Red Laser PL Lights
The Baldr RL Mini is the red beam version of the Baldr Mini, integrating the adjustable compatibility of the PL-Mini 2 and the accuracy of the Baldr RL. With the High visibility green laser and 600-lumen white light combo featuring a 130-meter beam distance, Baldr RL MIni will work excellently In the case of dark vision and be one of the best PL lights of 2021.
Optimization
Aside from the different color laser, a machine-processed rice screw was added to the orbit junction of Baldr RL Mini, which can reinforce the sliding rail to make the Baldr RL Mini more stable. The Baldr RL Mini runtime of red laser mode lasts up to 11 hours which lasts 8.5 hours longer than the Baldr Mini in the red laser mode. With these optimizations, the Baldr RL Mini will be more practical and more stable in use.
Special Structure
With Olight quick loading and unloading system, it’s easy to achieve one-second installation and separation, which can improve usage efficiency. And the dual rear switches adapts both hands-on usage habit.
Outside Characteristic
With an aluminum alloy body featuring a three-level hard oxidation treatment on the surface, Baldr RL Mini can be protected from scratches. Thanks to Olight classic magnetic changing, there is no need to disassemble the light to take the battery.
After a lapse of 5 months, Olight once again launched a brand new PL light with small size and magnific power. Never miss it!
