Mini Size, Great Use
The Obulb light has a max of 55 lumens. Powered by a 630mAh rechargeable battery, it can run up to 56 hours. The Obulb measures at a 2.13 in. diameter and a 1.94oz/55g weight, making it perfect for one-handed use, so you can carry it during a night walk. It has a 1.5-meter impact resistance IPX7 dust and waterproof rating and has a two-year warranty so that is enough of the quick features. It has four different modes: a high low white mode, a steady red mode, and a flashing red mode. The operating system was pretty simple it’s just a single button that’s located right dead center on the bottom of the obulb and it’s just a single press on and a single press off.
Attach Wherever You Want
It is charged magnetically with olight’s magnetic charger and it takes about two hours to fully charge and because it has a magnetic bottom you can stick this on any piece of metal or it comes packaged with an adhesive metal badge. To keep one around the house just for emergency power situations which would be perfect for just put that little adhesive metal badge stick it on your wall and put this right into a closet. If you don’t have any lamps in your house you can have them around for ambient lighting.
Hang at Your Campsite
The Obulb light would be pretty great for camping if you have a power outage in your house. You can just have one of these fully charged standings by.
Emergency Lighting
The red-light mode is perfect for breakdowns or uses the flashing red like a beacon. It has that nice 360 degrees light so you can put this right in the center of a room. Set an Obulb in every room for ambient light and power outages!
Create A Good Mood
The Obulb uses for a party or holiday decoration, shines for a good family time, and explores more fun. Enjoy a happy family time and worry less!
