In the realm of firearm accessories, the search for the perfect rail mounted light has always been a quest for balance - a balance between flood and spot, compatibility, ease of use, durability, and affordability. Olight has consistently heeded the voices of OFans, relentlessly pushing the boundaries. Today, we're thrilled to introduce you to the PL-Turbo, a rail mounted tactical light that doesn't just raise the bar; it achieves that balance. This article will provide an in-depth look at the PL-Turbo tactical light and how it achieves these balances.
Flood Light and Spot Light Combination
Before introducing this feature, it's essential to revisit the two weapon lights that paved the way for this groundbreaking innovation - the Valkyrie Turbo and the PL-3. The Valkyrie Turbo boasts an impressive throw distance but falls short in lumens, leaving a gap in flood coverage. Meanwhile, the PL-3 offers incredible brightness but lacks in beam distance.
Enter the PL Turbo, designed to bridge this gap. Thanks to custom high-tech LED technology and a deeper reflector, the PL Turbo delivers both incredible 800-lumen ample floodlight and 515-meter intense spotlight simultaneously with an impressive 66,300 candela intensity. This extraordinary floodlight and spotlight combination empowers users to illuminate distant targets while maintaining clear visibility of their immediate surroundings. Its remarkable 66,300 candela intensity ensures that you not only see more but also see it vividly, with a level of clarity that's unparalleled.
Compatability at Its Best
Compatibility is often a concern when choosing firearm accessories. However, the PL Turbo addresses this issue head-on. The PL-Turbo rail mounted light comes equipped with Olight's revolutionary adjustable sliding block rail mount. This innovative feature allows users to fine-tune the light's position using one of three sliding positions, ensuring an optimal fit for your specific firearm setup.
With the PL-Turbo, versatility is the name of the game. It includes two rail adapters—one for 1913 Picatinny (MIL-STD-1913) rail mounts and one for Glock rails. This means you have up to six mounting options at your disposal, making the PL-Turbo rail mounted light compatible with a wider range of both short and long firearm builds. We have collected various gun models compatible with the PL Turbo, including both long guns and handguns, totaling up to 100 different models! However, the list of compatible firearms for the PL Turbo is certainly not limited to these.
Once the ideal position and mounting are identified, the PL-Turbo's locking screw mechanism ensures a rock-solid fit that will not budge, even under the most extreme usage scenarios. This level of stability is crucial in critical situations where every fraction of a second counts.
Unparalleled Power Capacity
Powered by two Olight 1600mAh high-capacity CR123A batteries, the PL-Turbo tactical light provides up to 2 hours of runtime. It can maintain 4 minutes in 800 lumen before stepping down to 400 lumens due to heat management considerations. It is also compatible with CR123A batteries that can be found and purchased almost anywhere. However, we recommend the use of Olight, Panasonic, Sanyo, Energizer CR123A or Duracell 123, or Olight Rechargeable RCR123A. By having a few spare CR123A batteries on hand, you're making a smart choice for preparedness.
Built to Last
The PL-Turbo rail mounted tactical light features a secure captive screw locking mechanism, designed for extreme stability, enduring a rigorous 30,000 rounds of simulated recoil testing without a single failure. Crafted with rugged durability in mind, the PL Turbo tactical light features an aluminum body that undergoes a rigorous hard anodization process. This treatment not only enhances its resistance to scratches but also fortifies it against corrosion, ensuring that your investment will stand the test of time. Moreover, the impact-resistant tempered glass lens adds an extra layer of toughness, ensuring that your light remains operational in the harshest of environments.
Swift and Precise Control
The PL Turbo rail mounted tactical light is designed with the user in mind. Its one-brightness level design simplifies operation, making it accessible for users of all skill levels. The intuitive, ambidextrous switches are equipped with a dual tactical tail switch, providing quick access to Constant-On, Momentary-On, and Strobe modes.
Holsters Crafted for Perfection
When it comes to carrying your firearm, nothing is more crucial than having a reliable and comfortable holster by your side. Finding the right tactical light holster for your firearm can be a challenging task, but we've made it easier than ever. Visit at us.obuy.com, where you can explore the extensive range of holsters with an exclusive 10% code. ( The code is valid from 08:00 PM 9/17 to 11:59 PM 9/23 EDT). Whether you prefer inside-the-waistband (IWB), or outside-the-waistband (OWB) carry, Obuy has holsters to suit your preferred carrying style. All holsters are also compatible with PL-3/PL-3R rail-mounted lights.
Typical PL-Turbo Tactical Light Usage Scenarios
The PL-Turbo rail-mounted tactical light by Olight is your trusted partner in a variety of usage scenarios. Its versatile features cater to different needs, ensuring you have the right tool when and where you need it most.
🔦Home Defense: Safeguarding Your Sanctuary🏡
When it comes to securing your home, the PL-Turbo proves its worth:
The PL-Turbo's impressive 800-lumen floodlight and 515-meter spotlight simultaneously provide unparalleled visibility both indoors and outdoors.
In a crisis, the ability to identify threats from a distance while illuminating your immediate surroundings is invaluable, giving you the upper hand in critical moments.
Its compatibility with a range of firearms ensures you can mount it securely for rapid response, making it an essential tool for home defense.
🔦Search and Rescue: Guiding the Way to Safety🆘
During search and rescue missions, the PL-Turbo stands out as a beacon of hope:
The PL-Turbo's intense spotlight, with its 66,300 candela intensity, pierces through darkness and adverse conditions, aiding in the location of missing persons or critical items.
Its rugged build, capable of enduring simulated recoil testing, ensures reliability in high-pressure situations, providing peace of mind to rescuers.
Whether you're navigating dense forests, treacherous terrain, or urban environments, the PL-Turbo's adaptability ensures it's always up to the task.
🔦Law Enforcement: Enhancing Tactical Operations👮
For law enforcement professionals, the PL-Turbo is an indispensable tool:
The PL-Turbo's powerful combination of floodlight and spotlight is a force multiplier, aiding in target acquisition and situational awareness.
Its compatibility with standard Glock rails and Picatinny mounts offers versatility for various firearms, ensuring it's ready for duty.
With an aluminum body that can withstand rigorous testing and a secure mounting mechanism, the PL-Turbo can handle the demands of law enforcement operations.
Amazing Offers on O-Fan Day Sale
Are you ready for some incredible deals? The O-Fan Day Flash Sale is here, and it's your chance to enjoy up to a whopping 40% OFF on PL-Turbo tactical light. Add just $1, you can get Otacle Doughnut multi tool.
The PL-Turbo isn't just a rail mounted tactical light; it's a testament to Olight's commitment to listening to user feedback and delivering a weapon-mounted light that exceeds expectations. With its revolutionary floodlight and spotlight combination, unmatched adaptability, and attention to detail, the PL-Turbo is the rail mounted light of choice for those who demand the very best.
With the PL-Turbo by your side, you're not just illuminating the dark; you're illuminating the future of firearm lighting technology. Thank you for joining us on this journey to better illumination.>>Act Now
