The Perun 2 headlamp is an upgraded version of the Perun. As a result, all aspects of its performance than the old version are much better, and the color also made a breakthrough change to make it more dazzling.
Powered by a 4000mAh 21700 battery, this new multi-functional right-angle flashlight delivers a maximum output of 2,500 lumens and provides a longer runtime.
Power Enhanced
The Perun 2 is powered by a 4000mAh 21700 battery. This new multi-functional right-angle flashlight delivers a maximum output of 2,500 lumens, 25% brighter than the original Perun, and provides a longer runtime. If you go on an adventure, it will light up the front for you and keep you from fear.
Improved Charging Efficiency
Perun 2 is a rechargeable headlamp that adopts the MCC3 USB charging cable with a charging current of up to 2A, which greatly improves the charging efficiency. It increases charging speed by 33% compared to older versions, saving valuable time and getting you out of the house quickly.
Multifunctional Use
It is small and easy to carry every day. You can use as a traditional powerful headlamp Included headband, and you can clip it in your carry-on backpack without taking up too much space. You can also attach the Perun 2 to magnetic surfaces for hands-free use.
More safety
The special built-in proximity sensor will reduce brightness to protect any nearby objects and your eyes. Whether it's lighting up the road ahead or viewing a map in the dark, Perun 2 rechargeable headlamp automatically adjusts brightness and ensures the best user experience. The design greatly enhances the safety of such a bright flashlight.
