Hi guys, your number one EDC tool, I would like to recommend an EDC flashlight in your pocket. It can be used as a safety tool whether at night or not. I mean, lights have so many uses for me. I carry the Olight Arkfeld every day, it's super thin, 1000 lumens, and it even has a green laser attached to it, it slides into the pocket super easily and is very comfortable.By the way,If you like UV light, you can choose Arkfeld UV.
But now, What excites me is that Olight released Arkfeld Pro.
❓Want more powerful LED?
❓Want a stronger green laser?
❓Want a higher power of UV light?
❓3-in-1? ✅Yes! We spoke, they listened and they did it!
So What makes Arkfeld Pro stand out from the EDC Flashlight?
They combined white light, UV light, and green laser to create Arkfeld Pro, an EDC (Everyday Carry) tool that is truly powerful.
👏Pro White Light-1,300 Lumens
The Arkfeld Pro has become my go-to flat flashlight that I carry with me every day. The Arkfeld Pro has been upgraded to 1,300 lumens and still maintains a very flat size compared to the Arkfeld. With a longer body, measuring approximately 4.72 inches x 1.06 inches x 0.62 inches, it remains highly portable.
The UI interface is very simple and easy to use. The flashlight features a circular dial mode selection switch at the head, allowing users to quickly switch between white light, green laser, and UV modes. Now let’s take a look at the different brightness settings of the Arkfeld Pro EDC flashlight.
👉The first is the 1-lumen moonlight mode. I often turn on the moonlight mode before going to bed at night. It can be used as a night light and can run for up to 11 days.
👉Next, increase the setting to 15 lumens to have some light.
👉 Increase it to a medium brightness of 100 lumens and you can run it for about 9 more hours.
👉Then there's the high brightness of 420 lumens with a nice diffused beam that can illuminate an area approximately 15 yards away.
👉Then double-click to switch to the highest brightness of 1,300 lumens, which is very bright and has a uniform light spot, suitable for illuminating large areas.
👉If you tap it three times it goes into flash mode, it has a lot of features but is very simple to use.
👏Pro Green Laser - ≤5mW Class 3R!
The ≤520nm green laser mode of Arkfeld Pro is very helpful for me. Compared to Arkfeld, Olight has upgraded the green laser of Arkfeld Pro with an upgraded version of green laser (Class 3R) that provides clearer vision. I often use it in the office to assist with presentations and meetings, and my furry friend Lucky also enjoys playing with the green laser.
Oh, by the way, I found a very cool thing, the Arkfled Pro's green laser and white light can be combined. Point the selector knob to laser mode and click to activate the laser. Then, with the laser on, double-click to activate the white light. Cool!👏👏
👏 Pro UV Light - 900mW UV light!
To make Arkfeld Pro even more practical, Olight added UV light. Compared to Arkfeld UV, Olight has upgraded the power of the UV light, with a high-power output of up to 900mW at a wavelength of 365nm. It offers a purer and more professional UV experience compared to the standard 395nm ultraviolet light.
The UV mode is very useful and can be used in various scenarios. For me, the most important benefit is when staying in hotel rooms - using UV light to check for bodily fluid stains allows me to better understand the cleanliness of the room. I must admit, we have used Arkfeld UV lights in hotel rooms before and some of the findings were shocking. Additionally, I frequently use UV light to detect insects. In gardening, sometimes these insects are difficult to see, especially thrips around tomatoes, and UV lights can help us locate their glowing positions. Furthermore, my daughter enjoys using UV light to create nail art.
👏Pro Battery Life - 1,500mAH
As a user of the Arkfeld Pro flashlight, I appreciate the convenience of never being caught off guard by a dead battery. The five-level battery indicator provides me with a clear understanding of the available power and when it's time for a recharge. This takes the guesswork out of managing battery life, which is a huge relief.
The 1500mAh Lithium Polymer Battery delivers a reliable and efficient energy output of 3.7V and 5.55Wh. The battery capacity is greatly increased compared to Arkfled.
One good thing is that the Arkfeld Pro still has a magnetic charging module located at the tail end. It supports MCC (Magnetic Charging Cable) charging, which allows me to recharge it whenever and wherever I need it conveniently. Whether at home, in the car, or outdoors, I can attach the magnetic charging cable and let it power up. It's a user-friendly design that makes my life easier and ensures that I'll never be left in the dark due to a drained battery.
Another good thing is the magnetic tail gives me more usage options. this will work on any metal surface that is magnetic and then you can just turn on the light and it gives you a hands-free option if you have an overhanging wall shelf. You can do different things so it does give you different options.
👏Pro user experience
The original Arkfeld flashlight had a smooth side, while the new Arkfeld Pro version added a serrated texture on the side, providing a better grip. I didn't pay much attention to this change before because the original Arkfeld flashlight was very convenient to hold due to its clip design. However, the textured design on the new flashlight does add a bit of friction, which is highly practical. Additionally, the clip has been upgraded to a dual-clip design, making it more versatile by allowing you to clip it onto the brim of a hat. A new lanyard hole has also been added to the clip, giving you more options if you need to thread a cord through it. The new flat flashlight provides you with more choices.
As for durability, I put the Arkfeld Pro to the brutal test, throwing it around ten times and using it in heavy rain just to see if I could break it. But I'm happy to tell you that they can withstand a lot of torture. Moreover, they are IPX7-rated and can withstand harsh weather.
The packaging is very nice, almost iPhone-like, beautifully made, and has a lot of information on the back. After unboxing, there is a nice cardboard box inside to protect it. Friendly note, however, that on first use you will need to hold down the button to unlock it, as they are locked from the factory to prevent them from accidentally turning on during transport. You just need to read the instructions and follow the instructions. A charging cable is also included.
In the End
Guys, the Arkfeld Pro is very practical, they are easy to carry in your pocket, and it gives you a very bright light, perfect for EDC, you can dim it in the dark when you just want a little bit of light-dark and then you're good to go. The UV option will definitely make this more user-friendly, especially if you're someone traveling, but it's a great option any time and the green laser option is also very practical, especially if you have pets at home, or someone who often presides over meetings. The clip has been improved and I really like that, those side serrations really make it easier to grip.
The Arkfeld Pro still offers two color temperature choices, one is neutral white and the other is cool white. You can choose either color depending on your preference. Neutral white gives a slightly warm feeling. In addition, neutral white provides more natural colors, while cool white is more pure white, giving a different feeling. Some people prefer cool white, while others prefer neutral white. Personally, I prefer cool white because it can better show details, but neutral white can present more realistic colors. They are both great lights, just choose differently based on whether you really need to identify colors or details.
Now Arkfeld Pro has been launched in three colors, black, orange, and Halloween-themed zombie green version. I am completely obsessed! Friendly let you know that Zombie Green is limited to 5000pcs.
The Arkfeld Pro costs $69.99 Now, which is a great price, especially for a flat flashlight. Just grab Olight's October flash sale to get one, you can buy it at a very good price, Up to 40% off! I am going to take my Arkfeld Pro and do a big Halloween cleaning, wish everyone a happy Halloween in advance.
