In our modern world, gadgets have become a part of our lives. Yet, their functionality hinges on power. Without power, any electronic gadget is useless, no matter how expensive it is. That’s where the necessity of power banks was born.
Most power banks today are small enough to fit in your pocket and can charge your smartphone or flashlight several times before running out of battery.
Today I’m introducing you to a power bank flashlight, the Olight Baton 3 (Premium Edition).
Olight Baton 3
Olight Baton 3 is an upgraded version of the previous SR1 Baton II and one of the smallest flashlights in the Olight collection. Except for the portable wireless charger, there is no difference between the standard and premium Baton 3.
This flashlight is really small in size with a dimension of 2.48 inches in length and 1.87 oz in weight. It can produce a maximum output of 1200 lumens and a 166-meter beam distance.
The standard version has a runtime of 20 days, whereas the premium version (power bank flashlight) can last up to 94 days.
Olight flashlights including the Baton 3 are made to withstand harsh climatic conditions. Baton series flashlights are made of Aluminum Alloy. It has an IPX8 and a 1-meter water drop test rating.
Baton 3 also offers you hands-free convenience. The conventional dual-direction pocket clip and the flat magnetic tail make it easy to clip or attach to any metal surface.
Benefits of Olight Baton 3 Premium Edition
As I mentioned earlier the standard and premium versions are the same, but what makes them different is the portable charger that comes with the premium edition. If you’re looking for a power bank flashlight, the Olight Baton 3 premium edition might be the best option for you.
Here’s why,
Boost Battery Life
If you buy the premium edition, the power bank can charge your flashlight 3.7 times before needing to recharge the wireless charger. It can boost Olight Baton 3's runtime from 20 to 94 days. It's like getting an extra lifeline.
If you’re planning to hike in the wilderness for a long period of time, this is the flashlight you want to have as you don’t have to worry about running out of power. This added convenience is priceless in the Baton 3 premium edition.
Compact and Portable
Unlike other portable chargers, the Baton 3 power bank is compact and portable. In fact, the charger is designed in a way that you need to insert a flashlight inside the charger for charging.
You don’t need to connect the flashlight and the charger with a cable. All you need to do is push the flashlight in and let it charge. This removes your worries about the cable getting disconnected or the current not passing through.
The charger is a small square-shaped box that you can keep in your pocket, backpack, or handbag and take with you anywhere you go.
High-Speed Charging
Long charging times can be highly inconvenient when in a rush. But with Olight Baton 3 that's not the case. The power bank takes about 3.5 hours to fully charge, whereas the flashlight takes about 1.5 hours to fully charge.
Long Lifespan
Durability and longevity are key features to consider when investing in electronic devices. The good news is that the Olight power bank flashlight scores high on both of these aspects. Built to last, the Baton 3 wireless charger can endure hundreds of charging cycles before its performance starts to degrade.
This Olight flashlight can serve you reliably for several years with proper care and maintenance. Hence, it’s a one-time investment that reaps long-term benefits.
Comes in Handy During Emergencies
During an emergency, you cannot always hope to find a charging point. With an Olight power bank flashlight, you can charge your flashlight anytime, anywhere, and don’t need to worry about having your flashlight run out of power.
Also, in some cases, when you damage or lose your flashlight MCC charging cable or even if the power goes out at your house, a power bank is handy. Olight Baton 3 is always there to save the day.
Take Your Pocket Lighting Up a Notch
All flashlights' primary objective is to provide light. If it’s out of battery, your flashlight is useless. Owning a power bank flashlight like the Baton 3 gives you peace of mind and convenience.
This flashlight is a must-have for camping, emergency, and everyday use. By choosing Baton 3, you're investing in a reliable, high-performance tool that will be there when you need it most.
So why wait? Give your flashlight the lifeline it deserves with a top-notch portable power bank today.
