If you like the original Olight Swivel, you’ll love these new upgraded versions! The Olight Swivel Pro and Olight Swivel Pro Max are both versatile, ruggedly built, and handy for a multitude of uses. With their long run times and portability, these sturdy and reliable work lights will be your hardworking companions on and off the job.
Similar Functionality, Unique possibilities
🔥🔥🔥Floodlight vs. Spotlight Capability
The Swivel Pro and Swivel Pro Max both contain a floodlight COB module that projects a smooth, broad beam perfect for close-quarters illumination. The Pro offers up to 1,100 lumens and five brightness levels, while the Pro Max boasts a mighty 1,600 lumens with six floodlight modes for increased versatility. Along with the floodlight, the Swivel Pro also features an additional LED light on the end, giving you a more focused beam with two brightness levels to allow you to see things from a farther distance. Whether using the spotlight or floodlight function, this well-designed work light is going to be your first pick to light up any job you may have.
🔥🔥🔥Quick charging with Long run times
Both the Swivel Pro and the Swivel Pro max are equipped with a USB Type-C charging port for faster and more convenient charging. Fully charged in 3.5 hours for the Pro and 4.5 hours for the Pro Max, you’ll be out the door with plenty of power in no time. Not only do they charge quickly, but with a max runtime of 84 hours on the Pro and 120 hours on the Pro Max, these little work lights will keep your mind on the task at hand even longer. In addition to its many functions, the Pro Max also serves as a high-capacity power bank that can charge your phone or other devices, eliminating any worries of your phone dying in the middle of your task or journey.
🔥🔥🔥Light when and where YOU need it
The Swivel Pro and Swivel Pro Max feature a newly designed anti-pinch folding stand that can be adjusted 180 degrees up and down, and rotated 150 degrees side to side, allowing you light at any angle. Also included are three powerful magnets that will cling to any iron surface, providing you hands-free light in tight spaces. Needing to illuminate a larger space? The Swivel Pro and Swivel Pro max were both built with a 1/4 - 20 thread adapter that will work on any standard tripod, giving your hands the freedom they need to get the job done.
🔥🔥🔥Portable and Easy to Hang
The adjustable clip-style hook on the Swivel Pro and Swivel Pro Max allows you portability to take these handy lights anywhere. They can easily be clipped or hung on backpacks, cords, pipes, and so much more, giving you a multitude of mounting and carrying options. Weighing in at just 11.46 ounces for the Swivel Pro and 20.81 ounces for the Swivel Pro Max, these lightweight work lights will be the ones you rely on for any job, outing, or adventure for years to come.
🔥🔥🔥Built to Last
Both the Swivel Pro and Swivel Pro Max were built tough with a sturdy and well-sealed ABS body that will hold up against anything life has to offer. With an IPX4 water resistance and a drop test rating of 0.8 meters, these powerful lights will resist corrosion, heat, impact, and splashes of water. Whether it be for work or personal use, both the Swivel Pro and Swivel Pro Max will light your way through a wide range of tasks and conditions. With all these durable features, and backed by Olight’s 30 day money-back guarantee and 2 year warranty, you can have total peace of mind that either of these lights will be with you for the long haul.
Usage Scenarios
🔥🔥🔥Work, Construction, and Repair
No matter the job or size of your workspace, attach either of these versatile lights to your tripod and get started on your work. Combined with the clip-style hook and magnetic base, you’ll have multiple mounting options to provide you with all the light you need and both hands available to get it accomplished. The Swivel Pro and Swivel Pro Max are also durable and rugged enough to handle whatever situation you put them in, regardless of weather and conditions. Plus, if your job continues long into the night, the extended run time has you covered with plenty of power.
🔥🔥🔥Outdoor Adventures
Just clip the Swivel Pro or Swivel Pro Max to your backpack to provide illumination along your hike. Since both lights are splash resistant, they can also be hung on your tent, or even on a tree branch to light your campsite long into the night with no worries if unexpected weather occurs. Cell phone battery low and no electrical outlets around? The Swivel Pro Max can easily charge your phone with the included power bank function, keeping you connected and safe. Also, should something unplanned happen, use the red flashing light function as a beacon to draw others to your position.
🔥🔥🔥Auto Emergencies
Keep these versatile lights with you in the car for the unfortunate possibility of an accident or car trouble. With the magnetic base, you’ll have hands-free illumination to change your tire, work under your hood, or whatever the situation requires. You can also use the red flashing function to alert others of your presence, keeping yourself and others safer on the road.
🔥🔥🔥Unexpected Loss of Power
Should severe weather arise and power outages occur, the highly capable Swivel Pro or Swivel Pro Max can provide some assistance. Make use of the power bank function of the Pro Max to charge your phone or other devices, allowing you to stay updated and connected with what is going on around you. With the multiple brightness levels, you’ll be able to light your rooms regardless of your lighting preference to keep going about your tasks until the power is restored.
