In a defensive moment, hesitation isn’t an option. You need to find your reticle instantly, lock onto your target, and make every shot count. That’s exactly where the Osight SE GN comes in.
The Osight SE GN is the newest addition to the Osight SE lineup of compact pistol optics. Designed specifically for everyday carry, it combines a green multi-reticle system, a fully enclosed emitter, and a side-loading battery design, giving you the speed, clarity, and reliability you need when it matters most.
By expanding the SE series with more flexible reticle options while maintaining that renowned durability shooters love, the SE GN delivers a versatile optic solution for modern carry setups.
A Reticle That Adapts to You
One of the key features of the SE GN is its green Multi-Reticle System, allowing shooters to choose the reticle that best matches their shooting style or scenario.
The optic offers three selectable reticle configurations:
● Dot + Circle (2 MOA + 32 MOA) – Combines fast target acquisition with a precise aiming point.
● 2 MOA Dot – Ideal for precise shots and refined aiming.
● 32 MOA Circle – Designed for quick reticle pickup during fast engagements.
This versatility allows the optic to adapt to a wide range of shooting scenarios – Osight SE GN is ready for anything, whether you're punching tight groups at 25 yards or ringing steel in fast-tempo CQB drills. Its green reticle also maintains excellent visibility across varied lighting conditions, helping shooters quickly locate the reticle while maintaining a clear sight picture.
Built for Real-World Reliability
Every day carry can be harsh on a firearm. Life can get in the way of proper daily maintenance, and EDC systems are exposed to a constant stream of dust, lint, moisture, and debris. The SE GN shrugs all that off with ease thanks to its fully enclosed design, keeping its emitter clear in any environment.
Each SE GN is water resistant to an IPX7 level, meaning its sight picture is the same each and every draw, rain or shine.
For concealed carry users and defensive shooters, this additional protection provides confidence that the optic will continue performing reliably when it matters most, even if you don’t treat it like a safe queen all the time.
Faster Maintenance. No Re-Zero Required.
Maintenance should never interfere with reliability. The SE GN incorporates a side-loading CR1620 battery tray, allowing users to replace the battery without removing the optic from the slide.
By keeping the optic mounted during battery replacement, users benefit from faster maintenance while eliminating the need to re-zero the optic after installation.
The SE GN helps stretch that battery life further with automatic motion activation, user-toggleable standby mode, and a low-battery indicator.
Choose What Fits Your Carry Style
While the SE GN introduces new versatility to the lineup, it remains part of the broader Osight SE family, each designed to support different shooting preferences.
Within the lineup:
● Osight SE delivers a classic red-dot shooting experience with a clean, familiar sight picture.
● Osight SE 6 MOA GN features a larger green dot that many shooters prefer for faster target acquisition.
● Osight SE GN expands the lineup with a green multi-reticle system, giving users the option to switch between precision and rapid acquisition.
Every SE shares the same core design philosophy: compact size, durable construction, and widespread compatibility with RMSc-footprint pistols, making it easy for shooters to choose the configuration that best matches their setup.
The Osight SE GN isn’t just another compact optic—it’s a smarter one.
With its adaptive reticle system, enclosed durability, and user-focused design, it delivers the speed, clarity, and reliability you need when it matters most.
