Olight Oclip Specifications
Brand/model | Olight Oclip |
Corlor Temperature | 5700-6500K |
Max. Lumens | 300 lm |
Max. Beam intensity | 1,300 cd |
Max. Beam distance | 70 meters |
Battery config. | 280mAh built-in |
Onboard charging | USB-C |
Modes | 4 + red |
Blinkies | Strobe, beacon, Red blinking |
Reflector | TIR |
Waterproof | IPX5 |
Introduction
The best light is always by your side, and today I bring you the Oclip compact clip-on light from Olight. Weighing only 30 grams, the Oclip can easily be attached to clothing and backpacks, or used with its magnetic function to attach to metal surfaces or as a keychain flashlight hanging from your waist, providing ample illumination for your daily activities. The Oclip offers white light and red light. If you are interested in these features, please keep reading.
Oclip Package:
Oclip comes in a simple but beautiful cardboard box. Inside you can find the following:
Olight Oclip LittleClip Light
USB-C charging cable
User Manual
Clip Light in Use
There are many ways to carry your Oclip, here are the three main ways:
Clip-on:
Oclip comes with a strong clip that can be attached to various objects with a maximum thickness of 14 millimeters. It can be clipped onto pockets, hat brims, belts, and other items. Both the clip and the flashlight are equipped with rubber pads, effectively reducing the possibility of damage. So even if you clip on an expensive item, Oclip can hold it firmly without causing any damage.
Magnetic attachment:
Oclip has a small magnet embedded in the end of the clip, making it easy to attach to metal objects. This means you can fix it to a fridge, metal shelf, or other metal surface, making your flashlight available at all times. You don't have to worry about losing or searching for a light source, just fix Oclip in the right place.
Lanyard carries:
In addition to clip-on and magnetic attachment, Oclip also features a small hole at the other end of the clip for attaching a lanyard or keychain. You can thread the lanyard through the hole and then hang Oclip around your neck, backpack, or keychain. This carrying method is convenient and lightweight, making your flashlight easily accessible, whether for outdoor adventures or daily use.
With these three carrying methods, Oclip is not just a clip-on light, but a multi-functional and convenient portable flashlight. No matter which way you choose to carry it, Oclip can be easily carried and used.
So, what are the main uses of carrying a clip light?
The Oclip flashlight is extremely convenient in daily life. For example, during power outages, nighttime walks, camping, and other occasions, you can clip the Oclip onto your backpack or place it on your back to use its red light function as a rear signal light, increasing safety at night and making it easier for others to notice your presence. Additionally, when you need to do home repairs, the Oclip flashlight can provide sufficient light to help you complete tasks more easily. Whether it's changing batteries, disassembling furniture, or inspecting circuits, the Oclip flashlight can provide ample illumination.
For outdoor enthusiasts, the Oclip flashlight is also a great choice. During nighttime hikes or other situations that require location tracking, you can set the flashlight to beacon mode so that teammates or rescue personnel can accurately locate your position. Furthermore, due to its compact and lightweight design, you can easily carry it in your backpack or attach it to your keychain for instant access.
In terms of automotive maintenance, the Oclip flashlight is equally practical. As a backup flashlight, its brightness is sufficient for general lighting needs and can provide ample light in emergency situations. Its small and portable design allows you to keep it in your car or on your keychain for easy access. When you need to perform car repairs, the Oclip flashlight can provide sufficient light to help you complete tasks more conveniently. Whether it's changing tires, inspecting the engine, or replacing car bulbs, the Oclip flashlight can provide ample illumination.
Overall, the Oclip flashlight offers great convenience and versatility in various daily scenarios, making it a reliable companion for both indoor and outdoor activities.
Friendly UI design
The available main modes:
👉Moon, Low, Medium, High
The available special modes (blinkies):
👉Red, Red blinking
👉White beacon mode, and strobe
How the UI works when the flashlight is still turned OFF:
👉Single-click: to last used mode, mode memory
👉Double click: red
👉Triple-click: strobe
👉Press and hold 2sec: moon mode
👉Press and hold 4+sec: lockout (repeat to unlock)
How the UI works when the flashlight is turned ON:
👉Press and hold: Cycle through the menu from Low to High
👉Single-click: turns off
👉Double click: red
👉Triple-click: beacon mode
Shortcuts within the UI:
👉To Turbo: none
👉To Moon: long press from off
👉To Strobe: triple click from off
👉To beacon mode: triple-click from on
👉To red: double click from Off and On
Mode memory:
👉Yes, main modes, including Moon
Blinky modes:
👉Yes, there is a strobe (3 clicks from off), and there is beacon mode (3 clicks from on)
Low battery warning:
👉Yes, there is a tiny indicator light in the switch, but it’s kind of weak to really use. Green is 60-100%, orange 30-60%, red 0-30%
Lock-out mode:
👉Press and hold the switch from OFF for 5 seconds. It will turn on in Moon mode first, and then into lockout.
Dimensions:
Olight Oclip | Millimeters | Inches |
Length | 48 mm | 1.9 in |
Width | 22 mm | 0.9 in |
Thickness with clip near the head | 20 mm | 0.8 in |
Weight:
Olight OClip | Weight in grams | Weight inOz. |
Weight: | 28 grams | 1.0 oz. |
Batteries and Charging Methods
The 280mAh small capacity is sufficient to meet emergency lighting needs, considering the compact design and purpose of this light. Due to its small size, it is suitable for carrying in pockets or on keychains, primarily for addressing lighting needs in unexpected situations such as power outages, outdoor activities, or nighttime emergencies. For these temporary usage scenarios, the 280mAh capacity is enough to provide short-term illumination.
The USB charging feature makes it convenient and easy to use. The included USB-C charging cable can be connected to any USB device, eliminating the need for an additional charger. This means users can charge the light using common devices such as computers, power banks, or car chargers, increasing charging flexibility. Additionally, the USB port is hidden beneath a rubber cover, preventing dust and moisture from entering and improving the durability of the light.
The light has a fast charging capability, with a measured charging time of 1 hour and 33 minutes. This means users can complete the charging process in a short amount of time, reducing waiting time and enhancing convenience. Furthermore, the small red and green lights on the switch provide charging indicators, allowing users to clearly know the charging status. When charging begins, the red light illuminates, and when charging is complete, it changes to green, enabling users to accurately track the progress of charging.
Olight Clip Light Quality and Warranty
No part on the Oclip is removable except for the USB-C port cover. It's pretty sturdy for such a small light. The body is made of aluminum, the anodization is very well done, it doesn't look cheap, and the only color available right now is black. Olight will release more beautiful colors, so stay tuned!
If you purchased an Olight® product from Australia, China, France, Germany, or the USA after January 1st, 2023, the local service centers in these countries will honor your LIFETIME WARRANTY for your purchase. If your Olight® product (including its structure, built-in battery, LED, or lens) ever experiences any issues, we promise to take care of it. If we are unable to repair your product, we will promptly replace it with a product in perfect working condition, which will be of equal or better physical condition. If your purchase is a limited or discontinued edition of an Olight® product, we will repair or replace it with another Olight® product of the same or higher value.
I think this is a great little flashlight that is very portable considering its size and weight. If you want to carry it every day, you can put it in your pocket. I probably wouldn't do that and hang it on my backpack. If I need it, I know where it is. If you're interested in purchasing one, click here to purchase one. Thanks for reading!
