You most probably suffer from battery anxiety when your cell phone’s power is dangerously close to 20%. You're probably like the majority of people, seeing that red icon will make you panic, irritate you, and make you search for a spare charger. But have you experienced the same anxiety when needing a flashlight in an emergency but under a deep dark situation, you find out the flashlight is almost power-off.
In terms of low-power anxiety, owning a run-of-the-mill torch can also be troublesome. Despite the mediocre performance, the cheap battery couldn’t last long as well. Charging the tool itself is not much work but the power going off too frequently is going to be a potential hazard when you encounter an emergency. But, imagine having a flashlight that remains fully charged every time after a long day of use. That's where the Banton 3, an EDC flashlight and powerful rechargeable flashlight, comes in..
But what if you don't need searching power adapters and no more dangling wires on the desk while the power is almost run-off? More importantly, say goodbye to low-battery anxiety by only putting back the EDC flashlight itself back to the charging case to finish the charging process (just like the way how you charge your wireless earplug)
Baton 3 rechargeable flashlight is a product you hardly can find a lot of counterparts on the market. The unique feature of it is the tailor-made charging case. The power bank charges via type-C port and pumps out power via magnetic port while two indicators show your output and input status.
The wireless charger includes a 3500mah built-in battery that can charge the baton 3 powerful flashlight up to 3.7 times. It is convenient keeping the charging process in a bag while on the road, after it is charged up, take this EDC flashlight with you for easier portability.
The Baton 3 Premium Edition is one of Olight's best EDC flashlight, We released Patriotic Edition this fourth of July. Don't worry if you didn't get one,Click here to get yours now!
