If you always find yourself in a low-light environment, whether as an outdoor enthusiast, night worker, or security official, choosing the right powerful flashlight that would best fit your needs should be a priority.
If that's what you're looking for, then you're on the right page.
In this article, we will review one of the most powerful flashlights for outdoor activities: The Marauder Mini powerful flashlight.
We are going to analyze the brightness levels, lumen performance, battery capacity, and other must-consider specifications.
So without further ado let's dive in!
The Marauder Mini Powerful Flashlight (An Overview)
The Marauder Mini flashlight is a rechargeable compact dual-beam LED flashlight of 7000-lumen capacity, with a 1,968ft floodlight beam distance, and a runtime of up to 43.5 hours.
This powerful flashlight model with nine LEDs has multi-color RGB lights, is waterproof, and can be operated with an intuitive rotary knob.
It's the compact version of Olight's Marauder 2 model but built to fit lightly into your palms so you have full control of the grip, without sacrificing your favorite brightness level.
Who Is Marauder Mini Powerful Flashlight Designed for
The Marauder Mini Flashlight is mainly designed to be used for outdoor activities, search and rescue events, and low-light environments.
This high-lumen flashlight was designed to be used by:
●Security personnel, especially night watchmen.
●Explorers who love exploring thick forests, cave holes, and underwater glories
●Mechanics and technicians who have to see what they are fixing clearly. Heck, you're always under the vehicle.
●Campers who stay out all day and night
●Rescue teams looking for the most in the dark and deep
●Hunters and their dogs hunting for night games
●Photographers taking photographs of nature, landscapes, and celestial objects at night
●Engineers building tunnels, underwater structures, and or building infrastructures at night…
The list goes on. Marauder Mini powerful flashlight was built to combat any iota of darkness no matter how light or thick, keeping you productive all day and night – as you wish.
Marauder Mini Powerful Flashlight Features And Specs
7000 Lumen Max Performance
One of the biggest features of the Marauder Mini powerful flashlight is the brightness performance which is as high as 7000 Lumen.
This alone can turn your night into day. But that's not all.
Since this high-lumen flashlight was designed to fit varieties of needs, the designers have made it possible to adjust between various lighting levels.
So now you can adjust your 7000-lumen flashlight to 3200 lumens, 1600 lumens, 800 lumens, 200 lumens, and 100 lumens.
That's 7 levels of brightness for all your needs.
Battery Capacity And Max Runtime
If long-lasting battery life is one of the factors you'll consider when choosing the right flashlight for your needs, then Marauder Mini got you covered.
It can be powered with compatible customized batteries like the 6500MAh 3.7V 24Wh 32650 rechargeable lithium battery with a maximum runtime of 43.5 hours.
What's more? you'll have full control of howling you want the battery to run by simply adjusting within its 7 levels of lumen output.
Beam Distance
In addition to its powerful battery and high-lumen output, Marauder Mini powerful flashlight has a beam distance of 1968 ft.
For context, that's a whopping 600 meters.
And unlike other bright floodlights out there, the Marauder Mini beam distance of 600m is backed by a max intensity of 90,000 candelas.
Heck, you could blind a dinosaur with that level of a bright spotlight.
The higher the lumen, the higher the beam distance. And the higher the light intensity too.
RGB Flashlight
The biggest proof that the Marauder Mini was designed for various kinds of professionals and outdoor enthusiasts is the built-in RGB LED flashlight.
If you're an emergency or security personnel, you'll need a red light flashlight to signal danger.
If you're an explorer exploring the thick forests, cave holes, and underwater, then you'll need a green light flashlight to preserve night vision.
In fact, research has shown that green lights are capable of calming animals, so if you're likely to be with animals, then this is designed for you.
Finally, if you're a water junky, always fishing at night, then you'll need the blue light flashlight to help you spot and track fish. Cool, right?
Rotary Knob Switch
One of the reasons outdoor enthusiasts love the Marauder Mini series is that it's super easy to operate.
The Marauder Mini powerful flashlight is operated with an intuitive rotary knob switch that rotates more than 90 degrees.
With this rotary knob, you can easily adjust the 7-lumen brightness levels.
Also, there's a flip-flop switch below the rotary knob that allows you to flip up to spotlight mode and flip down the floodlight mode.
Other features built into the switch include battery level indicators, RGB light color indicators, and brightness level indicators.
Waterproof
This one is for water enthusiasts.
Marauder Mini flashlight is a flashlight for fishing that has been certified waterproof!
With an Ingress Protection X8 (IPX8) rating, it's designed to withstand continuous submersion in water, including dust and dirt.
So if you want to go night fishing with friends, then you don't have to worry about water damaging your flashlight.
Just kit yourself with this waterproof flashlight and you're good to go!
Compact Lightweight
Gone are the days when you needed a powerful flashlight as big as a coke bottle to meet your lighting needs.
With Marauder Mini, you get a lightweight handheld flashlight that only weighs 16.30 oz.
This is the most notable upgrade from the Marauder 2 model.
Marauder Mini Flashlight is just 5.12 inches high and 1.73 meters wide, making it leaner and easier to use.
Now you have full control of the grip, and no longer have to drop your flashlight.
One-Step Charge Rechargeable Battery
Asides from the Marauder Mini battery being customized and replaceable, it offers a one-step charging method experience with the Olight's USB Magnetic Charging Cable.
Simply snap the MCC3 magnetic cable on the magnetic charging port at the bottom of the flashlight and start charging.
Whew! That's lots of features for a mini outdoor flashlight.
With the Marauder Mini Flashlight within your palms, nothing is stopping you from doing the outdoor activities you love – not even thick darkness.
If you're yet to get your Marauder Mini Flashlight, simply visit our Olight store to purchase yours right now.
