Many of us ride bicycles for a variety of reasons. For some, it is a fun hobby that they do on weekends to get outside and enjoy the fresh air. For others, it is a primary way that they get around, whether for environmentally conscience reasons, or simply because it is the most cost-effective mode of transport. Still, others ride for the health benefits and exercise it provides. No matter the reason, riding a bike is universally enjoyed. Getting to use and enjoy the bicycle can be limited this time of year because of the shorter days and limited daylight hours. Additionally, for those of us that live in hotter climates during the summer, like Southeast Texas, the best way to enjoy a ride is either in the early morning hours or later in the evening when it is a little cooler. Because safety is paramount, being able to see as well as being visible to others around you is not an option.
The newly released Olight Wyvern Bike light is a great solution as it provides an impressive 300 lumens of light, all in a stylish package with simple-to-use button control. And the value is fantastic, which is even better if you take advantage of the February sale where you can get an additional 25% to 35% off depending on whether you bundle both the blue and pink versions together.
The Wyvern bike light is very sleek and stylish. It tapers from the front to the back and has an almost aerodynamic look to it. The name Wyvern bike light comes from a type of winged dragon, and this bike light looks like it might actually be in flight!
Powerfully bright without blinding others
With a maximum output of 300 lumens, the Wyvern bike light provides a great amount of light to illuminate the roads or trails around you. However, due to the anti-glare design, it will not blind oncoming traffic. It has three primary light settings, high, medium and low, as well as two flash settings, slow and quick. The flash settings are a great way to increase your visibility so others can safely see you. The high setting provides an impressive run time of 3.5 hours, which is more than adequate for recreational rides and shorter commutes without fear that you will lose power. However, dropping it down to medium provides 5.5 hours of runtime and at low, you will receive a very impressive 11.5 hours of continuous runtime.
Design specifications
The Wyvern bike light will come in either pink or blue and is housed in polycarbonate and ABS body, providing strength and durability. It has a 1-meter drop test rating and an IPX4 waterproof rating, which means you can bring it with you and have no fear if you get stuck in a heavy downpour.
The controls are simple and straightforward, with a single button located on the top and in the center of the housing. To unlock it, simply long-press the button until it comes on. Once one, you can simply cycle through the 5 different modes with each click of the button. Once your ride is complete, you simply long-press the button again to turn it off. Another really nice feature is the battery indicator just above the button. With green LEDs, it is extremely easy to know just how much power you have left. And when it is needed, charging it easy as well using the included USB type C cable.
Mounting the Wyvern bike light could not be easier and requires no tools. You strap the handlebar mount to the bike, ensuring it is nice and tight, and then you mount the Wyvern bike light by twisting it to lock it in place. When it is time to recharge, simply twist it to remove it from the mount.
The Wyvern bike light is a great bike light, and especially for kids’ bikes. The styling and color options in addition to the included decals, make this a fun addition for them, all while keeping them safe on the roads with you. Family nighttime rides are a tremendous amount of fun, especially when everyone has a Wyvern bike light mounted to their handlebars!
Final Thoughts
If you enjoy bike riding, then adding a headlight is an essential safety device to consider. The Olight Wyvern bike light provides a sleek and stylish option that is also extremely cost-effective. With 300 lumens of brightness available, 80 meters of visibility and up to 13 hours of max runtime, it is a great option. Couple that with the ease of mounting and simple user interface, and you have an almost perfect set-up for those casual evening rides through the neighborhood. Grab one now because they are discounted during the February sale.
Thanks for reading.
