If you plan to camp outside after the sun goes down, what do you need most? The answer is light. A bright light that can illuminate your surroundings. Right! No one wants to spend a night in the dark wilderness, right? Then maybe an outdoor camping light would be your best choice. They not only create a warm ambience but also act as a good deterrent to thieves and intruders at night.
Fortunately, Olight recommends 3 camp lights for you:
Odiance Camp Light
The Odiance is multi-use work light with remote control. With a max. output of 3,000 lumens and a color temperature from 2700 to 6000K, it is your great assistant on construction sites, for car repairs, camping, in the backyard, etc. By rotating the stepless brightness switch, you can get any brightness level you want. It also features a remote controller for easy adjustments of the brightness and color temperature. With its built-in 99.36Wh battery, it runs up to 2,800 minutes and is fully charged within 5.5 hours. With the type-C and USB-A output interfaces, it can serve as an emergency power bank to charge electronic devices. Rated as IPX5 water-resistant, it withstands rainy environments. Functional and powerful, it meets your various lighting needs.
Olantern Classic 2 Lite & Olantern Classic 2 Pro
Olantern Classic 2 Lite & Olantern Classic 2 Pro is Olight's first self-developed retro camping light. Olantern Classic 2 Pro/Lite can illuminate your surroundings 360°, not only for camping, gardening, and home atmosphere, but also for power outages and backyard parties. With a dual light source design, the top 14 warm white LED beads emit brighter warm white light; the middle 3 orange LED filaments emit a soft and comfortable orange glow to enhance the atmosphere; with a compact and exquisite appearance, it is a lamp, but also a way of life.
Olantern Mini Camping Light
The Olantern Mini is a compact outdoor light that features a balanced 360-degree beam. It is so small that you can fit it in one of your palms. Its handle also works as a hook, making it easy to carry and position. Its body is mainly made of zinc alloy, allowing it to be tough yet lightweight. The Olantern Mini not only provides a dimmable white light but also a night vision preserving red light, great for camping or emergency use. The tornado-shaped light diffuser softens the light output, reducing strain on your eyes during long-time use. When the included motion sensor feels a shake, the indicator around the button will light up, allowing you to read the battery level and locate the button in the darkness. It also features a built-in lithium-ion battery that can be charged quickly using the included USB magnetic charging cable. The Olantern Mini is a refined product to light your home and adventures.
What do you need to consider when buying outdoor camp lights?
Modes
For camping, you do not need to keep the camping light in the brightest mode, which will speed up its power consumption and shorten its operation time, so please choose a model that can provide you with several different brightness modes.
Lumens
The brightness of any light bulb is measured in lumens. The level of brightness required for travel depends on your personal needs. There are many higher-powered LEDs available for outdoor lighting; they can light up your camping area and allow you to eat, chat, and move around safely in the dark.
Runtime
For camping, you may need prolonged lighting, and the operating time of camping lights depends on how long you plan to camp. Usually, the longer the better.
waterproof
The camping lights are likely to get wet in the complex environment in the wild, whether it is raining in the camp or a humid environment in the middle of the night. Water resistance needs to be above IPX4.
More than just camp lights
In the wilderness, we tend to use more than just camp lights. Most campers will have three or four different lights. Olight provides headlamps. Outdoor flashlights are also a quality light source for outdoor travel. Check out olightstore.com for more products.
