Olight’s 15th anniversary is coming! We have created many special memories in the past 15 years and sincerely appreciate the continued support and help from the O-Fans. Your support is our constant motivation. Let us celebrate this special day in full swing with Olight through these brand-new flashlights and gifts. The 15th anniversary is just a milestone in the development of Olight. For Olight, this is a new beginning. Here's a brief introduction to each of the new models, unveiled as part of the Olight 2022 15th Anniversary flash sale.
iXV Keychain Light
To honor our customer's support, we prepared an exclusive gift -- a 15th-Anniversary Edition product that features a special design to symbolize Olight's 15-year history. iXV is based on i1R2 Pro, XV is the Roman Numerals: 15. There are two versions available, a coral blue version and a special Titanium edition. As a keychain light, the iXV is a practical rechargeable USB-C EDC with 180 lumens, specifically featuring a neutral white LED (5,000K). It’s a simple twist of the head, users can turn the light on/off and switch outputs. Of course, the IXV has a hidden design(five grooves on the upper body and 10 grooves on the lower body). The vertical fluted lines carved in the body allow for a useful grip, while also being very attractive.
Warrior 3S Tactical Flashlight
The new tactical flashlight: Warrior 3S retains all the features of the Warrior 3, such as tactical mode, lockout mode, reversible pocket clip, and compatibility with locking remote switches.
The newly adopted proximity sensor proactively drops the brightness level in case of obstruction, ensuring safe use while maintaining high performance to guide you through any situation. There are two versions, regular black and always popular gunmetal gray. Olight new tactical flashlights Warrior 3S has a fully integrated proximity sensor, and the light's safety has been increased, with absolutely no decrease in the lights' practicality or utility.
As the newest model to incorporate a proximity sensor, Olight has seamlessly integrated this safety feature, without compromising the beam pattern, or performance in any way. The Warrior 3 maintains its 2,300 lumens of max brightness and 300 meters of throw. The sensor, which is visible in the head of the light, has no perceptible impact whatsoever on the signature round hotspot of the Warrior 3s. The sensor is only active in high and turbo output settings. When active, the sensor drops the output to medium brightness when it detects an obstruction in front of the lense. This prevents the light from overheating if it's turned on in a pocket accidentally, or in any scenario where the light is left on and placed face down near any surface. It also helps avoid light bouncing back into your eyes and blinding you as you're using the light.
Then, Warrior 3S has also updated the design of the front bezel, it has become smoother and less aggressive strike, which is very suitable for daily carrying.
Odin GL Mini Weapon Light
The Odin GL Mini is compact white light and GL beam combo for Picatinny rails and inherits many of the great features from our popular Odin series. It’s perfect for home defense, hunting, law enforcement, etc.
Fully compatible with Olight's remote switch(sRod-7), the Odin GL Mini comes with all the mounting hardware required to attach to your firearm's Picatinny accessory rail. It also comes with an adjustment key to sight in the green laser. The Odin mounting system allows the light to be quickly released, and with the optional Finger Grip Ring, you can rapidly transition from a light installed on your rig, to a compact handheld light/laser combo which is a very unique capability. It also uses a custom-sized battery(2040mAh 18500 battery ) to allow the light to reach its performance goals while maintaining a small footprint. It can easily be charged via the included USB magnetic charging cable. The peak brightness is 1,000 lumens. The second of two brightness settings is 200 lumens, which will run for more than 3 hours of maximum runtime.
The brand new Odin GL Mini can fit your specific need. You also can have a full-featured, powerful, and reliable weapons light now!
Warrior Mini 2 Cu EDC flashlight
The brand new Warrior mini 2 Cu is made of copper, allowing it to record subtle traces of your life while developing a unique patina texture specific to its users. The Warrior Mini 2 has been made in many configurations before. Some have been very exclusive, so the Warrior mini 2 Cu can offer the opportunity to add this exclusive Warrior Mini 2 to your collection.
This CNC machined copper Warrior mini 2 begins its life will be shiny as a star, but gently over time, it will become a unique heirloom. Reacting to your hand as you use it, and reacting to the environments in which it serves, it creates a patina all its own which makes the Warrior Mini 2 Cu an accessory that grows with you over time, there can be no doubt that it is yours.
The advantage of copper light is heat dissipation. Aluminum lights can accumulate heat in the head of the light, where the heat is produced. A body made from copper is a conductor of energy, which disperses the heat evenly along the length of the light. This is good for usability, as the light does not get hot. And good for longevity, as the electronics inside, are protected from excess heat. So don't miss it, because it is sure to sell out fast.
Open Pro Brass Bark
The Open Pro is a penlight durable and lightweight for everyday carry, adventuring, patrol, etc. Now, coming in a brand-new beautiful and collectible color-Brass Bark. The Open Pro(2-in-1 penlight)is separable into two parts, giving more flexibility for nighttime or backup lighting. For Olight, Brass has been one of the most highly requested premium metals. It was only a matter of time before Olight released a pen made of this material, so popular in the industry. After the release of the Open Pro in Zirconium, Titanium, and Brushed Copper, the next logical step is what we see before us. Of course, it’s Open Pro Brass Bark. Its complex and interwoven Bark pattern give the holder a sense of connection with nature, through its texture, and through the unique feeling of brass in the hand.
i3T Plus Ancient Bamboo
The i3T Plus Ancient Bamboo is crafted with the perfect balance of space, time, and precision, each i3T Plus Ancient Bamboo is manually aged with fire and water to make every piece unique. For the i3T Plus Ancient Bamboo, Olight is the first to try this unique technology. We wanted the perfect combination between flashlight brightness and flexibility. In order to display its proud cultural heritage, the bamboo texture is CNC engraved into a solid raw copper body. The thin body of the light, paired with the gentle swells of each ridge, and the detailed vertical texture, make this an absolute pleasure in the hands. Truly a light that is as enjoyable to hold in your hand and gaze upon, as it is to carry and use. Don't miss out on this beautiful and unique pocket jewelry.
These are the new release products, but there are more discounts are waiting for you. We have prepared many activities and limited edition prizes. And All access begins on April 21st at the same time. Thanks for your reading and enjoy the sale!
