The Baldr Pro R is the new rechargeable flagship product of the Baldr Series. It boasts a white light of max 1.350 lumens like the Baldr Pro but also adds a GL beam (<5mW) for quick and accurate aiming. The GL beam emitter is integrated into the head of the light. This design leaves room for the charging port on the bottom of the light and supports a remote pressure switch. It can be switched on and off by magnetic connection wire control. So it is compatible with both pistols and long guns and has both a green laser sight and a rechargeable track light with white LED. Trust me! Green laser beam clearly visible.
Next, Baldr Pro R is powered by a 3.6V 1000mAh lithium polymer battery that can be recharged via the magnetic charging cable, this WML runs up to 93 minutes after being fully charged. The selector ring around the head allows you to easily choose between white light only, white light & GL beam combo, or GL beam only. The Baldr Pro R includes two types of rail adapters to fit both Glock and Picatinny rails. With the quick-install system, you can easily attach and detach the light to your self-defense setups.
The well-tested adjustable screws allow for easy zeroing and can withstand strong impacts without loosening. The ambidextrous rear switches allow for quick on/off or direct access to the strobe because the tail on both sides of the switch takes into account the left and right-hand habits.
Powerful, precise, and versatile, the Baldr Pro R is an ideal addition to your setups as long as you are gun light enthusiasts, long gun pistol holders, law enforcement (police), military, U.S. militia, or special operations commandos, etc.
The market application of Baldr Pro R tactical light is self-defense, Law Enforcement, and tactical use. And here is its use scenario: tactical scenes with pistol / long gun, close range (home) defense, night duty, dark search, aiming, target shooting, and hunting.
Product Performance
The Baldr Pro R has five modes of lighting, but the lumen, range, and running times of each mode are different. The following table can list their differences in detail.
Baldr Pro R | |||
Mode1 | Laser ON | 1.350~500~300lumens /1.5+38+10Minutes /200 meters /10.000cd | GL Beam ON |
Mode2 | Laser ON | 1.350~500~300lumens /1.5+40+13 Minutes /200 meters /10.000cd | GL Beam OFF |
Mode3 | Laser OFF | 300lumens /85minutes /95meters /2.256 cd | GL Beam ON |
Mode4 | Laser OFF | 300lumens /93minutes /95meters /2.256 cd | GL Beam OFF |
Mode5 | STROBE | 13Hz at /1.350lumens | STROBE |
Light Sourc | / | High-Performance CW LED | / |
In a word: Baldr Pro R’s 1350 lumens is a very competitive level in pistols and long guns, and the range of 200~160M is more suitable for short-range and close-range (family) defense, night shift duty, and hunting. Do you like it?
About the appearance on the fuselage of Baldr Pro R (size, weight, and material), Baldr pro r is lighter and longer than Baldr pro, but their waterproof and drop test is the same, they are IPX4 and 1m. Of course, a great waterproof can be used for hunting outdoors, self-defense, resisting certain accidents, and prolonging the service life.
Baldr Pro R | |
Length | 3.74in/95mm |
Width | 1.44in/36.6mm |
Height | 1.34in/34.1mm |
Weight | 4.44oz/126g (Including Battery |
Body Material | Aluminum Alloy |
Waterproof | IPX4 |
Drop Test | 1M |
Charging method
What you may not know is that the Baldr Pro R is powered by 3.6V 1000mAh Rechargeable Lithium Polymer Battery (Built-in). The previous Baldr Pro was using 2*CR123A batteries. After the battery is used up, you only can replace the battery, it is not rechargeable. However, Baldr pro R is a rechargeable tactical gun light, and uses MCC 1A USB magnetic charger, no need to take out the battery, charging is more convenient. The magnetic charging port is compatible with magnetic wire-controlled switches, and it is also very convenient to use on long tactical gun lights. Give you a more convenient experience.
Main Features
Featuring a max white light of 1.350 lumens with a 200-meter beam distance, it provides the ideal situational awareness you need. Integrated GL beam (<5mW) for quick and accurate aiming both during night and day. A new mode selector ring to choose between white light only, GL beam only, or white light & GL beam combined.
The built-in 3.6V 1000mAh lithium polymer battery can be charged via the MCC charging cable without the hassle of taking out the battery. The magnetic charging port also serves as a connection port for the optional remote pressure switch, making the light much more versatile.
Both Glock and Picatinny-sized rail adapters are included for superb compatibility.
The quick attach-and-release mounting system enables instant installation or removal. Dual ambidextrous switches for smooth momentary-on or constant-on activation by either hand with ease. Quick access to strobe by pushing both sides simultaneously.
Operation
Light settings: Brand-new design mode selection ring, lightly rotate it to select 3 lighting modes: white light, green laser, green laser & white light.
Turn on/off the light source: Quick single press (press and then quickly release) any button, and the output is continuously lit. Single press again to turn off the light source. Momentary-on: Press any button and hold, output turns on when pressed and off when released.
When the light source selector switch is placed in LED or LED&LASER option, the following operations are valid:
Change brightness: In the power-on state, a quick double-click (or multiple-click) of the key output brightness will be converted and memorized.
Direct highlight: In the off state, a quick double-click (or multiple-click) of the key will directly output the highlight.
Strobe mode: When the left button and the right button are pressed at the same time, the strobe mode will start, and the release button will continue to flash.
Lock Mode
In the off state, first press any key and hold (about half a second or more), then press another key, press and hold (about 2 seconds or more) both keys at the same time until the output is turned off, the product enters the lock mode.
In the lock mode, press and hold both keys at the same time (more than 2 seconds) until the output current light source mode (LED or LED&LASER option, the white light is low by default), and the product is unlocked.
In The Box
1. BALDR Pro R (Battery Built-in) x 1
2. Picatinny (MIL-STD-1913) Rail Mount Adapter x 1
3. Rail Adapter Screw x 2
4. Adjustable Screw x 2
5. H1.5 Allen Wrench x 1
6. MCC 1A USB Magnetic Charging Cable x 1
7. User Manual x 1
Note: The Baldr Pro R has an OPTIONAL ACCESSORY - Magnetic Remote Pressure Switch (RPL-7)
The Baldr Pro R beats the competition and is capable of conquering challenging tasks. Buy it now and get a free gift from our Olight Store. We have other best tactical flashlights. Thank you for reading.
