The BALDR Pro is a professional PL light with green laser sight and white LED for installation on equipment with a Picatinny (MIL-STD-1913) or Glock rail.
Powered by two CR123A batteries, with the extreme performance of 1350 lumens and 260 meters beam distance, the Baldr Pro is leading the way in compact rail lighting tools.
The neutral white LED and TIR lens makes for a robust searchlight. The center beam of the BALDR Pro is intense and concentrated, also soft and wide when near the ground. Three light settings are available. The white LED can also be set to 300 lumens of constant lighting. The beam emitted by the green laser is visible during both night and day.
The light can withstand strong impacts and vibrations without loosening after calibration when screws are adjustable. And It’s also easy to install and detach the light by pressing or loosening the side swing arm.
The aluminum body can stand extremely high strength and reliability. Thus, the BALDR Pro is a high-quality choice for professional users with its excellent ease of use, high brightness, and extremely powerful performance.
