In the ever-evolving world of flashlights, the Olight Seeker Pro line stands out like a beacon of brilliance, quite literally. They are the embodiment of "Eagle's Eye, Wolf's Sight, Seeker Light!" This catchy phrase captures the essence of what these flashlights are all about. They provide the keen vision of an eagle, the sharp instincts of a wolf, and the unmatched brightness of the Seeker Light. Now, the Olight Seeker Pro line bright flashlight has scaled new heights with the introduction of the Seeker 4 Pro. This high power flashlight represents the pinnacle of excellence, boasting an astounding maximum output of 4600 lumens and a maximum throw of 260 meters – a remarkable 400 lumen brighter than its predecessor, the Seeker 3 Pro. Let's embark on a journey to explore the brilliance of this new-generation flashlight.
A Blaze of Illumination
The Seeker 4 Pro high power flashlight is a force to be reckoned with, casting an intense burst of light for 2.5 minutes, showcasing its formidable 4600 lumens. It is bright enough to light up a hundred square meter yard and make it look like daytime. What makes this achievement even more impressive is that it maintains the same up to 15-day runtime as its predecessor. After this initial burst, it gracefully steps down to 1200 lumens for an impressive 122 minutes of continuous lighting. Finally, it settles at 600 lumens, providing an additional 35 minutes of runtime. This remarkable lighting progression ensures that you're never left in the dark, no matter the situation.
One of the standout features of the Seeker 4 Pro is its staggering light intensity of 16,895 candela, coupled with an extended throw distance of approximately 853 feet. This high power flashlight pierces through darkness like never before, revealing details and distances you never thought possible. Whether you're navigating the great outdoors or illuminating your path in a blackout, the Seeker 4 Pro high power flashlight delivers unparalleled clarity.
Despite its immense power, the Seeker 4 Pro maintains a compact and portable design. Standing at just 5.24 inches in length, with a head diameter of 1.38 inches, a body diameter of 1.10 inches, and weighing only 7.23 ounces, it's an effortlessly wieldable tool that fits snugly in your hand or pocket.
Type-C or Magnetic Charging
The Seeker 4 Pro high power flashlight supports two flexible charging methods to ensure you stay powered up and prepared for any situation. You can charge your Seeker 4 Pro with Type-C charging, utilizing the provided holster, or the MCC3 2A magnetic charging cable. With these adaptable charging options at your disposal, recharging the flashlight becomes a hassle-free task, no matter where or when you need it. This ensures the Seeker 4 Pro remains a dependable companion throughout your adventures.
Multi-Functional Holster
Speaking of convenience, the Seeker 4 Pro's holster is a game-changer in itself. It consists of two parts: the bracket and the holster. You can mount it on a wall, a car, a strap, or a belt for easy access and also dock it for charging, ensuring that your Seeker 4 Pro high power flashlight is always ready to shine when you need it most.
But what truly sets this holster apart is its industry-leading US patent-pending feature. It locks the powered-off Seeker 4 Pro securely, preventing accidental activation. This ensures that your flashlight remains dormant until you intentionally release it from the holster, providing peace of mind and preventing any unwarranted mispresses.
But what if you need to use your Seeker 4 Pro flashlight while it's in the holster? Olight has thought of that too. With a simple 90-degree right rotation of the switch, the light is unlocked and ready for action, just as if you had pulled it directly from the holster. This intuitive design enhancement brings you a flexible experience.
For those who crave hands-free convenience, a horizontal holster can be purchased separately. It's time to take multitasking to the next level. You can securely attach the horizontal to your belt or waistband, ensuring your flashlight is always within reach. This hands-free setup lets you concentrate on your tasks with reliable lighting close at hand.
Olight has thought of everything, including safety. To prevent the possibility of burning clothing while using the horizontal holster option on your belt, the holster would limit the flashlight's brightness to a safe 600 lumens automatically. This thoughtful design ensures a safe user experience by preventing the flashlight from becoming too hot while on your belt, freeing your hands for other tasks.
Ergonomics Redefined
Olight has prioritized user comfort with the Seeker 4 Pro's design. Building on the Seeker 3 Pro's silicone surface, the Seeker 4 Pro takes it up a notch. It features a full wrap-around grip for an even more comfortable hold. Holding this flashlight for extended periods of time has never been this comfortable.
Moreover, the enlarged metal side button provides improved usability, allowing for stepless dimming and a seamless 360° rotation or long-press dimming. Adjusting brightness has never been easier; What's more, you can set the brightness by rotating the button before powering it on, allowing you to go from moonlight to high brightness effortlessly.
A New Hidden Dashboard with Translucent Display
The Seeker 4 Pro high power flashlight features a hidden dashboard, a testament to innovation as it's the first flashlight to use micro-perforated laser engraving technology to achieve a translucent display on metal. With 1,200 micro holes, this dashboard not only adds a touch of elegance but also displays a more visible brightness level and remaining battery level. These holes are sealed with a waterproof material, bringing you the ultimate indicator appearance with the same IPX8 waterproof rating. It's a blend of artistry and utility, ensuring you stay informed throughout your adventures.
Dual Color Temperatures
The Seeker 4 Pro high power flashlight offers two color temperatures to choose from, cool white and neutral white, allowing you to tailor the lighting to your preference and needs. Cool white light is a bright and blue-toned light that can help you stay alert, making it good for places like offices. It's also used outdoors for clear visibility. On the other hand, neutral white light is a more balanced, comfortable light that reduces glare and eye strain. It's great for general lighting in homes and offices and shows colors accurately. The selection between these two options hinges on the specific requirements of needs and occasions.
Ready for Anything: Typical Use Scenarios
After learning about the powerful features of the Seeker 4 Pro, you must be curious about how they can be used in various scenarios. Don't worry; we're here to show you the user scenarios of the Seeker 4 Pro. It's more than just a high-powered flashlight; it's a versatile tool that caters to a wide range of usage scenarios, making it your ideal companion in various situations. Whether you're out camping, performing maintenance tasks, on night duty, simply walking your pets, etc. Seeker 4 Pro has got you covered.
🔦Camping Adventure
When embarking on a camping adventure in the wilderness, far from city lights. The Seeker 4 Pro is your ultimate companion. With its impressive 4600 lumens, it can light up your entire campsite, ensuring you can set up your tent, prepare meals, and move around with ease, even in the darkest of nights. The extended runtime of up to 15 days means you won't have to worry about running out of light during your outdoor excursion. Its compact design and multifunctional holster make it a hassle-free addition to your camping gear, fitting snugly in your belt or bag for quick access. In addition to the magnetic charging method on the flashlight itself, the revolutionary holster allows you to conveniently dock the flashlight for Type-C charging, ensuring it's always ready to shine whenever you need it on your camping adventure.
🔦Maintenance Tasks
Whether you're a DIY enthusiast or a professional mechanic, the Seeker 4 Pro is your go-to tool for maintenance tasks. Its powerful 4600 lumens provide ample illumination to inspect and repair even the most intricate components of machinery or vehicles. The enlarged side button and stepless dimming feature allow you to effortlessly adjust the brightness to your liking when wearing gloves, preventing glare and ensuring you can work comfortably for extended periods. Its innovative holster enables you to mount your Seeker 4 Pro flashlight on the wall of your garage or inside your vehicle or your belt. When you're working under the hood or beneath the car, simply dock the Seeker 4 Pro in its standard holster or optional horizontal holster, and it becomes a hands-free lighting solution.
🔦Night Duty
For those working night shifts in security, as first responders, or in any profession that demands vigilance in the dark, the Seeker 4 Pro is your trusted ally. With its intense brightness and a throw distance of 260 meters, it enables you to spot potential threats or incidents from a distance. The stepless dimming feature allows you to tailor the brightness to your specific needs, whether you're checking ID cards, patrolling large areas, or responding to emergencies. But the Seeker 4 Pro doesn't stop at illumination. It also serves as a self-defense tool with its strobe light feature to disorient potential threats, giving you precious seconds to take life-saving action.
🔦Walking Pets
The Seeker 4 Pro enhances your nighttime walks with your furry companions. Its powerful beam of light illuminates your path, ensuring you can spot any obstacles or potential hazards. The comfortable full wrap-around grip and lightweight design make it easy to hold while managing your pet's leash. Whether you're walking in a park, along a trail, or in your neighborhood, the Seeker 4 Pro's stepless dimming allows you to adjust the brightness to your comfort, creating a pleasant and stress-free walking experience for both you and your pet.
Amazing offers on O-Fan Day Sale
As part of the Olight O-Fan Day celebration, the spotlight shines brightly on the Seeker 4 Pro, and it comes bearing incredible discounts and perks for our users. This is an opportunity you won't want to miss.
Seeker 4 Pro comes with a variety of bundle choices to meet your needs. You can enjoy discounts of up to 40%, which means you can acquire the Seeker 4 Pro and related products at more budget-friendly prices. Just an additional $1, you can get the i3T Dream Blue flashlight.
What's in the Box
With your purchase of the Seeker 4 Pro, you'll receive a comprehensive package to enhance your lighting experience:
Seeker 4 with battery
Vertical holster
USB-C charging cable
Holster mounting bracket and hardware
User Manual
Innovation, power, and user-friendliness converge in the Olight Seeker 4 Pro high power flashlight. With its staggering 4600 lumen output, extended 853 feet throw distance, Type-C and magnetic charging options, industry-leading US patent-pending multi-functional holster, ergonomics and artistry design, this powerful flashlight is poised to become an indispensable tool in your daily life.
Whether you're an outdoor enthusiast for camping, hiking, wilderness exploration, a professional in law enforcement, search and rescue, or just someone who values reliable illumination, the Seeker 4 Pro is the ultimate upgrade you've been waiting for.
The new Seeker 4 Pro high power flashlight will be available in black, orange and a gorgeous midnight blue color. >>Act Now
