Choose between Olight's Seeker Ultra and Seeker 4 Pro by comparing the settings you expect to use, the light-and-battery weight you will carry and the complete holster arrangement. Seeker Ultra adds an OAL body and a larger battery, while Seeker 4 Pro offers a shorter, lighter standard configuration. Their higher-output sequences differ enough to deserve a closer look before choosing by maximum lumens.
Both are rechargeable handheld lights with a metal rotary side control and a vertical holster that also participates in charging. This comparison concerns the Seeker Ultra Olive Green and the ordinary Seeker 4 Pro Matte Black cool-white configuration. It separates their published differences from functions they share, so you can decide whether a particular change addresses your own use.
- 1. Identify the Seeker Ultra and Seeker 4 Pro Configurations
- 2. Compare the Size of the Light You Will Actually Carry
- 3. Keep the OAL Material Comparison Within Its Published Scope
- 4. Which Seeker Lists More Time at 1,200 Lumens on High?
- 5. Put Turbo and Lower Modes Beside the High Comparison
- 6. Read Each Battery Label With Its Own Flashlight
- 7. Compare Rotary Controls Through the Task at the Switch
- 8. Read Brightness, Battery and Lock Information Separately
- 9. Treat the Holster as Part of the Everyday Setup
- 10. Can Both Seeker Lights Charge Through Their Holsters?
- 11. Match the Carrying Arrangement to the Work That Remains
- 12. Choose the Light-Source Version Before Finalizing the Comparison
- 13. FAQ
The Seeker Ultra listing from Olight identifies an Olive Green model with a proprietary OAL body, a 5,800 mAh battery and cool-white illumination. The Seeker 4 Pro page includes several selections. Matte Black CW supplies the standard cool-white reference used here. Keep that selection attached to the dimensions, battery and weight when comparing the two lights.
This matters particularly with Seeker 4 Pro because its technical information also identifies a 350-gram Silver-Plated Bronze configuration. The ordinary configuration is listed at 205 grams including its battery. Assigning the heavier figure to the Matte Black light would create a misleading size comparison before you had considered a single task. An exterior finish can therefore require a separate specification check even within one product family.
The table keeps the main comparison on one consistent basis. Its weights include the battery in the flashlight. A holster, cable, bracket and the bag holding them add to the equipment you take, so the figures are useful for comparing the two lights themselves rather than describing every complete carrying arrangement.
| Published specification | Seeker Ultra Olive Green | Seeker 4 Pro standard CW |
| Body material description | OAL proprietary aluminum alloy | Aluminum alloy |
| Light weight including battery | 220 g | 205 g |
| Published length | 138 mm | 133 mm |
| Head or overall diameter entry | 35 mm in the overall dimensions | 35 mm head diameter |
| Battery label | 5,800 mAh, 3.59 V, 20.9 Wh | 5,000 mAh, 3.6 V, 18 Wh |
| Maximum output | 4,800 lumens | 4,600 lumens |
| Listed beam distance | 265 m | 260 m |
| Charging arrangement | USB-C through holster or optional MCC3 | USB-C through holster or optional MCC3 |
Seeker Ultra is five millimeters longer and 15 grams heavier than the standard Seeker 4 Pro, using the published light-and-battery figures. Assess those differences against the space available for your flashlight. A slim compartment that already accommodates the shorter light may offer little spare length once its closure, lining and neighboring equipment are included. A larger compartment can make the same difference unimportant.
Compare the head opening separately from the length of that compartment. Seeker 4 Pro lists a 35-millimeter head and a 28-millimeter body. Seeker Ultra's dimensions are presented as 138 by 35 millimeters. That overall diameter entry should stay an overall dimension when checking space. It does not establish that the Ultra has a 35-millimeter cylindrical body throughout its length.
A holster also changes the outline that must fit. For a light worn on a belt, consider the holster's placement and the room needed to remove the light. For a light carried inside a bag, consider whether you will put the holster in that compartment too. Comparing only the flashlight's diameter can overlook the component that actually contacts the bag or clothing during removal.
Seeker Ultra's US description identifies Olight's proprietary OAL aluminum alloy and compares its hardness with standard 6061 aluminum. It describes resistance to scratches and wear. That gives an owner a specific body-material feature to consider when a light regularly travels beside ordinary equipment or is frequently handled during outdoor work. Keep the comparison attached to the material and the reference named in that description.
Seeker 4 Pro's technical table identifies its body as aluminum alloy. That wording does not specify 6061 for the selected light. The published reference does not establish a numerical hardness comparison against Seeker 4 Pro. Choosing between these two models does not require assigning an unstated alloy to one of them or predicting a precise amount of cosmetic wear.
Also distinguish the body from the surfaces you touch. Seeker Ultra's description identifies a crocodile-textured silicone grip, while Seeker 4 Pro's product details describe a wrap-around silicone grip. The material surrounding the body and the control position both contribute to the handling arrangement you should examine. A body-alloy claim cannot establish the feel of either grip with your particular hand or glove.
Seeker 4 Pro lists the longer initial 1,200-lumen High stage, at 135 minutes compared with 23 minutes for Seeker Ultra. Ultra then lists 1,000 lumens for 140 minutes, 600 lumens for 65 minutes and 300 lumens for 15 minutes. Seeker 4 Pro follows its initial stage with 600 lumens for 35 minutes and 300 lumens for 10 minutes. Keep each published level beside its corresponding duration.
That creates a meaningful choice for someone examining the published working levels. The 4 Pro row assigns more time to its initial 1,200-lumen stage. Ultra includes a separate, longer 1,000-lumen stage before reaching 600 lumens. Decide which part of each published sequence concerns the task you are planning. Ranking the rows by either their first number or their combined duration alone leaves out that difference.
Ultra's Turbo entry is 4,800 to 1,000 to 600 lumens for 2.5 plus 150 plus 70 minutes. Seeker 4 Pro's is 4,600 to 1,200 to 600 lumens for 2.5 plus 122 plus 35 minutes. Both list a short first stage. The different following levels explain why the higher maximum and the longer listed sequence should be considered separately when selecting a light.
The lower settings provide a simpler, same-output comparison. Both list Medium at 300 lumens, with 12.5 hours for Ultra and 11 hours for 4 Pro. Low is 50 lumens for 69 and 60 hours respectively. Moonlight is 5 lumens for 17 and 15 days. Choose the useful output first, then read the applicable duration beside it.
For someone mainly using 300-lumen Medium, the 1.5-hour difference in the published entries is more relevant than the 200-lumen difference between maximum outputs. For another person making only brief nearby checks, the useful distinction may be elsewhere in the design. None of these rows supplies an individual remaining-hours countdown after a mixed session of use.
The maximum beam specifications add another comparison. Ultra lists 17,600 candela and 265 meters, while 4 Pro lists 16,895 candela and 260 meters. The five-meter difference is a difference between their published beam-distance ratings. For a user checking the surrounding ground or equipment, the actual detail that needs to be seen remains part of the choice. A rated maximum cannot establish recognition of a particular label, obstacle or distant object.
For close work, consider the scene around that detail as well. A nearby pale surface and an object farther behind it can require a change of aim or position before another increase in output. Comparing these two models by maximum reach alone would leave that viewing problem unresolved. Use the published beam figures alongside the intended distance and the chosen ordinary setting.
The Ultra manual identifies a 5,800 mAh, 3.59 V battery rated at 20.9 Wh. The 4 Pro manual identifies a 5,000 mAh, 3.6 V battery rated at 18 Wh. These labels describe the respective supplied rechargeable lithium-ion configurations. They provide another reason to compare the battery and light together instead of treating the two bodies as identical housings around one interchangeable power source.
The shared 21700 size description does not establish cross-model replacement compatibility. If you are choosing a second light because you already own spare equipment, match a replacement to the exact compatible-light information for that part. A battery that appears physically similar still needs the correct product-specific approval. Keep this purchase separate from deciding which of the two flashlights has the more suitable ordinary mode.
For a first purchase, the included battery is already part of the listed light weight. You do not need to add its mass again when comparing 220 and 205 grams. A separate spare, its protective carrying arrangement and any other power equipment would be additional items. This distinction is helpful when deciding whether the light is going into a small everyday bag or a larger equipment kit.
For an existing owner, identify what you actually intend to retain. Keeping the original light as a separate available device is different from transferring its parts into another model. The former gives the equipment a complete role with its own instructions. The latter requires explicit compatibility information for each part, which should be resolved before treating an existing collection as the new light's support system.
Both models use a metal rotary side control that supports stepless brightness adjustment. Seeker 4 Pro's US description specifically discusses operation with heavy gloves. Ultra's describes an enlarged metal rotary switch and a textured silicone grip. These are relevant design descriptions, but a purchase decision should consider where your fingers will meet the control while the rest of your hand supports the light.
For an ordinary stationary task, decide whether you want incremental adjustment as the object or viewing distance changes. Reading a nearby label and then examining a larger area can call for different levels. A rotary adjustment offers a way to make that change without treating every named mode as the only available brightness. Keep the output aimed at the work while making the adjustment.
Pressing and rotating also have different roles. From an unlocked state, the manuals describe a single press of the side switch for ordinary on and off. Their illustrations separately show rotational adjustment with the light off and with it on. For choosing equipment, the important question is whether that combination suits your intended preparation and use. Learn the matching sequence from the chosen model's instructions before depending on it.
An existing Seeker user may recognize the broad interaction style, while a first-time user may need to account for both the press and rotation. Familiarity can simplify a choice, but keep the exact starting state attached to the action. A borrowed light may already be locked, switched on or set to a different level, even though its control resembles the one you know.
The indicators provide more than one kind of information. Both manuals distinguish a brightness-level display from a battery-level display. Brightness feedback helps you understand the selected output region. Battery feedback describes the charge indication. Reading one as the other can make a normal setting seem like a low battery or encourage an unsuitable comparison between two different starting states.
Ultra's manual also describes a lockout icon. After automatic lockout, that icon lights for three seconds to confirm the state. In lockout, pressing the switch leaves the main light off while displaying the lock icon and battery level. This is useful information for someone preparing a light from a stored state, because a visible response can identify the control state without normal illumination starting.
Seeker 4 Pro's manual describes battery-level feedback when its side switch is pressed in lockout. Its current product-page guidance and the applicable instructions should guide unlocking. For this comparison, the useful distinction is the information shown when preparing the light. A familiar-looking dashboard does not establish that setup options or remembered sequences transfer between models.
Keep the display visible when choosing where the light will sit before use. A compartment or carrying position that conceals the control area may also conceal the information you want to read. If another adult will use the light, identify the battery indication and the locked state separately. That gives the person a more useful handover than describing every indicator simply as a brightness meter.
Each model's vertical holster combines carrying, placement and a USB-C charging role. This is a shared reason to consider these Seeker lights when you want an identified place for a handheld device between uses. The comparison then becomes where that complete arrangement will live. A holster that stays at a workstation serves a different routine from one that moves onto a belt or travels in a bag.
The manuals' Figure 12 illustrations give a clear off-state example. With the flashlight off, removing it from its holster unlocks it. With the light off, returning it to the holster locks it. Account for that interaction when moving between a fixed storage position and handheld use. The holster is involved in preparing the operating state as well as holding the light.
Seeker Ultra's US product description also states that brightness reduces to below 600 lumens when the light is inserted in its holster. Keep the light outlet and the surrounding area clear during any intended supported use. That feature belongs to the documented arrangement, and it should not be read as a reason to cover the light or treat every nearby surface as a suitable support.
For someone already using Seeker 4 Pro, holster-supported charging and locking are established parts of the system rather than new benefits exclusive to Ultra. If those are the features attracting you, compare the size, battery and actual output differences before deciding to change models. The shared system concept may already meet the need you are trying to address.
Yes. Each rechargeable flashlight offers USB-C charging through its holster and magnetic charging with an optional MCC3 cable. The USB-C description concerns the complete holster route. If you leave the holster at home, account for how you will recharge the flashlight elsewhere. A loose USB-C cable in a travel bag does not by itself reproduce the same arrangement.
The manuals' cable tables specify 5 V, 2 A input. For Seeker Ultra, the USB-C table lists about 4.1 hours to full charge and the optional MCC3 table about 5.3 hours. Seeker 4 Pro lists about 3.5 and 4.5 hours respectively. Keep each time with its route and stated supply.
An overnight charging opportunity and a short gap between tasks present different practical questions, even when both places have a USB socket.
Both manuals list a 0.8-meter USB-C cable and a 0.5-meter optional magnetic cable. Allow for the specified cable length when positioning a holster or arranging another charging location. A nearby power source may suit the shorter magnetic route, while a socket farther from the intended position requires attention to the complete layout.
The optional cable is a separate purchase from the supplied USB-C and holster equipment. Decide whether magnetic charging solves an actual second-location need before adding it. Olight's flashlight charging and care guide covers the broader connection and care questions. Here, the purchasing choice is which complete route you will use with the selected Seeker, including the parts that remain at the normal charging location.
A handheld light is useful when you want its direction to move independently of your head. For checking a cupboard, looking beside a bag or examining an ordinary item from another angle, you can direct either Seeker from the position that gives the needed view. Its holster then provides a planned carrying or return arrangement when you stop using it by hand.
The next part of the task may require both hands. Decide whether a suitable supported location will keep the light directed where needed, whether another adult will hold it or whether another lighting format better answers the task. Olight's headlamp guide for equipment setup addresses that last choice. Selecting the higher-output Seeker does not itself change the number of hands available for the work.
The complete setup also includes what you keep at the work location. A bracket and holster that remain there can make sense for repeated short tasks, while a mobile user must decide which parts travel. Keep the intended access path clear of other equipment. A larger light carried behind a tightly packed compartment is a different working arrangement from the same light immediately available in its own suitable carrying position.
Both models list IPX8 and a working-temperature range of 0 to 40 degrees Celsius. Apply those statements to the named flashlight and follow its instructions for the planned conditions. They do not assign a matching rating to a bag, cable or the whole collection. Use the conditions to decide where the arrangement belongs, including where you will prepare power after the outdoor task.
The Seeker 4 Pro listing identifies cool-white and neutral-white choices, with published color-temperature ranges of 5,700 to 7,000 K and 4,000 to 5,000 K. The Ultra configuration considered here is cool white. If your reason for choosing a light involves the light-source version, resolve that selection before using the standard CW comparison as the final answer.
A version choice also affects what a photograph or recommendation can tell you. A scene made with a neutral-white Seeker 4 Pro should stay identified that way when judging its appearance. It cannot establish how the cool-white Ultra will render the same objects. Choose according to the version you actually want to examine, and keep any personal color preference separate from a claim about overall brightness or recognition distance.
