Welcome to the ultimate guide to Olight's Baldr series rail mounted tactical lights, has redefined the standards of accuracy and performance, tailor-made for all you gun enthusiasts out there! This comprehensive guide is designed specifically for firearm owners, especially those in search of weapon lights equipped with laser sighting capabilities. Let's dive into the captivating journey of the Baldr series, uncovering their unique features and applications in the world of shooting sports and tactical operations.
Baldr Pro: Tactical Light & Green Laser
Baldr Pro, released in November 2019, emerges as a powerful rail mounted tactical light, boasting a staggering 1350-lumen neutral white light and an impressive beam distance of 260 meters, all powered by two CR123A batteries. Its versatile design caters to firearms equipped with a Picatinny (MIL-STD-1913) or Glock rail. Offering exceptional adaptability, the Baldr Pro allows users to adjust the white LED to 300 lumens for consistent lighting in various environments. Additionally, the highly visible green laser beam serves as a reliable targeting aid, delivering unparalleled accuracy in both day and nighttime conditions.
Baldr RL: Tactical Light & Red Laser
Baldr RL, introduced in March 2020, powered by two CR123A batteries, offers remarkable precision and targeting accuracy by combining a red laser sight with a powerful 1,120-lumen neutral white LED illumination. The 5mW red laser, selected for its optimal balance between visibility and eye safety, serves as a reliable aid for precise and accurate targeting, enhancing the user's capacity to acquire and engage targets swiftly and effectively. Its adaptable design facilitates seamless installation on Picatinny (MIL-STD-1913) or Glock rails, ensuring optimal performance and ease of use. The Baldr RL's dynamic capabilities, including the option to set the white LED to 300 lumens for consistent lighting, cement its position as a trusted ally for professionals seeking a reliable, high-performance lighting solution.
Baldr Mini: Compact Rechargeable Tactical Light & Green Laser
Baldr Mini, debuted in August 2020, embodies a perfect fusion of power and size, boasting an ultra-compact design of merely 2.24 inches. Despite its compact size, the Baldr Mini delivers an impressive 600 lumens of cool white light, complemented by a highly visible green laser beam, ensuring enhanced accuracy and visibility in close-range shooting scenarios. With two adaptable rail adapters catering to both Glock and Picatinny rails, its adjustable sliding rail enables effortless customization to find the optimal position for short setups. Equipped with a built-in lithium polymer battery, the device is easily rechargeable through Olight's signature magnetic charging port.
Baldr IR: Tactical Light & IR Beam
Baldr IR, launched in November 2020, combines a 1350-lumen neutral white light LED with a Class 1 eye-safe IR beam, ideal for covert night missions. Designed for Picatinny (MIL-STD-1913) and Glock rails, it provides a 1350-lumen or 300-lumen beam, ensuring far-reaching spot illumination and soft flood for situational awareness. Its IR mode emits a focused IR beam from the bottom, invisible to the naked eye yet perfect for night vision goggles. With a runtime of up to 4 hours for the white light and an impressive 80 hours for the IR, powered by two CR123A batteries, the Baldr IR is a reliable companion, emphasizing Olight's commitment to versatility and durability in low-light environments.
Baldr RL Mini: Compact Rechargeable Tactical Light & Red Laser
Baldr RL Mini, introduced in April 2021, is the red beam counterpart of the Baldr Mini. This compact rail mounted light arrives with both Glock and Picatinny rail adapters, accommodating various mounting preferences. The patented sliding rail mount facilitates effortless adjustments, allowing for a seamless fit even on subcompacts. Despite its compact size, the Baldr RL Mini produces a robust 600-lumen cool white light and a red beam, enhancing accuracy in challenging environments. Powered by a built-in lithium polymer battery, this lighting tool ensures extended runtime and convenient recharging through its magnetic charging system.
Baldr S / Baldr S BL: Compact Rechargeable Tactical Light & Green / Blue Laser
The Baldr S and Baldr S BL, unveiled in July 2021, represent powerful compact light/laser beam combinations available. They offer an impressive 800-lumen cool white light output, accompanied by a convenient 100-lumen low setting for varied lighting needs. The Baldr S offers users enhanced visibility and accuracy with a green laser beam, while Baldr S BL provides a Class III 440-460nm blue laser beam. The light's enhanced battery capacity of 3.7V 380mAh ensures an extended runtime of up to 140 minutes, guaranteeing sustained performance during critical operations. Featuring the patented sliding rail mount and two types of rail adapters for Glock and Picatinny rails, the Baldr S and Bladr S BL emphasize adaptability and ease of use, accommodating a wide range of firearms with precision and reliability.
Baldr Pro R: Rechargeable Tactical Light & Green Laser
Baldr Pro R, introduced in November 2021, emerges as the flagship rechargeable rail mounted light of the Baldr Series, combining a robust 1350-lumen cool white light with an integrated <5mW green laser beam for swift and precise aiming. The light's innovative design integrates the green laser beam emitter into the head, allowing for a convenient magnetic charging port on the bottom and support for a remote pressure switch, enhancing its versatility and user-friendly operation. Equipped with two types of rail adapters for Glock and Picatinny rails, the Baldr Pro R ensures seamless integration and optimal performance on a wide array of firearms. The built-in 3.6V 1000mAh lithium polymer battery can be effortlessly charged via the MCC charging cable without the need to remove the battery.
A Guide to Laser Types for Tactical Precision
When it comes to laser weapon lights, different colors of laser beams have their unique advantages and applications in various scenarios.
🔎Green Laser: Green lasers are often considered one of the most easily observable laser colors, especially in situations with strong outdoor lighting. This makes it a preferred choice for many shooters as it provides clearer target indication and higher precision. The use of green lasers is applicable in various shooting environments, ranging from indoor shooting ranges to outdoor tactical missions. The high visibility of green lasers makes them an ideal choice for quick and accurate aiming.
🔎Red Laser: Red laser strikes a balance between visibility and eye safety. It performs better in low-light environments, as its beams are more easily perceptible in such conditions. They are particularly useful for indoor or nighttime operations, providing good target alignment capabilities. Red lasers are also a common choice for many shooting enthusiasts, especially in dim or limited light conditions.
🔎Blue Laser: Blue Lasers offer a distinctive and highly visible appearance. The unique wavelength of the blue beam enhances accuracy and visibility, making it an optimal choice for scenarios where standing out is essential. Reduced atmospheric scattering allows the blue laser to maintain a concentrated beam over longer distances, making it valuable for target identification in a variety of environments.
🔎IR Laser: IR (Infrared) lasers are an ideal choice for use in low or no-light conditions, as their beams are invisible to the naked eye but can be observed through infrared devices such as night vision goggles. This makes IR lasers a preferred choice for clandestine and covert operations in many military and law enforcement settings. They offer higher concealment and security while still providing accurate target indication capabilities.
By understanding the characteristics and application scenarios of these different lasers, shooting enthusiasts and professionals can choose the appropriate tactical lights that best suit their specific needs. This personalized selection ensures optimal visibility and accuracy in different shooting environments and operational scenarios.
In the ever-evolving landscape of rail mounted tactical light, the Olight Baldr Series continues to empower users with the tools they need to shoot with confidence and precision, no matter the situation. Whether it's the superior precision of the laser, the adaptability of diverse models, compact design, or the powerful illumination, the Baldr series stands as a testament to Olight's dedication to revolutionizing weapon lights. As a crucial component of modern shooting and tactical equipment, the Baldr series provides firearm enthusiasts with great shooting experience.
Friendly Notice:
After the end of the Black Friday sale, our support team will manually add 50 O-Coins to your account. Please note that this process may take some time due to the high volume of requests. We kindly ask for your patience and assure you that the O-Coins will be credited to your account as soon as possible.
If you have any questions or concerns, please feel free to reach out to our customer support team, and we will be happy to assist you.
Thank you for your understanding.
