1. Baldr Mini Tactical Light
Baldr Mini tactical light combines both highly visible green beams and 600 lumens of white light with a throw of 130 meters. Aside from the adaptability to GL and Picatinny rails, the light can be slid back and forth on the sliding rail to the best position, which makes it even more compatible. Powered by a built-in lithium polymer battery, it is rechargeable through the signature magnetic charging port at the bottom of the light. The low battery indicator alerts you when it’s time to recharge. The quick attach rail mount is extremely easy to install. The dual rear switches permit smooth momentary-on or constant-on activation by either hand with equal ease.
2. Obulb Bulb Light
Obulb is a portable orb LED light with 4 modes, including warm white light (55 / 3.5 lumens), 7 lumens red light (steady or flashing). The operating system was pretty simple it is just a single button that’s located right dead center on the bottom of the obulb and it’s just a single press on and a single press off. Obulb comes in handy for various situations, like camping, hiking, night work, emergency power outage, signaling, ambiance lighting, home use, and party decoration.
3. Odin Mini Tactical Light
The Odin Mini is a brand-new compact offering in our revolutionary Odin weapon-mounted light series. Powered by a single customized 2040mAh 18500 battery, Odin Mini tactical light delivers a maximum output of 1,250 lumens and a 240-meter beam distance. Adopts the MCC3 USB magnetic charging cable with a charging current up to 1.5A, which ensures fast charging. Dedicated Mlok rail mount included and compatible with third-party Picatinny and Key-mod mounts. The length of the pressure switch is 11.22 inches. The removable Mlok mount features an innovative slide rail and a mechanical lock for secure operation. Innovative push-to-lock magnetic remote switch for a convenient and tight fit.
4. Baton 3 Rechargeable EDC Flashlight
The Baton3 EDC flashlight is the upgraded version of Olight's popular S1R II EDC light. Designed with an aluminum alloy case, the mini pocket flashlight is waterproof and corrosion-resistant, which is durable for our users. In addition, the rechargeable flashlight is merely 53g (battery included) that can be easily carried, so it is an ideal EDC flashlight for your choice. The max. output of Baton3 is up to 1200 lumens with a range of 166 meters, which greatly meets your illumination needs.
OLIGHT's first portable wireless charger can not only extend the battery life of Baton 3 but also prevent the risk of the accidental triggering of its side button, which would greatly enhance your sense of security. The lower part of the handhold pocket compact torch is OLIGHT’s special magnetic tail cap, which supports a stable handstand and absorbability onto the iron surface for lighting, thus releasing your hands and improve your satisfying user experience. The magnetic tail cap is compatible with MCC 1A/MCC3 magnetic charging cable, which is super convenient.
5. M2R Pro Warrior Tactical Flashlight
The M2R Pro Warrior is the newest version of OLIGHT two-button straight tactical flashlight. It features a single 5000mAh 21700 chargeable lithium battery and TIR lens for uniform light. The maximum output and distance are increased by 20% and 44% separately, reaching 1800 lumens and 300 meters. The surface texture is improved to the second-generation multi-functional tail with strengthened connective magnetism. Newly designed magnetic USB charging wire can hold 2A current, increasing charge rate 100%. With its lanyard hole, detached two-way Stainless Steel Pocket Clip, flashlight bag, the M2R Pro is the next evolution of the tactical flashlight.
