This Olantern is an excellent all-around lantern, giving out an even, steady 360-degree lighting distribution. The white light LED module and flaming LED module are replaceable for fun and scenario-based illumination. The white light LED module has 3 adjustable settings: 30 lumens, 120 lumens, and 360 lumens. It is powered by four 1900mAh lithium-ion batteries rechargeable via the magnetic charging cable and runs up to 80 hours. The stable base and the hanging hook are available for several placement options. It is resistant to splashing water and the impact of daily use. The battery indicator around the button indicates the battery level and fades on and off to reveal the button in the darkness.
The The Olantern Mini is a compact outdoor light that features a balanced 360-degree beam. It is so small that you can fit it in one of your palms. Its handle also works as a hook, making it easy to carry and position. Its body is mainly made of zinc alloy, allowing it to be tough yet lightweight. The Olantern Mini not only provides a dimmable white light but also a night-vision preserving red light, great for camping or emergency use. The tornado-shaped light diffuser softens the light output, reducing strain on your eyes during long-term use. When the included motion sensor feels a shake, the indicator around the button will light up, allowing you to read the battery level and locate the button in the darkness. It also features a built-in lithium-ion battery that can be charged quickly using the USB magnetic charging cable. The Olantern Mini is a refined product to light your home and adventures.
Both of them can be used as decorations in some festivals, especially the Olantern. The detachable cover of Olantern gives us a lot of self-made chances, which meets different kinds of festival decoration needs. Except that, the two lights will be the practical camping lights for signaling, lighting, and so on. Get them and have more fun. Comment below to give your opinion to them.
