If you’re a proud fan of the Baton line, you need to check out the new limited edition Baton 3 Pro Cu! Take your collection up a notch with the new elegant and classy copper addition, while still enjoying all the features you know and love from the classic Baton 3 Pro. If this powerful EDC isn’t already your favorite, the extended runtime, easy pocket-size length, and convenient features and design will surely convince you!
Brighter, Longer Runtime, and More Reliable
The Baton 3 Pro Cu boasts an impressive max output of 1500 lumens with a throw of up to 175 meters, which is an increase of 30% in both performance categories when compared to its predecessor. It has a quick charge time of 3.5 hours with the included MCC3 USB magnetic charging cable, and will run for up to 120 days between charges.. that's 4 months! Not only is it perfect for your longest work days, but it’s also extremely efficient and helpful in a power outage! The Baton 3 Pro has a sturdy build with a drop test score of 1.5 meters and an IPX8 waterproof rating, which means it can withstand being submerged in water up to 2 meters deep for up to 30 minutes without damage. This resilient EDC is at home whether stored in your pocket or subjected to the harshest of environments. It can not only do it all but still come back for more!
Unique, Comfortable Design
Weighing in at a low 6.07 ounces and measuring 3.99 inches from tail to tip, the Baton 3 Pro is perfectly pocket-sized and fits nicely into your palm. It was designed with the new body knurling that makes it non-slip and more comfortable to grip. It features the newly improved and enlarged concave side switch, making it easier to operate and decreasing the possibility of accidental activation. The wider and longer two-way pocket clip was made using thicker steel, making it more durable and less likely to deform when used. Also included in the packaging is a handy L-stand made of magnetic stainless steel and backed with super strong adhesive for storing your Baton 3 Pro, ensuring it’s always easy to find when you need it!
Hear What Other Fans Have To Say
👨Everything about this light is awesome! From the materials, brightness, and battery life to the cool look. Best work light/ edc ever!!!
👨This light is perfect for EDC and for stashing around the house with the steel L bracket. I have them hanging in several rooms for easy access when the need arises!
👨Long battery life and stylish design and grip are nice features.
👨This thing packs a punch to be such a small pocketable light. Might just have to pick up another one.
👨It’s a great light the color was awesome and it feels really high quality. Very bright!
Learn More👉👉Click Here!
Final Thoughts
The Baton 3 Pro Cu is versatile and capable of a multitude of uses! From the perfect EDC pocket-carry flashlight, storing on your nightstand in case of a power outage, to taking it with you on your next hike or outdoor adventure, you’ll be amazed at how often you reach for it! The new copper will look so sharp attached to your belt, while still being tough enough to stand up to the elements! Don’t sleep on this limited edition..make sure you add it to your collection before it’s gone!
