Use a thermal camera for home insulation checks before construction and again under comparable conditions afterward. Photograph the same surfaces from the same positions, record indoor and outdoor temperatures, and keep camera settings consistent. Pair thermal patterns with installation records and targeted professional verification to judge what changed.
| Purpose | Useful equipment | Selection priority | Example or record |
| Map surface temperature patterns | Phone-connected thermal imager | Compatible device, saved images, repeatable settings | TOPDON TC001 Max |
| Identify the exact location | Visible-light camera | A wide context photo plus a closer detail | Phone camera and numbered room sketch |
| See access points and write notes | Adjustable white inspection light | Comfortable close-range output and secure positioning | Olight Perun 3 |
| Compare conditions | Air thermometer, humidity meter, weather record | Same measurement locations and units | Separate before and after session logs |
| Verify the installation | Contractor documentation and appropriate inspection | Coverage, material, depth or density, and agreed scope | Installation photos and completion report |
- 1. Can a thermal camera be used to check house insulation?
- 2. Comparable Conditions Before and After the Work
- 3. A Ten-Location Baseline You Can Repeat
- 4. Camera Settings That Keep the Comparison Honest
- 5. Reading Patterns Without Jumping to a Diagnosis
- 6. Emissivity, Reflections, and Window Readings
- 7. Resolution: 256 × 192 and Enhanced 512 × 384
- 8. Visible-Light Checks Around the Inspection Area
- 9. Turn the Comparison Into a Contractor Conversation
- 10. Professional Energy Assessments and Assistance
- 11. Is it worth buying a thermal camera?
- 12. What is the best thermal camera for homeowners?
- 13. Frequently asked questions
Yes. A thermal camera helps you locate surface temperature differences that deserve a closer insulation or air-sealing inspection. During a heating season, compare the room-facing surfaces of exterior walls and ceilings. Mark an unusual patch, locate it in an ordinary photograph, and compare that same area after the work under similar conditions.
Keep the question specific. A colder ceiling patch above a bedroom can justify asking about insulation coverage over that location. A streak near an attic hatch can justify checking the hatch seal. Neither observation tells you the installed insulation depth or the air leakage rate by itself. Ask for evidence that matches the particular concern rather than treating the entire house as one pass-or-fail thermal picture.
For a phone-connected option, the TOPDON TC001 Max, available through OSelect, combines infrared and visible-light cameras. Olight's U.S. product information identifies a 256 × 192 infrared resolution enhanced to 512 × 384 through TOPDON's TISR technology. That distinction matters when choosing how closely to frame a suspect area and how to describe an exported image.
The TC001 Max has separate visible-light and infrared lenses; the USB-C connector sits above the blue body.
Choose the wall or ceiling surface before choosing a color palette. A wide scan helps you organize a room, while a closer image helps you relocate a small feature. Keep both views. A close-up with no room reference can leave the contractor guessing which side of the window, closet, or attic opening you meant.
Plan the baseline while the old insulation condition is still accessible for documentation. Ask the contractor which areas the project will change, which areas will stay as they are, and when the finished assembly will be ready for a useful follow-up. Save that scope with your room sketch so the second visit covers the actual work.
For a winter comparison, choose a period when the house is heated and the outdoor air is colder. Repeat at a similar time of day and with a similar indoor-to-outdoor temperature difference. Avoid comparing a sun-warmed afternoon wall with the same wall after a cold night. Also note wind, recent precipitation, thermostat changes, and unusual indoor heat sources. These observations help explain why two otherwise similar pictures may differ.
Use an air thermometer to record indoor and outdoor conditions. A thermal camera's spot reading on a wall describes that surface; it does not substitute for the room air temperature. Take indoor readings at the same location, away from a supply register or direct heater, and use a consistent outdoor location. Record the time rather than relying on the image's color to suggest how cold the night felt.
Calculate the air temperature difference using the same units in both sessions. For example, indoor air at 70°F and outdoor air at 35°F produces a 35°F difference. This is an arithmetic example for filling in the log. Your comparison should use your own readings, along with the weather and operating notes collected during each session.
Decide whether the sessions are comparable before judging improvement. If a strong wind affected one night, or someone changed the thermostat shortly before the second scan, flag that pair for another visit. Keep the pictures and the explanation. A clear reason to repeat one location is more useful than adjusting colors until two unmatched images appear persuasive.
| Session detail | Before the work | After the work |
| Date, local time, and room | Record on site | Repeat location and time window |
| Indoor and outdoor air temperature | Record both, with units | Record both, then compare the difference |
| Indoor relative humidity | Record at the chosen room location | Use the same location |
| Weather and recent sun exposure | Note wind, rain, snow, and sun | Flag meaningful differences |
| Heating and ventilation operation | Record thermostat and equipment state | Match normal operation where practical |
| Camera, app, and settings | Save the configuration | Repeat and record any change |
Make a simple floor plan and assign ten location numbers before collecting detailed images. Ten is a practical organizing choice, not a required inspection standard. Select positions that cover the contractor's scope, the rooms with comfort complaints, and a few nearby comparison surfaces. A smaller home or a narrowly defined project may need fewer locations; a complex addition may need more.
For an attic insulation project, useful room-side views include the main bedroom ceiling, a ceiling near an exterior corner, the ceiling below an attic storage area, and the closed attic access hatch. Add a wall-to-ceiling junction and a ceiling area near a bathroom or utility penetration. Photograph around these features from the occupied room without removing electrical covers or disturbing insulation.
For a wall project, include the center of an affected wall, the area beneath a window, a corner, and a wall section beside a door. Record whether furniture, curtains, or a cabinet covers part of the surface. If you move furniture for the baseline, allow the surface conditions to settle and repeat that arrangement for the follow-up. Do not compare a freshly uncovered wall with one that remained exposed all evening.
At each position, capture a room view, a thermal overview, and a closer thermal detail if you see something worth discussing. Write down where you stood, which direction you faced, and the approximate camera height and distance. Include a fixed feature, such as a door frame, in the context photo. This gives you a reliable way to find the same patch months later.
Use a filename that sorts into pairs, such as L03-bedroom-ceiling-before and L03-bedroom-ceiling-after. Keep original files as well as the copies you annotate. Put arrows and comments on a duplicate so the original remains available for another interpretation. Save the session log beside the images rather than leaving the temperature readings in a separate notebook you may misplace.
End the first session with a short list of questions. Separate a suspected coverage gap from a known draft complaint or a stain that needs moisture investigation. Tell the contractor which locations you want documented during installation, before the work becomes concealed. That request can provide stronger evidence than trying to infer every detail from the finished ceiling.
Start with the same camera, phone, app, and orientation for both sessions. Save a screenshot or written record of the relevant settings, including temperature units, emissivity, palette, and image mode. If the app provides a manual temperature span, record its lower and upper limits. Keep the original automatic-span image as well when it helps locate the feature.
A palette translates temperatures into colors. If the app rescales those colors for each picture, a small temperature variation can fill the whole palette in one image while a larger variation uses the same colors in another. Read the temperature scale and compare equivalent surfaces. A different shade alone gives you too little information to judge the installation.
Keep thermal-only images for comparing patterns and use visible-light or fusion views to identify the location. The TC001 Max's two lenses provide useful context, especially when a plain painted ceiling has few recognizable features. Check that any visible outline aligns with the thermal feature at your chosen distance. Use the ordinary room photo to resolve location questions.
For a suspicious small area, move to a safe position that gives the camera a clearer view instead of relying on digital enlargement. Retain enough surrounding wall to show where the feature sits. If a lamp, radiator, television, or supply register affects that section, record it and choose an additional view away from the local heat source.
The TC001 Max manual describes occasional shutter clicks and brief image pauses during its automatic refresh. Allow an interrupted view to settle before saving your comparison image. Keep the lenses clean according to the product instructions and avoid touching them. A repeatable routine helps you recognize a camera or framing issue before treating it as a construction defect.
Compare the shape and location of an anomaly with the construction behind it. A regular line that follows framing differs from an isolated patch in the middle of a ceiling bay. Natural Resources Canada's building-science guide explains that framing can form thermal bridges and that airflow depends on both openings and pressure differences. Use those distinctions to decide what needs verification.
Describe what you can locate: a broad patch, a repeated stripe, a narrow edge pattern, or a change around a penetration. Then ask what else could produce that pattern. A visible stain, the position of a duct, or an installation photo may change the next step. The following table organizes possibilities; a qualified inspection establishes which explanation fits your house.
| Pattern in a winter room-side scan | Possible explanation | Useful follow-up |
| Isolated cooler patch between framing lines | Missing, displaced, or uneven insulation; another local condition | Compare installation photos and inspect the matching location |
| Repeated cooler lines following framing | Thermal bridging through framing | Identify the assembly and the agreed insulation scope |
| Irregular streak near a trim edge or penetration | Air movement affecting surface temperature | Ask an assessor about controlled leakage testing |
| Patch associated with staining or damp material | Moisture-related condition | Investigate the moisture source before covering it |
| Apparent hot or cold feature on shiny metal or glass | Reflection or a different surface property | Change viewing angle and compare a suitable nearby surface |
Treat a change in a single location as a lead to follow. Check the adjacent area and return to the room overview. A feature that follows the outline of a heating duct calls for a different conversation from a patch centered in the contractor's newly insulated area. Keep those observations separate in the report so the right trade can address each issue.
After the upgrade, look for a more even pattern across the treated area under comparable conditions. Also revisit the two most concerning baseline locations. Ask the contractor or assessor to document what they found there and how they verified it. Record the confirmed explanation, any correction, and the follow-up date. Leave an unresolved item labeled unresolved until someone has checked it.
A thermal camera estimates surface temperature from infrared radiation. Emissivity describes how effectively a surface emits that radiation. Surface finish and reflected surroundings affect the result, so a shiny metal fitting and a painted wall can display different apparent temperatures even when a direct comparison seems tempting.
The TC001 Max manual specifies surface measurements and warns that the device does not see heat through glass or opaque objects. Aim at the room-facing surface you want to inspect. A scan of a closed window cannot show the insulation on the other side of that window, and a scan of drywall cannot reveal a literal photograph of the material inside the wall.
If a suspicious feature appears on reflective glass or metal, change your viewing angle while staying in a safe position. Watch whether the feature moves with your viewpoint or resembles a nearby person, heater, or lamp. Photograph the surrounding painted frame or wall as a separate surface. Keep each material's reading in context rather than averaging unlike surfaces into one result.
Use a consistent emissivity setting for comparable surfaces and record any deliberate change. Avoid adjusting that setting merely to make a reading agree with an expectation. For a dispute involving a small temperature difference, ask an assessor about appropriate measurement methods and uncertainty. Comparing the same painted surface under matched conditions gives a clearer starting point than comparing unrelated materials.
The TC001 Max's 256 × 192 infrared array represents 49,152 pixels. A 512 × 384 image contains 196,608 image positions, four times as many by multiplication. Those counts describe image dimensions. With this model, TOPDON's TISR enhancement produces the larger image from the lower-resolution infrared data; describe the enhanced output and the sensor resolution separately.
For a homeowner, framing often makes the practical difference. If an entire room fills the picture, a small gap near a hatch occupies only part of it. Take a room overview for context, then a closer detail of the same location. A larger exported file cannot replace a clear view of the target or recover a feature that never occupied enough of the original image.
Select a camera by the job you need to document. Look for a compatible phone connection, understandable app controls, a way to retain useful image files, and enough detail at a safe working distance. Evaluate the screen and handling together: you should be able to identify the location, read the scale, and save the image without balancing a phone on a ladder.
The TC001 Max U.S. listing identifies support for iOS, Android, and Windows and describes USB-C and Lightning adapters. Check the exact device, operating system, connector, and app requirements before choosing a configuration. For a before-and-after project, make that compatibility check before the baseline date so both sessions can follow the same workflow.
Use ordinary room lighting to reach the observation positions, read your notes, and take context photographs. An adjustable headlamp can keep your hands free when you need to handle the phone and record a location. Aim the beam where you are looking, choose a comfortable working level, and keep the walking route clear.
The Olight Perun 3 includes a headband and offers white and red lighting. Its large side button supports operation with gloves, according to Olight's U.S. product description. For an indoor inspection, use white light to identify trim, labels, and surface details, adjusting the output to the task rather than starting with maximum brightness.
The OD Green Perun 3 shown here sits in its headband mount for hands-free visible-light work.
Position the light and your body so they do not obscure the phone's view. Keep the light away from the surface being compared, and avoid resting a warm flashlight against that surface before scanning. Record any local heat source that could affect the area. Visible light helps you see where you are working; the thermal camera handles the infrared image.
A rechargeable flashlight can also help with a ground-level visual check of a hatch frame, weatherstripping, or an accessible corner. Choose a stable position and keep both feet on a suitable floor. Leave concealed wiring, suspect materials, and inaccessible attic areas to a qualified professional. More light does not provide a safe walking surface above a ceiling.
Send a short, organized packet rather than a folder of unexplained screenshots. Start with the work area and the concern, such as a recurring cooler patch above the bedroom closet. Include the location number, a room photograph, the before-and-after pair, and the session conditions. Keep your question tied to the agreed scope: coverage over that closet, hatch insulation, or air sealing at a named junction.
Ask for the installation evidence that answers the question. Depending on the material and project, that may include photographs taken before concealment, product identification, installed depth markings, coverage records, or the contractor's inspection checklist. Ask the contractor to explain how the evidence relates to the location you flagged. This keeps the discussion focused on a verifiable part of the work.
For the two highest-priority anomalies, agree on a follow-up method before anyone disturbs the assembly. A professional may use accessible inspection points, construction records, or another appropriate diagnostic method. Any opening or material disturbance requires permission and an assessment of what lies behind the surface. Keep the homeowner's role to locating, recording, and asking clear questions.
Close each item with a written outcome. Record whether the contractor confirmed a gap, identified a thermal bridge outside the project scope, corrected an issue, or requested different inspection conditions. Save the correction photographs and repeat the relevant image pair when conditions allow. A documented unresolved question is easier to carry into an independent assessment than an argument about which palette looks better.
Request an independent assessment when several rooms remain uncomfortable, the images have multiple plausible explanations, or you need measured air leakage information. The U.S. Department of Energy's home energy assessment guide describes infrared scans and calibrated blower-door testing as complementary tools. It also recommends preparing a list of comfort or condensation problems and recent energy bills for the assessor.
Ask what the visit will deliver: a location-based findings report, relevant measurements, photographs, and prioritized recommendations. Share your baseline packet in advance. Let the assessor choose and control any pressure testing, including the precautions appropriate to combustion appliances and ventilation. Your normal-operation image log gives the assessor useful history without requiring you to alter the house's pressure conditions.
For selecting a provider, DOE's Energy Skilled consumer resource explains how to ask about recognized credentials, including home energy assessment credentials. Confirm the individual who will perform the visit, the services included, and whether the assessor can investigate your particular wall or attic concern. Credentials and a clear scope help you choose the right service for the question.
Households seeking help with weatherization costs can start with DOE's Weatherization Assistance Program application page. The program operates through state and local administrators. Use that route to identify the responsible agency and its application process before committing to work. Ask the agency which services, documentation, eligibility requirements, and approvals apply to your household and project.
Buying can make sense if you expect to repeat inspections across several projects and are willing to keep consistent records. A camera offers the convenience of returning to the same location when the weather is suitable. Consider the full workflow, including device compatibility, image storage, and the time needed to compare conditions and interpret the pictures.
For a single insulation project, compare buying with renting a suitable camera or hiring an energy assessor. An assessor may be the better first purchase when you need an independent diagnosis, controlled leakage measurements, or a completion report. A homeowner who already understands the assembly and wants regular condition records may value having a camera available between professional visits.
Choose the option that answers your next decision. If you need to locate a suspect ceiling patch, a repeatable thermal survey can help. If you need to establish installed material depth or confirm a concealed repair, arrange the corresponding inspection and documentation. Put the cost toward resolving that question rather than buying a higher image-resolution number alone.
The best fit combines compatibility, usable detail, manageable controls, and files you can keep for later comparison. For phone-connected inspections, the TC001 Max offers dual lenses and TISR-enhanced imaging in a compact format. Match those features to the surfaces and distances in your home, then check that your phone and software support the workflow you intend to use.
Prioritize a clear scale and a repeatable image over a dramatic color scheme. Try the camera's recording and retrieval process before the construction date. Make sure you can find an image by location, reopen it, and share a readable copy with the contractor. That small preparation step can matter more to a useful before-and-after record than an extra feature you never use.
