TL;DR: Choose a pen light with controllable white output and a grip you can turn easily. Sweep light across a cooled weld or cured paint to reveal surface texture. Use even bench lighting and the approved sample for color comparisons. Record anything unusual and follow the job's inspection procedure before accepting the part.
- 1. Start with the light direction that fits the task
- 2. What is the best flashlight for inspections?
- 3. Which pen light is the most powerful?
- 4. How to choose a pen light?
- 5. Follow the lighting requirement in the job procedure
- 6. Check cooled welds, cured paint, and machined edges
- 7. Set up the record before a second person needs it
- 8. Compare two portable white-light choices
- 9. Frequently asked questions
At an approved inspection bench, begin with the assigned room or task lighting. Use the pen light to take a second look when glare, a shadow, or a narrow opening gets in the way. Make sure the part has cooled, the surface is ready for examination, and any movement is allowed by the station's procedure. Cool paint can still be awaiting release from the finishing area, so check the actual job status first.
| Light direction | Useful surface check | What to confirm |
| Low across the surface | Weld edge, paint texture, or raised burr | Feature stays in the same place when the light moves |
| Even white bench light | Paint appearance and visible reference | Use the approved sample and viewing setup |
| Light behind a visible edge | Outline of an accessible hole or slot | Part is secured and the approved view is clear |
On a finished weld edge, a low light can cast a small shadow that draws attention to a change in the surface. Move the light a little to check what the shadow follows. For paint color, start at the specified station and compare the surface with the designated sample under the same light. For a machined edge, backlighting can make the outline easier to see if the fixture already allows a safe line of sight.
Start with an easy view that gives you the whole area, then locate the part of interest using the job drawing or work traveler. The same short line can be hard to find again on a row of similar brackets. Put your observation next to a reference that the next inspector can recognize. A hole number, the marked face, or the accessible end of the seam is more useful than a general note about the part.
Keep the first view and the second view in proportion to the job. You may only need a brief look at a marked edge, or the operator may already have a fixture that takes care of side lighting. Use the bench setup that the quality team has provided. Add a handheld source only when it helps you locate or describe a visible feature and the procedure permits it.
The best flashlight for an ordinary bench inspection gives enough white light to see the area and enough control to move the reflection out of your view. Choose a slim pen light for narrow spots you can already see. For a wider view, use the approved bench light and compare portable options for permitted supplemental use.
Many inspection problems show up during jobs that require several views at once. You might need to read the work traveler, see the full face of a bracket, and look more closely at the edge of a hole. A fixed light gives you a reference while you move between those views. A small flashlight can then illuminate the one area that needs attention. Keep enough of the surrounding surface visible to tell which edge you are looking at.
If two people work the same station, check whether both can hold the light without covering its controls or putting a hand between their eyes and the part. Choose something that works while the inspector follows the assigned handling requirements. If the bench calls for both hands, use the approved fixture and stationary light. A small portable light may still help with a final view when you can hold it safely.
Published maximum lumens tell you the highest stated visible output for a particular model or mode. Olight lists a 120-lumen peak for the O'Pen 3 clip light. For close inspections, also check the lower white settings and look at glare on your actual bench. The best usable setting preserves detail across the area you need to see.
Lumens describe the light leaving the source. They cannot tell you the illumination at the surface without knowing how the beam lands there. A concentrated beam can leave one bright patch and a poorly lit area beside it. An even field can make it easier to compare two surfaces. Read the mode description to understand the equipment and use the station's approved check if the work sets an illumination requirement.
Finish by comparing the view you get in normal use. A bright reflection can hide a feature on glossy paint or polished metal. Moving the light or using an approved lower output can help keep the highlight out of the view. If the task then becomes too dim to see the edge clearly, stop and check the fixed setup or ask the responsible inspector for the next step.
Choose a pen light by the position you can safely inspect from, the control you can identify without looking away from the part, and the white settings it offers. Check its grip, carry method, charging process, and any tool-control rule at your station. A plain white-light design can make equipment selection easier where extra modes are unnecessary.
Test the handling question on a generic finished part that the team has cleared for bench use. Can you aim at the edge while standing in the position the fixture allows? Can you put the light back in its assigned place without laying it on the part? Does the switch fit the way people use the bench? These checks help you find awkward handling before a real inspection depends on repeated observations.
For stations that share inspection equipment, look at how the light will come out of storage and return to it. A clear home for the light makes it easier to check for a missing item before the next job. If personal equipment is allowed, confirm the charging and handoff process with the shift lead. A battery indicator can be helpful, but an easy replacement arrangement often matters more when the next inspector needs the same setup.
The American Welding Society's public preview of its 2015 Guide for the Visual Examination of Welds describes a guide that covers surface conditions and equipment among its topics. The job itself establishes which instructions and acceptance criteria apply. Find the current drawing, process document, customer specification, or inspection instruction before deciding how to document a visible concern.
If the requirement says only “visual inspection,” check what document defines that step. The work traveler may point to an internal procedure or a customer document that includes conditions this page cannot determine. Ask the responsible quality lead about any missing instruction before treating a portable light as part of a formal check. Record the document revision and the inspection stage in the places your facility already uses.
Where your procedure requires an illumination check, use the instrument, location, orientation, and method it calls for. A reading taken on a bare section of workbench alone may leave the actual inspection surface unaccounted for. The relevant surface might be at a different angle, under a fixture, or partly shaded by the part. Ask the quality lead which plane to document when the procedure leaves that question open.
Keep illumination records distinct from product specifications. A quality record can identify which shop lamp and handheld mode were used, the approved setup, and the actual instrument reading if the task requires one. Enter a measurement only when it was taken under the proper procedure. A product's published maximum lumens can help inventory the device and identify its mode. It does not provide a reading for a finished part.
Think about who must make a formal decision. A worker can report a visible feature and refer it to the right inspection step. The person accepting the part follows the approved criteria and uses the required instruments. If a seam appears irregular or a paint surface has an unexpected texture, describe the place and conditions that made the feature visible. Hand over the observation with the part status so the next person can locate it independently.
Locate a visible change on a cooled weld
On a weld that has cooled and been released to the inspection station, find the seam and the accessible side specified by the job. Look first under the normal bench light so you can recognize the start, end, and surrounding surface. When the procedure permits a second light, direct it across the surface from a low angle. An uneven edge or small opening can cast a shadow that makes it easier to locate.
A useful report can describe what a second person can find. For example, “A small dark opening is visible beside the seam on the marked face near the end with the locator hole.” That tells the next inspector where to look without assigning a defect type by sight alone. Write down any obstruction or surface condition that blocks a full view. Preserve the workpiece and use the site's follow-up instead of scraping or cleaning the feature on your own.
Take care with polished metal and textured seams. A bright spot may move across the workpiece as you move the beam, while a visible edge often stays in the same location. Comparing two viewpoints can help you describe that difference. A completely inaccessible surface has no observation to report beyond the access limit. Use the inspection route provided for that workpiece if a review of another face is necessary.
Separate paint texture from paint color
The NIST chapter on color and appearance explains that some materials look different under changing illumination and viewing conditions. That is common enough to plan around at a finishing bench. A highlight can emphasize a surface feature, and a change in the viewing position can alter the appearance of a finish. Use a consistent approved reference for the property the job actually asks you to judge.
On a cured panel released to the applicable bench, an oblique view can help the team locate a change in texture around an edge or between two ordinary reference points. Start from the normal viewing place and check whether the feature can be located again from another permitted view. Record the area or edge. Keep the comment about visible texture separate from a color assessment and any decision to rework the surface.
For color, use the designated viewing setup and the approved comparison sample. Both pieces need the conditions specified by the job. If one was under a room fixture and the other was lit by a handheld light, the observations came from different conditions. Set the pen light aside for the approved color check. Record the sample or lot reference so the next reviewer can confirm which target you compared.
A light's white appearance alone tells little about how it will show each coating. Labels such as warm white and cool white describe the light's own appearance. A finish may look different under another specified source, especially when it has a directional effect. If the lighting station is unavailable or the reference is missing, follow the normal hold procedure and name the missing condition in the record.
Work with cured parts that have been released to a permitted, ordinary inspection area. The 2025 annual CFR version of OSHA's spray-finishing rule addresses portable lamps in covered spraying areas and restricts them during spraying. Follow current applicable requirements and site restrictions. Keep the consumer lights discussed here out of spraying and classified areas. Use the station the facility has approved for inspection.
Confirm what you can see at a machined edge
A hole mouth or slot can disappear into shadow when a part sits flat against a dark backing. A permitted light behind a visible edge can show more of the outline if the fixture leaves a clear view. A side light can make a small raised area easier to locate. Keep the part secured and keep hands away from any edge the facility has identified as sharp.
Avoid using a fingertip to search a sharp edge or trying to push the light into a blind hole. The useful first step is to locate the visible area and describe where the line or raised feature appears. A good record can say which face was examined, what the normal fixture obscured, and whether the outer edge was visible. If the job calls for a burr limit, inspection of the inner wall, or a dimension, use the approved follow-up.
Standardize the orientation description. On a small lot, “near hole one with the part label facing up” can give a practical reference. If the station numbering puts feature names on the drawing, use those names. That helps when the next reviewer works from a photo, an identical part, or a different shift. Record the visible result while the approved setup is still in place.
Leave the bench set up the way the approved procedure describes. A clean mat, a work traveler in the same place, and a known orientation can save time when two people have to check the same part. Keep the approved reference sample within reach if it belongs to the task. Use the current version of the reference. A sample rejected for use may have a similar appearance and still lead to a different conclusion.
| What to log | What to keep | Example |
| Release | Station and part cleared for view | Cooled coupon in assigned fixture |
| Part location | ID, face, and nearby feature | Marked face at locator hole |
| Light and view | Approved light and viewing position | Bench light, added side view |
| Observation | Visible shape or limit | Short line under mark, partly shaded |
| Handoff | Held status and next owner | Refer to assigned inspector |
The short line in the sample record has no assumed type, depth, or measurement. The note locates it and leaves a visible access detail for the next station. If the relevant quality plan calls for a photograph, take one that includes both the feature and a recognizable reference. A tight crop can preserve detail. A wider view helps a reader place that detail in the assembly.
Use the site's document controls for images and customer records. The person receiving a photograph needs to know the asset and face it shows. Add the reference to the record even if the name is already printed on the part. A mark outside the frame can still identify the right orientation in the written note. Avoid sending informal copies with names that will disappear when the next shift opens the work order.
When the bench lighting is changed or a lamp has been replaced, record what changed if the procedure calls for a comparison with previous work. A different fixture can put a highlight in the center of the part. The approved comparison may need the original setup or a new baseline required by the quality team. Log the change without trying to match it by turning the portable light up or down.
Separate equipment notes from the disposition. For example, if the station's approved lamp is unavailable, attach that condition to the hold record and tell the responsible person. The shop then has a clear reason for the hold. A portable light might let a technician locate the affected area for documentation while the part still waits for the required setup. That is a useful division of work.
When two inspectors disagree about a mark, have them first agree on which surface and reference image they are discussing. Thin shadows can move as a small light crosses the edge of a fixture. If each person was looking at a different edge, the first useful correction is the record that points them to the same spot. Give the next person the part orientation and any fixture contact that blocked the earlier view.
The production team may give a reworked part a new traveler entry while keeping the original part number. Look for the current status before comparing an older image with the present surface. Where the records retain earlier views, use the record number or date alongside the face name. Write the new observation under the current step so an incoming reviewer can tell when the feature was seen.
At a finishing station, keep the designated sample with its label visible during the handoff. Two panels may have similar shades while representing different finish codes, or a familiar sample may belong to a different customer. Use the reference specified on the job. If its label is missing, record the missing reference and hold the appearance judgment until the responsible person resolves it.
If the inspection area already has an approved lamp, choose portable equipment for a small remaining task. A pen profile helps when a deeper grip would block the light or your view. A flat compact flashlight can suit a separate quick look from farther back at the same bench. The choice can change with the fixture, the part, and the way the operator safely holds it.
The Olight guide to pen lights at work explains why different job roles use different small-light shapes. At a quality bench, the need is a deliberate, repeatable view of a feature. Plan storage around that task. A light that disappears into a pocket at shift change can leave the station without the same reference for the next lot.
Use each product's ordinary white source for this work and keep the other light sources off. Follow the product's eye precautions and keep the beam away from people. If your employer specifies a white-only tool, use that approved equipment. The uses below are limited to ordinary, nonclassified work areas that permit these products and have the required fixed lighting or inspection setup.
The official O'Pen 3 charging image shows the product in several familiar storage and charging settings.
The separate charging image helps show where the cable belongs in a small kit. Give rechargeable equipment a defined charging location outside the inspection area as the workplace permits. At a shared station, include the cable and storage slot in the end-of-shift check. That makes it easier to have the same white-light option ready when the next lot arrives.
Check whether the smaller pen profile or the flat handheld feels more stable while you view a permitted sample under normal bench light. Use the assigned protective equipment and keep all fixtures in their known state. When the larger light's highlight takes over the view, change its position or return to the approved fixture. The point of the light is a clear look at the same surface the next person will have to find.
- November 19, 2026: Reviewed the public AWS preview, NIST appearance chapter, annual CFR source, U.S. product pages, and three exact product images.
