The festive season is just around the corner, and it's the perfect time to start thinking about unique and practical gifts for your loved ones. This guide will focus on recommending a tactical flashlight as an ideal Christmas gift, catering to the needs of outdoor enthusiasts, adventurers, and those interested in self-defense.
We’ll take a closer look at the Olight PL Turbo. This is an 800-lumen flashlight, but it has an incredible candela output of 66,329.
Pressing and releasing the button keeps it on and also turns it off, which you can do from either side.
If both buttons are pressed simultaneously, flash mode will be entered, and flash mode can be turned off by pressing either button.
It uses two CR 123A batteries, like the one here, they are not proprietary and you can readily buy them in any store.
When opening and closing this lid, you have to pop that little device up.
It comes with an adapter for the Glock rail, already mounted on it.
There is a screw to remove it and then you get a tool kit that includes these two Allen wrenches, the large one for tightening or loosening the screws that hold the rails and the small one for removal and reinstallation Add-ons on the 1913 rail.
If you're not mounting it on a Glock, just unscrew that screw, take off the adapter, replace it with a new one, and put the screw back on.
It also provides an extra screw. When installing it on the rail, you need to do the following steps: First, align it with the groove on the rail; then, push it back or forward to seat it; once it is in place, you can use your fingers to Twist it and make it tight enough, or you can use something like a quarter to tighten it all the way down if it needs to be tighter. This is easy to do.
I'm going to get it mounted and we're going to take some pictures of it mounted on the gun and then I'll take you to light it in the dark and compare it to my other lights.
Let's take a look at the beam between PL 3R, Valkyrie Turbo, and PL Turbo, wow can you see the difference?
Photography by Cody Allen
Look at how well they light up those brackets, they light up so brightly, like daylight, hundreds of yards away.
It has good wide-angle illumination and a concentrated strong beam. I think this is a great flashlight for use as a pistol light and I'm sure it would work for other uses like a rifle as well, maybe even better in those situations where a long range is required.
If you need a bright flashlight that shoots long distances and focuses light, this is the flashlight for you.
If your family loves outdoor activities or wants to ensure personal safety, I highly recommend considering a tactical gun flashlight. It is a specialized tool that can be mounted on firearms like pistols or rifles, offering a range of benefits.
First and foremost, a tactical gun flashlight enhances visibility during nighttime adventures such as hunting, camping, or hiking. It helps you navigate safely in low-light or dark environments, making it easier to identify potential obstacles or hazards. Whether you're tracking animals or searching for lost items, this flashlight can greatly assist you.
Moreover, a tactical gun flashlight can be a valuable asset for self-defense purposes. In situations where personal safety is at stake, having a combination of a firearm and a powerful flashlight can provide a tactical advantage. By temporarily disorienting or blinding a potential threat with the flashlight's intense light, you gain precious moments to assess the situation and take appropriate action.
Additionally, these flashlights often come with useful features like strobe modes, adjustable beams, or momentary-on switches, which add to their versatility across different scenarios. They are built to withstand rugged outdoor conditions, being water-resistant and shockproof, ensuring their reliability during your adventures.
However, it is crucial to remember that the use of firearms, including for self-defense, should always comply with relevant laws and regulations. Prioritizing safety, receiving proper training, and using the tactical gun flashlight responsibly are imperative factors when incorporating it into your outdoor activities.
Overall, a tactical gun flashlight can significantly enhance your outdoor experiences and provide an added layer of safety. Its ability to improve visibility and serve as a self-defense tool makes it a worthwhile gift to your loved ones. Add one to your cart, click here!
