Welcome to this blog post where we introduce three remarkable pocket EDC flashlights- the Warrior Mini 3, the Baton 3 Pro and the Baton 3 Pro Max. These high-performance lighting tools have gained popularity among outdoor enthusiasts, camping lovers, and security professionals alike. If you love outdoor activities, then these pocket EDC flashlights will be your perfect companions. Now, follow me to explore their features!
Warrior Mini 3 VS Baton 3 Pro VS Baton 3 Pro Max
| Warrior Mini 3 | Baton 3 Pro | Baton 3 Pro Max | |
| Beam Distance | 787 ft (240 m) | 574 ft (175 m) | 475 ft (145 m) |
| Max Performance | 1,750 lumens | 1,500 lumens | 2,500 lumens |
| Max Run-time | 100 days | 120 days | 60 days |
| Max Light Intensity | 14,400 candela | 7,900 candela | CW/NW: 5,295 candela WW: 4,482 candela |
| Waterproof | IPX8 | IPX8 | IPX8 |
| Weight (Including Battery) | 4.3 oz | 3.63 oz | Orange/Black/OD Green: 5.22 oz Desert Tan: 4.73 oz |
| Size (in) | 4.37*0.91*0.91 | 3.99*0.91*0.91 | 4.49*1.02*1.02 |
| Battery Capacity | 3500mAh 3.6V | 3200mAh 3.6V | 5000mAh 3.6V |
| Rechargeable | Yes | Yes | Yes |
Warrior Mini 3 Portable Tactical Flashlight
Powerful Output
With a maximum output of 1,750 lumens, it provides an incredibly bright illumination, ensuring clear visibility even in the darkest environments. Furthermore, it offers a maximum beam distance of 240 meters, allowing you to effortlessly light up distant targets. And it offers an impressive runtime of up to 100 days, ensuring prolonged and dependable illumination. Despite its compact size of only 4.37 inches, the Warrior Mini 3 boasts unparalleled performance.
Proximity Sensor
The pre-activated proximity sensor prevents accidental switching to high mode when obstructed at close range, avoiding unnecessary inconveniences. However, the sensor doesn't interfere with the intended output even when the flashlight comes in close contact with objects such as raindrops or window glass. This intelligent design ensures reliable performance in real-world usage scenarios.
Nano Molding Technology
This technology makes cleaning metal dust around the tail switch a breeze. As most users know, prolonged flashlight usage tends to accumulate metal dust around the switch, making cleaning difficult. Thanks to nano molding technology, the Warrior Mini 3 takes user convenience to the next level. A gentle wipe easily removes the metal dust, keeping the flashlight looking and performing like new.
Bigger and Tougher Side Switch
The larger and more durable side switch is also a highlight of the Warrior Mini 3. It features an expanded and wear-resistant metal side switch, providing enhanced usability and comfort. Whether you're wearing gloves or have wet fingers, operating the switch is effortless. This design not only improves the user experience but also adds durability to the flashlight, making it a reliable companion for the long haul.
Baton 3 Pro Rechargeable Flashlight
Powerful Output
The Baton 3 Pro boasts a maximum brightness of 1,500 lumens, with a beam distance of up to 175 meters. It can continuously operate for an impressive 120 days, so you never have to worry about running out of battery power. Whether you're camping, hiking, mountaineering, or embarking on a nighttime adventure, the Baton 3 Pro will deliver incredibly bright light, helping you conquer any challenge with ease.
Two Color Temperature Options
The Baton 3 Pro offers two color temperature options: cool white light and neutral white light. This allows you to choose the light that suits your preference or the specific scenario you're in. Cool white light is ideal for situations that require strong illumination, such as outdoor adventures or nighttime work. And neutral white light closely resembles natural daylight and offers a softer and more natural glow. It is suitable for scenarios where color accuracy is important, such as indoor reading, artwork, or photography.
Larger Side Switch
When it comes to design, the Baton 3 Pro features a recessed side switch. This innovation ensures that operating the flashlight is effortless, precise, and intuitive.By being slightly recessed, it minimizes the risk of accidental activation, even in demanding and unpredictable outdoor conditions. This means you can confidently carry the flashlight without worrying about it unexpectedly turning on and draining precious battery life.
Convenient to Store
The Baton 3 Pro also comes with an L-shaped pocket clip that can be attached to any surface, allowing for easy storage after use. Whether it's at home, inside your car, or inside a tent, you can conveniently store the Baton 3 Pro, always ready for your next adventure. Learn more!
Baton 3 Pro Max Powerful EDC Flashlight
Powerful Output
Featuring a maximum output of 2,500 lumens, the Baton 3 Pro Max boasts the raw power necessary to illuminate even the darkest corners. Equipped with a long-lasting 5000mAh battery, the Baton 3 Pro Max offers an exceptional runtime of up to 60 days. Whether you're engaged in lengthy workdays or embarking on extended backcountry adventures, this flashlight will serve as your reliable companion, never leaving you in the dark.
Proximity Sensor
The Baton 3 Pro Max takes safety seriously. Its upgraded proximity sensor has been meticulously optimized to strike the perfect balance between sensitivity and functionality. This innovative feature ensures your protection without compromising the integrity of the light's beam pattern, providing peace of mind during your nighttime ventures.
Shake To Wake
No more fumbling around in the dark to check battery levels. With the Baton 3 Pro Max's shake to awake battery indicator, simply give it a quick shake to activate the convenient battery indicator. This eliminates the need to turn on the flashlight, making it effortless to determine the remaining charge. Additionally, the illuminated side switch makes locating and operating the flashlight a breeze, even in pitch-black conditions.
Versatile Magnetic Tail
Recharge the Baton 3 Pro Max effortlessly using the included MCC3 USB magnetic charging cable. With a charge time of only 4 hours, you'll be ready for your next adventure in no time. Plus, the multifunctional magnetic tail allows you to conveniently attach the flashlight to the metal L-shape stand, ensuring easy accessibility and storage after every use.
These three pocket EDC flashlights are absolute gems in their respective fields. Whether you need long-distance illumination, protection against accidental switching, effortless cleaning of metal dust, a choice between different color temperatures, convenient storage options, or outstanding performance, these pocket EDC flashlights have got you covered. Whether you're camping, hiking, mountaineering, or engaging in nighttime activities, these pocket EDC flashlights will be your most reliable companions. So go ahead and click here to choose one of them today to light up your future and illuminate every adventure you embark upon!
