TL;DR: Pack for the longest gap between resupply stops you can confirm. Carry a headlamp, a separate backup light with its own power, a compact repair tool, and a whistle you can reach while wearing the pack. Choose the pack around your loaded kit and check each trail segment before leaving town.
- 1. Build the kit around the next trail segment
- 2. What are the best backpacking packs for thru-hiking?
- 3. What should I pack for a thru-hike?
- 4. What size backpack is best for thru-hiking?
- 5. Plan lighting for starts, camp, and delays
- 6. Compare a rechargeable main light and an AAA backup
- 7. Choose a small tool for an actual repair job
- 8. Verify what the next town can actually provide
- 9. Pack resupply boxes for items you can safely wait for
- 10. Let the trail manager shape the itinerary
- 11. Frequently asked questions
A thru-hike puts the same gear through many short trips. Before leaving a town, know where you expect to sleep, which services you have confirmed, and what you will do if you arrive after closing. Work out which items stay with you for that entire segment. A spare source of light matters most when the main one runs down and your next stop is still hours away.
| Trail job | What to carry | Check before leaving |
| Set up camp or read a map | A hands-free headlamp | Charge, condition, and the setting you use most |
| Cover a main-light failure | A separate backup light | It works with the spare power you carry |
| Trim a patch or loose tape | Scissors or the repair tool your kit calls for | It handles your actual repair materials |
| Get someone's attention | An accessible whistle | You can reach it wearing your loaded pack |
Do this check with the pack you expect to carry, including the next food and water load. If an item lives under a dry bag and a full food bag, its role should match that access. A spare cable can wait until you are stopped. A backup light should be easy to find when you're standing beside your pack and the main lamp is out.
The National Park Service's trip planning guidance includes essentials for navigation, changing weather, illumination, and emergencies. Its guide also suggests a whistle and points out that a phone can lose service or run out of charge. Carry the basic systems that fit your route before tuning the size of any individual device. That planning starts with the National Park Service Trip Planning Guide.
Look for a backpack that fits your torso and carries the weight you expect at the start of your longest leg. Try it with your shelter, sleep system, rain gear, food storage, full water load, and equipment in place. Compare access to layers and light while wearing the pack and during a short loaded walk.
The loaded walk can answer questions a store shelf can't. Can you tighten the hip belt without running out of adjustment? Does a shoulder pocket interfere with the strap or make the main light hard to reach? Do you need to put the pack down to get the whistle? Pay attention to the place where you normally stop to put on rain gear. A bag that carries well in a shop can still be awkward beside a muddy trail if you have to set everything out.
Choose a return or borrowing arrangement that lets you check the fit with your real gear where possible. Be consistent about what you load into each pack you try. Otherwise a smaller pack may feel better simply because you left out the food or water that made the heavier model uncomfortable. If you expect a seasonal change later in the trip, talk through that new load before relying on the same pack to carry it.
Carry a shelter, sleep system, weather layers, navigation, water treatment, food, first aid, illumination, repair materials, and the emergency equipment your route calls for. Add a portable light you can use hands-free and a backup that works separately. Check each leg's expected conditions, water and camping arrangements, and where you can actually replace or recharge equipment.
A useful packing list tells you where an item lives and when you check it. Add the spare battery to the same inventory line as the backup light, even if you store them in separate protective places. Keep your weather layers easy to reach so you can make a change before a delay becomes uncomfortable. Arrange prescription and other personal essentials around the trip plan and any confirmed resupply access.
Leave a route and check-in plan with someone who isn't walking the trail with you. Record the next segment and your expected contact when the route lets you check in. If the plan changes, update your trusted contact when you can. Make sure you and that person have agreed what a missed check-in means. A loud whistle and a working light are useful emergency tools, while the contact plan gives someone a place to start if you need help.
Choose the smallest capacity that holds your full load for the bulkiest expected segment while keeping the pack comfortable and within its load range. Measure with actual gear rather than a size label alone. Make room for the longest food carry, required food storage where applicable, extra water, and cold-weather layers if that segment calls for them.
For a useful fit check, pack the actual food container you plan to use rather than a soft bag of the same approximate volume. A rigid item can change how a pack closes and where the weight sits. If the container makes the rain shell hard to reach, try rearranging the pack before deciding you need more liters. The shape and access points can matter as much as the stated volume.
The pack may feel emptier after the next resupply or after you switch to a different set of layers. Keep it fitted and adjust the contents for the leg ahead. Avoid shedding required gear to force a bag to close. If one stretch consistently calls for more room, consider whether the shelter, sleep system, or required equipment needs a different carrying arrangement and ask the appropriate outfitter or trail authority when the constraint is unclear.
Think about how you use light on a normal day. You may turn it on to find the zipper before daylight, switch it off for most of the walk, and use it again to pitch a shelter after a delayed arrival. Short tasks and sustained route lighting draw on the same battery in different ways. The brightness you use for the longest blocks matters more for planning than the highest setting printed on the box.
Use the hands-free headlamp where holding the light would get in the way. Adjust it before you need both hands. Around camp, keep the beam low enough for your task and away from other people's eyes. If you need to look up to speak with someone, lower the lamp or turn it off first. A readable map, a visible tent buckle, and a section of trail lit farther ahead can all call for a different setting.
Plan toward safe daylight travel where possible. If you are behind schedule and the next stretch is unfamiliar or difficult, use your map and plan to reconsider, turn back, or stop where permitted. A brighter headlamp is useful only within a safe route decision. Put your alternate campsite or exit point in the plan before you need to look it up under pressure.
Keep an outdoor flashlight or other independent backup where you can find it without the headlamp. A small handheld backup can be handy for close tasks like checking the buckle or finding a spare cord in a pouch. For an itinerary where your usable backup may need to leave both hands available, choose a second suitable hands-free light instead. Think about how you would actually stop and operate the backup safely if your main light failed.
A spare lamp can fail alongside the main one if you keep both in the same unprotected pouch. Choose separate accessible positions and follow the manufacturer instructions for protecting devices and cells. Let equipment and charge points dry as directed before charging. Check that nothing presses a switch while the equipment is packed and use the light's documented carry or lockout method where provided.
If you share gear with a hiking partner, each person can check whether they can use their own light and find a backup without borrowing the other's pack. A group kit is convenient when everyone is together. It does little for someone who stops to retrieve a layer while the other person walks ahead. Agree on how you will stay in contact and where you will regroup before heading into the next section.
Keep cold-weather access in mind when arranging small items. With gloves on, it can be harder to find a little ring in a deep pocket or distinguish two identical pouches. Use storage you can recognize without pulling out everything else. Try this at home with the layers you intend to carry, and improve the arrangement while you still have time to make a change.
There are two jobs in this comparison. The main light covers repeated hands-free tasks. The backup supplies short local light if the first is unavailable. Weight and runtime figures help describe each device, while your longest gap without a charger or store decides how much independent power to carry.
| Light | Published operating details | Resupply check |
| Perun 3 Black | Olight lists 150 g with battery and 89 hours in 30-lumen Low. Magnetic MCC3 charging. | Confirm access to a power source and carry the matching cable |
| i3E EOS Summer Palm | Olight lists one AAA cell and 90 lumens. Twist control. | Carry a compatible spare and verify actual town stock |
The Perun 3 manual labels its 150 g figure as including the battery. Weigh your full setup with the headband, cable, and protective storage if total carry weight is part of your decision. The Low runtime is a manufacturer rating for that specific setting. Weather and the levels you actually use matter. Keep a reserve and check the charge before the next extended stretch. The i3E EOS has a different operating role, so the two rows cannot tell you how many nights you will get from your own kit.
A useful first trial happens near home. Use the same headlamp, charging cable, and backup setup you plan to carry. Try ordinary campsite tasks and check which white level you end up using. Then pack it away and find it again without another person shining a light into your bag. Record what you learned about access and charging. Treat that as a fitting and setup exercise before your next practice outing.
If power is tight, look at your electronics together. A map device, phone, or approved satellite communicator may need independent power for navigation or check-ins. List the cables and appliances supported by any backup bank during trip planning. Recharge in a permitted safe place at the trailhead or in town and avoid relying on one short stop that might not have a working outlet.
Start with the pieces you might need to mend. A spare buckle may fit one pack and serve no purpose on another. A short piece of compatible repair tape can close a small tear if the maker allows it. Scissors can trim that tape or a loose end while you're stopped at camp. Put the working materials next to the tool when you practice so you can see if anything is missing.
Think about how you would store the tool between uses. It should close securely and go back in a known place after a repair. A pouch can also keep a small tool from catching on a shelter or pressing a light's switch. A check at home with tape, a spare fastener, and the gear you own usually tells you more than the number of functions printed on the package.
A gear repair can call for a part or method a pocket tool cannot provide. A failing buckle on an essential pack, a big shelter tear in deteriorating weather, or a water treatment device you cannot restore should prompt a fresh route decision. Decide when to turn back, seek help, or reach confirmed replacement supplies. A compact repair kit is most useful when you know what it can handle with your gear.
Write down the next stop that can cover each need. A supermarket may have food without the exact spare cell you use. An outfitter may list equipment but open after the morning shuttle departs. Confirm hours and the connection between the trail, town, and back before choosing that stop for anything urgent. Where possible, ask about the particular item and carry a working spare until you know how you can replenish it.
Set a departure check that takes only a few minutes. The headlamp turns on and the strap is intact. The backup turns on and its spare remains with you. The charging cable and the right power connection are back in the pouch. The whistle is reachable when the pack goes on. If the next stop falls through, you know which alternative the plan allows. An unchecked cable left at a hostel can be more disruptive than a short published runtime.
Choose a conservative trigger for replacing a used spare. It may be convenient to wait until the final store before a longer leg, but it gives you one fewer fallback if that store is closed. On a route where you can replace an item one town early, consider doing the check while you still have options. Separate the small supplies that are easy to buy from the exact piece that only your setup can use.
Revisit this plan when the seasons or travel hours change. Shorter daylight can make ordinary camp jobs more dependent on light. A damp stretch can change how you protect charge ports or spare cells. A route change can shift both travel time and the supply stop you were counting on. Before leaving a confirmed town, compare the next leg with the list you made at the previous one.
Keep a short record after a longer stay in town. Note which battery or cable you replaced and which shop actually had it. A planning spreadsheet can retain old listings long after an item sells out. Treat notes from your own last stop as dated and use the same confirmation process for each new one. Share the exact model or connector if someone else is helping check stock.
When a power bank is part of the plan, inspect the cables you really used before packing them. A worn connector or cable that only charges intermittently is worth addressing while another option is available. Give each item its own place in the bag as you put it back. If your main light and phone use different cables, check both instead of counting the number of cords in the pouch.
Use a box for planned items you can replace on a regular schedule. Think of fresh repair tape, a clean spare headband, or a cable you intend to swap before the old one fails. Keep the working light, working cable, and necessary spare power with you while traveling. If pickup is delayed, you should still be able to light your camp and follow your revised itinerary.
Ask the actual recipient what it accepts, how to label a package, when pickups are possible, and what happens if the package arrives early. A post office and a private host may follow different rules. In Yosemite, for example, the National Park Service identifies specific post offices as food resupply points and says ranger stations do not accept food packages. The example is explained on the park's John Muir and Pacific Crest Trails page.
Packing spare batteries or a power bank creates another decision. Check the current carrier rules for the exact item, its chemistry, and how it is shipped. Confirm the requirements with the carrier before putting anything that contains lithium cells into the box. The U.S. Postal Service shipping restrictions describe categories of restricted materials and direct senders to its detailed mailing requirements. If you cannot verify a particular shipment, plan to acquire or carry the item by an approved method.
Make a short list for anyone helping you send a box. Give them the recipient's current address and instructions, the approximate need date, and a way to confirm details if your route changes. A small envelope or part should be easy for the recipient to identify. Mark your own checklist when you actually pick it up, then confirm the new item fits and works before you leave town.
A weather delay may change the timing of a delivery without changing your need for the gear. Check the next opening or pickup period while you still have a safe route choice. If you're mailing a replacement for an item that's starting to fail, decide what you will do if you cannot pick it up. A packing plan is more practical when you can change a stop without losing a safety essential.
Long-distance trails cross different areas. Each manager can have different camping, food-storage, or access requirements. On the Appalachian Trail, the National Park Service basic information page distinguishes walking on the trail from permits that may apply to some overnight or parking arrangements. Check the specific land office or park where you plan to stop. Your permission to walk along one section gives you little information about where you can sleep that night.
Pacific Crest Trail arrangements can also change by land unit and campsite. Yosemite describes particular conditions for PCT long-distance hikers who camp along the trail inside the wilderness or travel off it. Carry the equipment and current documentation required for your own segment. For the Continental Divide Trail, the Bureau of Land Management trail page directs visitors to the appropriate management offices for updates. Use the responsible office for restrictions and recent conditions before you count on a route.
Leave room for ordinary changes. A source of water, a scheduled ride, or the timing of a permit can become the most important constraint in your plan. Review the itinerary and gear together. An extra light can help while you're organizing equipment at a permitted stop. A known alternate route gives you an option when the first plan no longer fits your daylight or conditions.
Olight's backpacking gear checklist covers the wider kit. Use it when assembling the first pack, then apply the route and resupply checks above to your lights and repair tools. Keep your initial inventory flexible. At the next stop, record what you actually used, what was hard to reach, and which safety items you need to carry into the next set of conditions.
If you change the order of stops, update your list before sending someone new instructions about a package. Check which part of the route now has the longest unsupported stretch. A pack can still have the correct capacity while the reserve inside it is wrong for the new timing. Confirm your backup light, communication plan, permits, and water plan for the revised leg before deciding to leave.
At the end of a section, write down one gear access problem while you can still remember it. That might be a repair pouch you could not reach without unloading food, or a flashlight that slipped deep under a warm layer. Move the necessary item to a position you can check safely. Keep the route essentials in the pack even if they had little use on the previous leg.
- November 19, 2026: Checked official trail planning, resupply and mailing sources, four U.S. product listings, and all four main product images.
