It's almost the end of 2022, do you know which are the Olight hot-selling products? We have compiled a list of top 3 hot products with attractive discounts in our Christmas Flash Sale. Just take a little time to check out their features and application scenarios!
Seeker 3 Pro Bright Flashlight
Features
✅High Performance: 4 high-performance LEDs for an amazingly bright 4,200 lumens, 31% higher than the Seeker 2 Pro.
✅Smart Proximity Sensor: Built-in thermal and proximity sensors to ensure maximum safety in case of overheating or lens obstructions.
✅Powerful & Rechargeable: A large-capacity customized 5000mAh rechargeable battery, ensuring a max runtime of 15 days.
✅Smart Lockout & Unlocking: It gets locked out automatically after 30 seconds of non-operation. Rotate the knob switch over 90 degrees to unlock it.
✅Upgraded User Interface: Long-press the rotary knob to access 4 brightness levels or rotate it for stepless dimming.
The Seeker 3 Pro is an ultra-bright floodlight flashlight great for outdoor activities. Its 4 high-performance cool white LEDs boast an incredible max output of 4,200 lumens and a 250-meter beam distance. The newly adopted rotary knob switch on the head allows for smooth adjustment between brightness levels. Surrounding the rotary knob are the indicators to reveal the brightness and battery levels in real time. The built-in proximity and thermal sensors keep the light and nearby objects safe on higher settings. Continuing with its classic style, the Seeker 3 Pro is more powerful, way brighter, and packed with new refinements that make it one of the most well-designed pocket lights out there.
Marauder Mini Powerful Led Flashlight
Features:
✅Smaller in Size, Yet Incredibly Powerful: Marauder Mini, the miniature version of Olight's Marauder, has a 7000-lumen max output and a 43.5-hour max runtime, thanks to its custom 24Wh 32650 rechargeable lithium battery.
✅Uniformly Distributed RGB Color LEDs: Three RGB LEDs are uniformly distributed around the lens, greatly increasing its usefulness on any outdoor adventure. A silicone-coated grip and hidden lanyard hole enhance portability, carrying, and daily use.
✅Dual-beam with Spot and Flood: An array of LEDs offers two powerful beam choices: a 600-meter max throw from the central LED’s spotlight beam, or a 7,000-lumen max output floodlight beam from the 9 surrounding LEDs.
✅Enhanced Safety: Features a built-in thermal sensor and cooling fins to help ensure safety by dissipating heat and sensing lens obstruction.
✅Intuitive Toggle Switch & Rotary Knob Switch: A simple toggle switch selects either spot or flood mode, and an intuitive rotary knob switch allows you to quickly select from seven different brightness levels.
The Marauder mini is a miniature version of Olight's Marauder series of flashlights. It's a powerful rechargeable dual beam LED flashlightwith both flood and throw. Following the Marauder 2's lens design and composed of 9 LEDs surrounding the center, it enables seven brightness levels that provide 200-7000 lumens. A large round LED has been added to the center, offering a 600-meter spotlight beam. Three RGB color LEDs are uniformly distributed around the converging lens, making it suitable for use during any occasion. The toggle switch in the middle of the body allows quick access to select either spotlight or floodlight, while the upper rotary knob is intuitive to adjust brightness levels. Surrounding the rotary knob switch are indicators that reveal the brightness level, battery level, and three RGB light colors. The flashlight features a thermal sensor that automatically downshifts the light to achieve a body temperature below 50 degrees when there is continuous high output use. Powered by a customized 24Wh 32650 rechargeable lithium battery, it offers extended runtime and is compatible with Olight's MCC3 magnetic charging cable. Wrapped by 270-degree silicone, the flashlight’s body surface provides a more comfortable and stable grip. The hidden lanyard hole design quickly manifests for ease of storage, carrying, and daily use. Smaller in size but still powered like a beast, the Marauder mini is a must have for search & rescue, hunters, and all outdoor enthusiasts.
Arkfeld Flat Flashlight with Green Laser and White Light
Features:
✅Dual Light Source EDC Flashlight: White light in 5 brightness levels with a max output of 1,000 lumens, and the output of green beam is ≤0.39mW, Class 1. The light's memory function enables you to save your favorite mode so it's always ready!
✅Flat & Ultra-thin Body: A unique flat shape makes it extremely comfortable to hold in your hand or carry in a pocket. (Only 3.07oz in weight and 0.59in in thickness)
✅Your Needs Are Met: Use the white LED light for any low light needs such as the outdoors or emergency needs. The green beam is perfect for presentations or on-duty use, and loved by pets!
✅Pocket Clip & Magnetic Attachment: The clip clamps tightly onto your shirt or pockets for easy carrying. It also features a magnetic end, allowing you to simply attach it to a nearby metal surface for hands-free light.
The Arkfeld is the first dual light source and portable EDC Flashlight at Olight. 2 color temperatures, 5 brightness levels as well as a memory function that allow you to select what you like with one single click. An amazing max 1,000lumens output is able to light up every corner you can see. The green laser, a good helper when making a presentation or amusing your pets, is featured in the flashlight as well. The creative switch design (Central Button & Selector) is both practical and beautiful. Besides, the magnetic charging cable enables you to have it charged automatically. Last but not least, the flashlight is flat and features a clip, so it is easy to carry (3.07oz in weight and 0.59in in thickness)—It can be clamped onto your pockets and shirts even without noticing its existence. With great design plus multiple lighting functions, Arkfeld can be a second-to-none choice for EDC flashlight.
