Obulb Pro VS Obulb MC
General Introduction
Main Difference
1. Smart Control
Obulb MC:
It is obvious that the Obulb MC led bulb light does not have smart control.
Obulb Pro:
In comparison, the most outstanding feature of Obulb Pro led bulb light is it can be controlled by the Olight APP via Bluetooth. As the first Olight device that supports the Olight app, it allows users to change its mode, brightness, and color, and check the remaining power and runtime effortlessly on the Olight App. More importantly, Olight APP also enables group control and data sharing. In this way, it is easy for you to control multiple Obulb Pros led bulb light simultaneously while your friends and relatives can also control them by scanning your OR Code.
2. Output
Obulb MC led bulb light:
Obulb Pro led bulb light:
3.Mode & Color
Obulb MC:
8 light modes. Warm white light, red/green/blue/ flashing red light, 256-color gradient change, and 7-color cycling.
Obulb Pro:
7 light modes. Warm white light, red/green/blue/flashing red light, fade between 7 colors, cycle between 7 colors.
4. Batteries
Obulb MC:
Built-in 3.7V 630mAh Rechargeable Lithium Polymer Battery
Obulb Pro:
Built-in 3.7V 1650mAh Rechargeable Lithium Polymer Battery
5.Weight & Dimensions
Obulb MC led bulb light | Obulb Pro led bulb light | |
Weight | 2.05oz/58g (Including Battery) | 3.7oz/105g (Including Battery) |
Height | 1.89in/48mm | 2.28in/58mm |
Body Diameter | 2.13in/54mm | 2.56in/65mm |
6. Package Contents & Optional Accessories
Attention:
Due to our environmental protection efforts, the Obulb Pro led bulb light does not come with an MCC 1A Charging Cable, which is not the same as the Obulb MC. However, we decide to cut down the price of the MCC 1A Charging Cable to $ 8 during this Summer Sale and you can click here to take it away!
Similarities
1. Magnetic Bottom
The magnetic bottom of the led bulb light attaches to almost any smooth surface when combined with the adhesive metal badge.
2. Drop test & Waterproof
Both these led bulb lights have IPX7 waterproof and 1.5-meter impact-resistant.
After reading the above, will you choose Obulb MC or Obulb Pro? If you would like to buy Obulb Pro led bulb light, click here to take it away!
