When it comes to weapon-mounted lights, Olight stands out as a trusted brand renowned for its commitment to quality and innovation. In this comprehensive review, we will delve into the features and advantages of three exceptional models: the Baldr S, Odin Mini, and PL-3. These lights cater to a wide range of firearms enthusiasts and professionals, ensuring enhanced visibility and target acquisition in any tactical situation.
The Best Weapon Light With Green Laser: Baldr s
Performance
White light output: 300-800 lumens on high, 100 lumens on low
Runtime: 1-140 minutes
Green aiming laser
Switching
Push-button switch accessible from both sides
Momentary and constant-on modes
Select light only, laser only, or both
Construction
Locking lever for fast, secure attachment to Glock rail
Adapter for Picatinny rail
Slides on the rail for precise positioning
Easy charging with Olight Magnetic Charge Cable
IPX4-rated water resistance
Weighs 3.35 ounces, and measures 2.48"
Finding a reliable weapon light and laser sight is crucial for individuals or professionals with high-security awareness. The Olight Baldr S Rechargeable Weapon Light with Green Laser is an excellent choice that will give you the tactical advantage you need. This compact pistol light provides up to 800 lumens of white light and features an adjustable daylight-visible laser for precise target acquisition. Its runtime ranges from a burst output of one minute at the highest brightness mode to 140 minutes at 100 lumens in low mode. The dual-side switch design allows for easy controls from either side, and you can choose to use the light only, the laser only, or both simultaneously. The adapter is sliding and compatible with Glock and Picatinny rails for perfect positioning. The Baldr S also comes with a built-in lithium polymer battery that can be recharged using Olight's magnetic charging cable. It has an IPX4 waterproof rating, measures 2.48 inches, and weighs only 3.35 ounces.
The Olight Baldr S is your best tactical companion, thanks to its outstanding functionality and durability. With up to 800 lumens of white light illumination, it ensures clear brightness in any environment. Additionally, the unique adjustable laser sight allows for precise target acquisition, whether in close-quarters combat or long-range shooting. Its low mode provides an option for extended use, making it ideal for tasks that require continuous lighting.
In summary, the Olight Baldr S Rechargeable Weapon Light with Green Laser combines high-intensity white light and accurate aiming with a green laser, providing you with a powerful and reliable tactical tool. Its compact design and lightweight make it easy to carry and operate, while the built-in charging system saves you the trouble of constantly changing batteries. If you're an individual or professional concerned about personal or professional security, I highly recommend purchasing the Olight Baldr S to always maintain the advantage in tactical situations.
The High Performance Weapon Light: Odin Mini
Performance
Output: High, 1250 lumens (6 minutes runtime)-900 lumens (11 minutes)-700 lumens (39 minutes)-200 lumens (14 minutes); low, 200 lumens (5 hours runtime)
Switching
Push-button tail cap switch
The remote pressure switch cable attaches over the tail cap switch
The remote switch snaps onto Picatinny rather than the adhesive attachment
Momentary and constant-on operation
Construction
Mount screws onto M-LOK rail, light snaps into mount and locks with the turn of a knob
Compatible with third-party KeyMod and Picatinny mounts
IPX8-rated water resistance
MCC3 magnetic charging cable from any USB Type-A source
green and red charging indicator lights
Measures 4.6", weighs 6.2 oz
The Olight Odin Mini Rechargeable LED Weaponlight is a must-have for those seeking a reliable and powerful light source in critical moments. With its M-LOK rail mount, snap-on remote pressure switch, and impressive peak output, this weapon light is designed to exceed your expectations. Learn more!
The Odin Mini's M-LOK rail mount ensures a secure and semi-permanent attachment to your weapon. With a simple turn of a knob, the light locks onto the mount, providing stability and confidence during intense situations. The stainless steel tail cap switch allows for silent operation, is perfect for stealthy operations, and can also be used handheld when necessary. Additionally, the included remote pressure switch provides even greater versatility, attaching magnetically over the tail cap with a threaded locking ring and a flexible switch mount that snaps onto a section of Picatinny rail.
Equipped with a built-in 18500 lithium battery, the Odin Mini delivers an impressive peak output of 1250 lumens, ensuring exceptional brightness when you need it the most. It also offers a low-power setting of 200 lumens, providing a five-hour runtime for extended use. Charging the battery is convenient and hassle-free with the USB cable and Olight magnetic tailcap attachment. Plus, the light features a vibration alert system that notifies you when the battery is draining, with vibrations occurring once every five minutes when below 20%, every minute when below 10%, and every 10 seconds when below 5%.
Designed to withstand the harshest conditions, the Odin Mini is IPX8 water-resistant and impact-resistant up to 5 feet. Its compact size of 4.6" and lightweight construction of 6.2 ounces make it easy to carry and handle, without compromising on performance.
In conclusion, the Olight Odin Mini Rechargeable LED Weaponlight is a game-changer in the world of weapon lights. Its robust features, including the M-LOK rail mount, snap-on remote pressure switch, and impressive output, make it an indispensable tool for any professional or individual seeking reliable illumination in critical situations. Don't miss out on this exceptional weapon light that combines functionality, durability, and convenience. Equip yourself with the Olight Odin Mini and experience the ultimate lighting solution for your tactical needs.
The 1300 Lumen Weapon Light: PL-3
Performance
Output: High, 1300lumens (1.5 minutes runtime)-450 lumens (82 minutes)-200 lumens (43 minutes); low, 200 lumens (270 minutes runtime)
Switching
Dual ambidextrous switches
Construction
Comes standard with both Glock and Picatinny rail inserts for easy mounting to almost any short setup.
adjustable locating block
IPX6-rated water resistance
Weight 4.20 oz (119 g) (Including Battery)
Height:1.28 in (32.5 mm); Length: 3.19 in (81 mm); Width: 1.44 in (36.6mm)
PL-3 Valkyrie Weaponlight from Olight is a game-changer in the world of tactical lighting. With its sliding rail block for precise positioning and powerful 1300-lumen beam, it is designed to exceed your expectations in any situation.
One of the standout features of the PL-3 Valkyrie is its adjustable locating block on the rail mount, allowing for a customizable fit on a variety of rails. This ensures a secure and snug attachment, providing confidence shot after shot. The robust locking device not only ensures stability but also allows for easy one-handed mounting and dismounting, making it a breeze to attach or detach the light as needed.
Equipped with dual ambidextrous switches, the PL-3 Valkyrie offers exceptional ease of use. Whether you prefer momentary or constant-on modes, you can effortlessly switch between them with either hand. Additionally, the switches provide convenient access to the strobe mode, adding an extra layer of versatility to this weapon light.
The PL-3 Valkyrie operates on readily available CR123A batteries, ensuring that you won't have to worry about running out of power when you need it most. With a maximum runtime of approximately 270 minutes, this weapon light is built to handle extended use without compromising on performance.
In conclusion, the Olight PL-3 Valkyrie Weaponlight is a must-have for those seeking a reliable and powerful illumination tool. Its sliding rail block, adjustable locating block, and robust locking device ensure a secure and customizable fit on various rails. The dual ambidextrous switches provide easy access to momentary and constant-on modes, as well as the strobe function. With its impressive 1300-lumen beam and long runtime, this weapon light is designed to excel in any situation. Don't miss out on the opportunity to enhance your tactical setup with the Olight PL-3 Valkyrie Weapon light. Get yours today and experience unmatched performance and reliability.
Conclusion:
In this comprehensive review, we have explored the remarkable capabilities of three outstanding weapon-mounted lights from Olight: the Baldr S, Odin Mini, and PL-3. Each model is designed to cater to specific tactical scenarios while guaranteeing superior performance and reliability. Whether you're a law enforcement officer, a competitive shooter, or a dedicated enthusiast, Olight provides the tools to illuminate your tactical journey. With their exceptional features, user-friendly design, and unwavering commitment to excellence, the Baldr S, Odin Mini, and PL-3 are undoubtedly worthy additions to any firearms setup. Choose the one that best suits your needs and experience the difference that Olight brings to your tactical endeavors. Illuminate your path to success with Olight weapon-mounted lights.
