reason to carry scissors from a single unusual equipment failure. Both can matter, but they deserve different interpretations. Record what happened rather than converting a small personal sample into a claim about what backpackers generally use most often.
Note the working conditions as well as the tool. Daylight at a picnic table, rain beside a shelter, and a cramped repair under a headlamp are different situations. Record whether you had enough light, a stable surface, and comfortable access to the implement. These observations may lead you to change the pouch position or lighting arrangement instead of buying another tool.
For a three-day itinerary, review the notes after each day while the details are clear. Record an unused implement as unused during that trip, not useless in every setting. A longer route, different shelter, or another season may change the repair needs. Compare similar outings before removing equipment whose value depends on a less frequent but important failure.
Back at home, group the entries by task. Keep cutting, gripping, fastener adjustment, and other uses separate. Add the time or inconvenience involved in retrieving the tool if that affected the job. The resulting record gives you a specific reason to keep a feature, replace a poor-fitting implement, or reduce duplicated equipment on the next trip.
Choose a protected location you can reach without emptying the main pack. A small pouch can keep the tool with the repair materials it serves. Check how the pouch closes and whether a sharp edge or protruding part can contact nearby fabric. A clip or keyring may help retention, but it should suit the actual carry location and the product instructions.
Keep the kit organized by use. Store clean first-aid materials apart from adhesive-covered repair tools. Keep loose small parts contained so a missing fastener does not disappear into the pouch. After each job, account for the tool and any detached component before moving on. This is especially useful when the work takes place on uneven ground.
Rain and sweat make post-trip care part of the packing routine. Follow the exact product's cleaning, drying, and lubrication instructions. Remove visible grit and adhesive by an appropriate method, and let the tool dry before prolonged closed storage. Stainless steel still deserves care; a material name should not be treated as a promise that every joint can remain wet indefinitely.
Inspect moving parts and cutting surfaces before the next departure. Look for damage, unexpected resistance, or a change in lock behavior. Stop using a tool with a questionable mechanism and resolve the issue through its instructions or service support. Do that at home while another tool can be selected, rather than discovering the concern during a needed repair.
Check lighting alongside the repair kit. A small pocket flashlight can help locate dropped parts or inspect a pouch, while hands-free light may suit sustained work. Keep the chosen light accessible and confirm its power arrangement before departure. Avoid pointing a bright beam toward another person who is trying to help with a close task.
A blade lock and an air-travel decision answer different questions. Choose a locking mechanism around the tool's intended operation and your ability to handle it safely. For a flight, identify every implement in the complete tool, review the applicable screening rules, and plan its baggage location before the airport. A product description using “travel-ready” is not an individual screening decision.
F12 includes a knife blade, and LK is a folding knife with integrated light. S0 has a scissors-focused, blade-free design, but its complete configuration still needs to satisfy the rules for the actual trip. Do not transfer a statement about scissors to a knife-equipped tool. Keep any protective packaging suitable for the item and the baggage location.
For an itinerary crossing jurisdictions, check the actual destination, transit points, and land manager's conditions. Trail access and knife-carry rules can differ from airport screening requirements. Identify the exact tool and route when seeking an answer, and keep it with the trip record. Resolve a restriction before choosing which tool to take.
Pack the return trip deliberately. A tool moved into a jacket pocket during the hike can remain there when the backpack is reorganized for the flight. Check pockets, the repair pouch, and borrowed group equipment while the contents are visible. Make the verified arrangement easy to recreate rather than relying on memory at the checkpoint.
For a particular backpacking task, a tool with a better fit or lower unnecessary weight can be the better choice regardless of brand. Compare exact models and the functions you will use. A scissors-focused tool can suit a tape-and-cord repair kit, while an identified gripping or fastener task may justify a different design.
Start by matching the same role. Comparing a small scissors tool with a full-size plier tool by function count alone obscures their different purposes. Compare the required cutting action, driver fit, usable grip, carry arrangement, and complete packed weight. Then decide whether any extra implement covers a plausible repair on your equipment.
The three tools discussed here offer different starting points rather than a universal brand ranking. S0 prioritizes a light scissors arrangement, F12 combines compact pliers and cutting tools, and LK combines a knife with light. Check the exact alternative you own against the same job list before buying something to replace it.
Carry repair materials that fit your actual equipment: an appropriate replacement buckle, suitable patch material, a spare lace, or the specified small fastener can matter more than another implement. Choose the relevant parts from your gear's repair instructions. Keep them with the tool so a usable driver or pair of scissors has something useful to work with.
Check the replacement against the equipment before departure. A buckle with the wrong attachment or webbing size adds weight without resolving the failure. A patch needs to suit the material and application instructions. Weigh the selected parts with the complete tool kit, then remove duplicates that serve the same job. This gives each added gram a specific purpose on the trip.
