When darkness comes, light becomes necessary for illumination. Since we need light most of the time, especially in outdoors with insufficient moonlight, it only makes sense to bring a flashlight with you. For most outdoor enthusiasts, an EDC flashlight is usually one of the most important items on their grab-to-go list because of its compact size and ease of carrying. As an ideal outdoor everyday carry flashlight, super bright and long battery life are essential. This time, I would highly recommend the Seeker 3 Pro flashlight.
What Are the Cool Features of Seeker 3 Pro for Outdoor Use?
🔥🔥Super Bright Floodlight
Seeker 3 Pro is equipped with 4 high-performance cool white LEDs light to emit floodlight up to 4200 lumen and has a long range of 250-meter beam distance. Floodlight is a light to illuminate a broad area with its wider and brighter beams of light. It is often used in situations where soft and large-area illumination is needed, such as outdoor sports, camping, hiking, fishing, mountaineering, search and rescue, and so on.
No matter the lighting conditions, Seeker 3 Pro has 5 brightness light modes to meet your lighting requirements. The strobe mode is also a good helper for self-defense.
🔥🔥Fantastic Battery Life
Seeker 3 Pro is a rechargeable flashlight, powered by a large capacity customized 5000mAh rechargeable lithium-ion battery, which extends the max runtime to 15 days. It is charged by an Olight signature MCC3 magnetic charging cable, allowing up to 2A charging current, which makes the charging process quick and simple. The fantastic battery life helps you leave insufficient light source anxiety in long-term activities.
🔥🔥Safety Ensure
When you’re putting that kind of power in your pocket or bag, safety should be a priority. Seeker 3 Pro is equipped the built-in thermal sensor and proximity sensors to protect against overheating or lens obstruction. The proximity sensor performs non-contact detection of the presence of the object. When the head of the flashlight comes close to an object, the proximity sensor automatically dims higher output modes in case of lens obstructions. The thermal sensor is capable of measuring the temperature of the flashlight. When the temperature reaches a certain value, the thermal sensor will automatically dim high output modes in case of overheating.
🔥🔥User-friendly Design
✅Smart lockout and unlocking: it gets locked out automatically after 30 seconds of non-operation, which is helpful to prevent accidentally turning on when you put it in the pocket. If you want to unlock the flashlight, simply rotate the knob switch over 90 degrees.
✅Upgraded user interface: compared to the previous seeker series flashlight, the Seeker 3 Pro brings a brand new switch experience. It adopts the rotary knob switch to adjust brightness levels smoothly. You can long-press the rotary knob to access different brightness levels or rotate it for stepless dimming. Importantly, there are indicators surrounding the rotary knob to reveal the brightness and battery levels in real-time intuitively.
✅Comfortable in hand: the stylish dermatoglyphic silicone wrap with finger grooves around the handle makes it non-slip and comfortable to hold in hand. It also helps with keeping the heat off your hand when you are using higher output mode for a long time.
✅Self-defense: Seeker 3 Pro has a strobe light to blind and disorientate the attacker. Its bezel also comes in with some fibs on the top, giving this EDC light a little more of a tactical style.
Applications of the Seeker 3 Pro EDC Flashlight
🔥🔥Hiking and Mountaineering
There doesn't need too much brightness for hiking and mountaineering. It is said that a flashlight with more than 200 lumens or even over 300 lumens can help you take notice of the surroundings and give you extra protection when walking at night. Due to the long hiking and mountaineering time, you should choose a flashlight having a long battery life. At the same time, it should be easy to carry and can be put in your pocket.
The medium brightness mode of Seeker 3 Pro reaches 300-lumen light output and it lasts about 640 minutes after fully charged. If you need brighter light to explore the terrain, then the high mode of Seeker 3 Pro would be better. With a 1200-lumen light output and 130 meters long-range beam, it is helpful for you to explore the surrounding terrain clearly.
🔥🔥Caving
The environment corresponding to the cave is usually dangerous, and the rock in the hole has low light reflection ability. In view of this situation, an ideal flashlight for caving must be bright enough and have a long battery life for illumination. There sometimes is water in the caving and the environment is pretty damp, which also requires a flashlight with high water resistance.
Seeker 3 Pro, standing out as an ultra-bright and long battery life pocket flashlight, totally meets your caving requirements. It has 5 brightness modes to provide you with the max visibility. The water resistance rating reaches IPX 8, the highest grade in the international certification system of water resistance.
Olight has always been committed to providing the highest level of build quality. Seeker 3 Pro, made in quality aluminum alloy, really builds tough enough to withstand the impact of stones without damage.
🔥🔥Emergency Circumstances
Carrying an EDC flashlight with you makes sense as it would be helpful in emergency cases like a power outage, items lost in the dark space, or car repairs on the dark roadside. Seeker 3 Pro provides not only illumination in emergencies but also serves as a self-defense tool. It is able to deliver strobe light at 13Hz at 4,200 lumen, which is pretty powerful to blind and disorientate attackers, giving you several seconds to take action for life saving. The seeker 3 Pro also comes with a strike bezel which is a bit more aggressive than its previous version. The simple attachment brings this EDC flashlight a tactical style, which is also good for self-defense in emergencies.
