A headlamp for workers should provide a useful mode for the time it is actually needed, fit alongside the assigned protective equipment and use a charging plan the team can maintain. Start with the job and shift pattern, then compare the manufacturer's mode-specific runtime, controls, mounting and water-protection instructions.
| Work requirement | What to check first | Practical decision |
| Long inspection shift | Runtime at the mode you expect to use | Plan for breaks, charge access and an approved backup |
| Close maintenance task | Beam width, lower settings and glove operation | Choose a comfortable beam and controls the wearer can operate |
| Work with a hard hat and eye or hearing protection | Employer-approved mounting and the helmet maker's instructions | Confirm the combined setup before the shift |
| Rain or sweat exposure | The product's stated water rating and care instructions | Keep charging contacts dry and inspect the strap and light |
| Classified hazardous location | Site classification and the exact equipment approval | Use only equipment approved for that location and task |
The figures in our product comparison are published ratings. A headlamp is a lighting accessory, not protective headgear. Its water rating does not establish electrical protection, explosion protection or permission to use it in a hazardous location.
- 1. Choosing a Work Headlamp for the Actual Task
- 2. Headlamp Runtime for 8-, 10-, and 12-Hour Shifts
- 3. Headlamp Step-Down and Mode-Specific Runtime
- 4. Comparing Olight Headlamp Ratings for Shift Plans
- 5. Headlamp Fit With a Hard Hat and Other PPE
- 6. Work Headlamp Fit in Sweat and Rain
- 7. Headlamp IP Ratings and Hazardous-Location Approval
- 8. A Crew Plan for Headlamp Charging and Replacement
- 9. Work Headlamp Lumens Depend on the Task
- 10. A Pre-Shift Headlamp Checklist
- 11. FAQ
The best headlamp for working is the one that meets the task, the employer's equipment rules and the wearer's protective-equipment setup. Check runtime at a useful mode, beam pattern, weight, glove-friendly controls and charging. In a classified location, use equipment approved for that specific location rather than inferring approval from an IP rating.
A facilities worker reading labels in a small room may want a broad beam and an easily selected lower mode. A worker checking an outdoor area may prioritize a different beam and weather exposure. Neither needs to choose solely by the largest advertised lumen figure. Ask what the light must illuminate, how often it will be used and what backup is available if the battery runs low.
For a team, trial the proposed mounting arrangement with the actual helmet, eyewear, hearing protection and other assigned equipment before making a bulk purchase. A comfortable fit for one wearer is not proof of compatibility for everyone, and a lighting accessory must not interfere with required protection. Follow employer procedures and the equipment makers' instructions.
Separate the length of the shift from the time the light will actually be on. List the intended mode, periods of continuous use, expected breaks, and available charging or battery replacement. Compare that plan with the manufacturer's runtime for the same mode, then allow for uncertainty and maintain a suitable backup under the workplace's rules.
For example, a 12-hour shift might include several inspection periods rather than 12 hours of continuous headlamp use. Write down the intended pattern before comparing lights. If a worker expects six hours of illumination in a mode rated for four and a half hours, that rating is shorter than the planned use; the worker needs a different plan, such as an approved spare or a light with a more suitable rating. This comparison of published numbers does not establish the battery's remaining charge.
| Shift-planning question | Example decision | Why it matters |
| How long is the light actually needed? | Record the planned on-time and the longest uninterrupted task | Shift length and continuous operating time are different |
| Which mode supports the task? | Identify the useful steady output before comparing runtime | Longest runtime may belong to a very dim mode |
| When can the light be charged or changed? | Check the schedule and site-approved charging location | A charging cable is useful only if access and time are available |
| What happens if the light is depleted? | Carry or stage a suitable approved backup | Manufacturer ratings are not guarantees for every condition |
| Will gloves and PPE remain in place? | Practice using the exact controls and attachment while supervised | A bright light is less useful if the worker cannot operate it safely |
Do not divide a battery's capacity by a product's maximum-lumen number to predict an exact shift duration. Output changes, electronics and operating conditions affect energy use. A runtime stated for one mode cannot be assumed to apply to another; a very long moonlight figure is not evidence that the highest setting lasts that long.
Some high-output settings begin brightly and then reduce output. When the manufacturer lists separate brightness stages and times, read each pair together. Adding the stage times can describe the published sequence, but it does not mean the light holds its starting brightness for the sum of those times.
The Portable Lights American Trade Organization describes different test methods in ANSI/PLATO FL 1-2025 for ordinary modes and short-duration elevated-brightness modes. Check which standard and mode a particular product claims before comparing numbers. A published runtime is a measurement under stated conditions; it is not a guarantee of constant output throughout a shift.
When the work involves reading a small label or distinguishing a wire marking, the useful question is whether the planned mode and beam support that task. An adult worker and supervisor should evaluate the actual work area under the employer's procedures. Do not assume a manufacturer's maximum output or its longest low-mode runtime answers the whole question.
The figures in this comparison come from our product ratings reviewed on October 31, 2026. Each medium white-light figure applies to its own mode, and conditions can differ between products. The ratings do not guarantee constant brightness or establish that the light meets a workplace illumination requirement.
| Model and mode | Manufacturer-rated output / runtime | Listed weight with battery | Charging and mounting consideration |
| Perun 3, white medium | 120 lumens / 25 hours | 150 g | MCC3 magnetic cable; supplied headband |
| Perun 3 Mini standard, cool-white medium | 100 lumens / 4.5 hours | 54 g | MCC 1A magnetic cable; supplied headband |
| Oclip Pro standard, white flood medium | 100 lumens / 3.5 hours | 53 g | USB-C charging; clip light, not a dedicated hard-hat mount |
| Oclip 2 Pro, white flood medium | 100 lumens / 3 hours 45 minutes | 75.5 g | USB-C or magnetic charging; clip light, mounting requires separate review |
We list the Perun 3 headlamp at 120 lumens for 25 hours on white medium. That rating is longer than a continuous 12-hour example, but it is not a guarantee that the light will meet the task's illumination level or last that long in every workplace condition. Its listed weight includes the battery. Compare the headband and magnetic charging cable with the actual helmet and site rules; do not assume either is acceptable for every workplace.
The Perun 3 Mini headlamp standard cool-white version is listed at 100 lumens for 4.5 hours on medium and 54 g including its battery. If a work plan calls for six uninterrupted hours at that setting, the listed 4.5 hours is less than the planned on-time. Select a different approved configuration or arrange a suitable backup. The HCRI version lists 85 lumens at medium, so do not substitute the cool-white output for that model. The premium case has a different listed combined weight; check the exact package.
We list the standard Oclip Pro clip light at 100 lumens and 3.5 hours on medium flood, with a 53 g battery-included weight. The Oclip 2 Pro clip light lists 100 lumens and 3 hours 45 minutes on medium flood, with a 75.5 g battery-included weight. Both are clip lights with several modes; neither figure proves a 12-hour continuous task at medium output. Our Oclip Series Headlamp Strap lists compatibility with Oclip Pro and Oclip 2 Pro; the strap package does not include a flashlight. Compatibility with the light does not establish compatibility or approval for a hard hat: check the helmet manufacturer’s instructions and employer requirements before use. The Oclip 2 manual also warns people with a pacemaker or an implanted cardioverter-defibrillator (ICD) to avoid close or prolonged contact with the product to prevent possible interference.
The headlamp collection and Oclip series show different product formats. Neither a product category nor an IP rating is proof of hazardous-location approval. Confirm the exact model, battery, attachment and job requirements before choosing any of them.
Use the helmet manufacturer's instructions and workplace rules to select and position any accessory. Confirm that the suspension, helmet fit, eye protection, hearing protection and other required equipment remain properly worn. If the arrangement interferes with required protection or the maker's instructions, stop and ask the responsible safety professional for an approved option.
The Occupational Safety and Health Administration's PPE assessment guidance advises following available manufacturer instructions. A headlamp's ability to wrap around a helmet does not by itself prove compatibility with that helmet's safety certification. Do not drill, alter or improvise a mounting method for protective equipment unless the employer and helmet manufacturer explicitly permit it.
Before the shift, check the setup with the actual equipment rather than a generic photograph. Put on the required head protection, eye protection and hearing protection as instructed. Ask whether the light or strap obstructs an adjustment, pushes glasses out of position, traps a cable or prevents required equipment from seating correctly. If any piece needs to be displaced to use the light, resolve the conflict through the site's PPE process.
For a general comparison of best headlamps, check the relevant runtime and weight for each model. The headlamp comfort guide also explains fit considerations; workplace PPE compatibility must still be verified with the actual equipment and employer.
A clip light, a headband and a helmet mount are different attachment methods. The maker's statement that a light can clip to clothing or fit a headband is not a claim that it is approved for every hard hat. Choose the mounting method that the employer and relevant manufacturers accept for the particular combination, and verify that it stays secure without blocking vision or other safety equipment.
Read the exact light's water-protection rating, charging instructions and cleaning guidance; then inspect the strap, attachment and charging contacts before and after use. A water-resistance claim describes specified test conditions. It does not guarantee protection against every chemical, pressure wash, contaminated liquid, damaged seal or charging condition.
Sweat, rain and dirt can make a headband uncomfortable or affect how it sits. Follow the manufacturer's cleaning and drying instructions for the light and strap, and replace worn or damaged components according to workplace policy. If the device has an exposed or covered charging contact, follow its manual before cleaning and charging; do not charge a wet device or connector when the manufacturer instructs otherwise.
For outdoor work, store a backup and charging equipment in a location consistent with the site rules and the product instructions. A dry bag can help organize gear, but it is not a substitute for a product's own protection rating or a way to make an unsuitable charger safe in a hazardous area. Inspect the light and its mounting after an incident such as a hard fall, and remove damaged equipment from service under the site's procedure.
An IP rating describes protection against specified ingress of solids or water; it is not a hazardous-location, intrinsically safe or electrical-protection approval. For a classified workplace, check the classification and select equipment that the employer has approved for that exact location, including the relevant certification and conditions of use.
OSHA's construction rule for hazardous classified locations addresses equipment suitable for such locations. The applicable rule depends on the work and location. The Olight products discussed in this guide are ordinary lighting products; no hazardous-location approval is claimed for them. If the site requires a certified light, obtain and verify the exact product documentation through the employer before use.
A high IP number, aluminum housing, rechargeable battery or statement that a light is useful at work does not answer the approval question. The worker should not make that determination by interpreting a shopping page alone. Use the site's established selection process, including any restrictions on charging or opening equipment in the classified area.
Choose equipment around the work and site rules, then document the exact model, allowed mounting, cable or battery, charging location and replacement process. Label storage locations, make compatible backups available and assign someone to inspect the equipment. Standardization helps only if the chosen light and its accessories meet the actual job requirements.
A simple handover record can list the light's identifier, visible condition, charge status according to the product indicator, and any issue reported during the shift. It should not pretend to measure remaining runtime unless the equipment actually provides that information. If a light or mount is damaged, keep it out of service and follow the employer's inspection or replacement procedure.
Check the process with the people doing the work. A cable that fits the light but is not available where charging is permitted is not a complete plan. A headband that fits one helmet may not fit another. Where shifts overlap, agree on who checks the lights, where a replacement is kept and how a problem is reported without delaying the worker's access to required illumination.
There is no single lumen number for every task. Consider the work surface, beam pattern, surrounding light and the employer's requirements, then check the runtime for a mode that supports that work. Peak output can be useful for a short task, but it does not establish the light's output for a full shift.
A broad lower setting may be preferable for a close inspection when a concentrated beam causes glare from a reflective surface. A more focused beam may help with a distant check. These are selection considerations, not promises that a particular brightness will satisfy an employer's illumination requirements. Where a task has a required lighting level, follow the workplace assessment and applicable rules.
Before selecting a work headlamp, establish what must be illuminated and how the light fits into the site's equipment process. The following checks help a worker and supervisor discuss the complete setup, from the required light mode to charging and replacement, without relying on a single figure on the package.
- Describe the work area, the task and the expected continuous periods of light use.
- Identify a useful mode and compare its published runtime with the intended on-time.
- Check how the light mounts with the actual helmet, eye and hearing protection, following employer and manufacturer instructions.
- Confirm the controls can be operated with the required gloves without disturbing PPE.
- Read the stated water rating, temperature limits and charging instructions for the exact model.
- Confirm that the product is approved for the specific classified location when such approval is required; an IP rating is not enough.
- Arrange compatible charging or replacement equipment and a suitable backup under the workplace's rules.
- Remove damaged lights or mounts from service according to the employer's procedure.
- September 28, 2026: First published.
