TL;DR: Start in ordinary light and identify the stamp issue, banknote design, or paper object. Use a documented long-wave UV flashlight only for a specific observation that the object can tolerate. Follow the light's safety instructions and wear suitable UV protection. Use the result alongside other evidence, and send high-value or fragile pieces to a specialist.
- 1. Start with the object and one question
- 2. Read the U.S. banknote guide for the matching design
- 3. Check a postage stamp by issue and format
- 4. Compare paper and repair clues with ordinary-light photographs
- 5. How can you tell whether a light emits UV?
- 6. Can my phone detect UV light?
- 7. Can you use a UV light to tell if money is real?
- 8. Set up the lamp with its manual and keep exposure brief
- 9. Keep comparisons tied to the same setup
- 10. Send the open question with a useful record
- 11. Frequently asked questions
| Object | First check in ordinary light | When UV can add context |
| U.S. banknote | Identify the denomination and design, then consult its official guide | Check a documented feature and compare it with the note's other features |
| Postage stamp | Identify the issue and record the paper, perforations, design and mounting | Document how it appears with the known light and compare the applicable issue reference |
| Paper collectible | Photograph the whole object and note any visible seam, mark or mounting material | Let a conservator decide whether a fragile or valuable object should be examined |
| Lamp or camera | Confirm the exact lamp specifications and use a regular light to prepare the workspace | Use a camera for visible documentation and suitable instrumentation for measuring UV |
Set the object on a clean, stable work surface in ordinary light, provided its condition allows it to be moved. A banknote in current circulation, a stamp on an old cover, and a signed document with crumbling edges call for different handling. Look at the object before deciding what equipment to use. Keep a brittle item supported and leave stuck, sealed or framed material where it is. A photograph through the mount and a note about the obstruction give a specialist somewhere to start.
Identify the question in a sentence. You might want to know which issue a stamp belongs to, whether an area of a paper print looks different from the surrounding sheet, or whether a note shows the features documented for its design. Each question needs a different reference. Save the official design page, issue information or conservation reference with your note before switching the lamp on.
Give the object an identifier you can match to the photo later. A collection number, the page in an album, or “stamp still attached to the blue envelope” may be enough. Write the identifier on a separate card or in your notes. Keep it away from the original object. That small step avoids having to handle several similar pieces again to figure out which one you photographed.
Make a short record of the printed design, approximate size, any visible watermarks or perforations you can observe safely, and the condition. Capture a full view and a close view of the area you are asking about. For a stamp on an envelope, include the envelope in the overview. It may help a specialist judge the context or spot a part you did not think to record.
Separate the light used to prepare the scene from the light used for the observation. Put your ordinary task light within reach before dimming anything. Olight's guide to different lighting roles explains that principle in a different setting. At a worktable, it means you can return to white light to put the object away or find a control.
Check what country, denomination and design you have in front of you. The U.S. Currency Education Program has separate guidance for different designs, including earlier issues. Its current-design twenty-dollar note page describes a green response from the embedded security thread under UV and gives ordinary-light checks for the watermark and color-shifting numeral. Read the entry for the design you actually have. U.S. Currency Education Program's twenty-dollar note guide
Start with the checks you can perform in ordinary conditions. The texture, the way the printed feature changes as you tilt the note, and the details you can see when it is held to light are separate observations. Use the program's images and instructions for the feature locations and how to check them. A heavily circulated note or an unfamiliar older design can look different from the new-looking note in a quick reference photograph.
If you look for a documented UV response, keep the rest of the assessment tied to the official design. Record which feature you looked at, what you actually saw, and what the other checks showed. A glow elsewhere on the surface is a different observation. Record that separately. If the notes do not agree with the appropriate official reference, stop and use the current reporting or verification guidance.
Suppose you have two twenty-dollar notes with different designs. A useful side-by-side comparison starts by identifying each one on the official site. Follow the instructions for each design independently. Make one short record for each note. This keeps a feature from the newer design from becoming an expectation you incorrectly apply to the older one.
A collector's paper note may also have a sleeve, hinge or fragile edge worth protecting. Leave it in place if removal would risk damage. Record whether an observation was made through the sleeve and bring the visible-light images and issue information to a specialist. A collectible note can have a separate condition or value question even when you are comfortable identifying the design.
Treat a possible counterfeit as a separate decision from collecting. Follow the current U.S. Currency Education Program reporting guidance and any procedures that apply to your work. Do not attempt to pass a note you suspect is counterfeit. The reporting page explains the current channels, including differences for businesses and financial institutions. U.S. Currency Education Program reporting guidance
Some U.S. postage stamps used luminescent tagging to help automate mail handling. A study archived by the Northwest Philatelic Library distinguishes some early phosphor tags from the fluorescence of brightened stamp paper. Long-wave UV can reveal the paper response in those examples. Ask a philatelic expert to identify the specific tagged variety. Study of early U.S. stamp tagging
Begin with the stamp's ordinary appearance. Record the design, wording, perforations and format you can see. Whether the stamp is a detached single, part of a strip, or still on an envelope can matter to the identification question. Leave the stamp and its backing as you found them. Pulling a stamp from a cover or working on its gum can change what you wanted to have examined.
Compare evidence for the same issue and format. A scan from an album or a screen capture from a seller may show the printed design while leaving out paper or tagging details. Note those limitations before you treat the image as a reference. Seek an issue-specific description. If it calls for a form of examination you cannot perform safely with the lamp you have, save the question for a specialist.
Look at where an observed change appears. With the exact long-wave setting recorded, note whether a visible response is general across the paper or confined to an area you can locate under white light. It may be near the edge, around a printed area, or where the stamp touches its mount. Keep the note as an observation about that particular stamp and setup. The feature and its cause may still need to be identified.
An album page provides a simple reason to be careful. A stamp may sit in a transparent mount on a backing that has its own appearance. A pale area that seems to line up with the edge of the stamp could also be at the edge of the mount. Look in ordinary light again to locate those boundaries. Take photos of the page and stamp as they are, then tell an expert exactly what you could see.
If an issue might be rare or valuable, show the unaltered item and your notes to a philatelic expert before paying a premium for an uncertain identification. Ask whether photos are enough for the initial question and what an in-person examination can establish. Include the reference you used and what remains unclear, so the examiner can distinguish your observation from the claim about the stamp.
Paper and parchment can show differences in fluorescence. In its museum guidance, the National Park Service describes optical brighteners in some modern papers and reports that past repairs and added materials sometimes differ from the surrounding sheet. Conditions vary by object. A pale blue area, a darker patch or a visible line is worth documenting in the context of that object. National Park Service guidance on fluorescence in museum objects
Begin with the whole sheet. Identify the edges, seams, folds, and any backing or mount you can see without changing it. A wide white-light photograph helps you compare the position of a patch with those features. If the change is confined to the corner near a hinge, mark that location in a sketch or a copy of the photo. Keep the original object free of added marks.
Use a description that another person could repeat. Try “pale area beside the lower edge under the recorded setting” or “line along the fold on the back.” Color names can vary with the room, lamp and camera. Include where you were looking and a point of reference such as a margin or corner. Keep interpretations in a separate sentence so the description remains useful if your first explanation turns out to be wrong.
A stronger response in one region can suggest a difference in the paper, coating, adhesive, backing or treatment history. It can also leave the cause open. A cover, album mount or fluorescent work surface may change your view. Record the layer you think you can see and how certain you are about its location. A conservator can decide whether another method is needed to identify the material.
If a paper collectible includes faded writing, skip repeated illumination to see whether a camera can pull out more detail. The question may call for careful imaging under controlled conditions. Save the white-light images, bring any existing labels or conservation records, and ask a paper conservator about next steps. Fragile or friable material, attached pages, and documents with previous repairs warrant particular care in handling.
Keep the same distinction when someone sends you a UV image of a collectible. Ask which object is pictured, which light was used, which part you are seeing and whether there is a white-light view. An image of a bright mark can be useful in that context. When the photograph arrives without those details, treat it as incomplete documentation. Ask about the original item's condition before making a purchase or requesting another examination.
Check the documentation for the exact light, setting and stated wavelength. Visible purple spill can show that visible light reached your eyes or camera, and fluorescence shows a material response under particular conditions. Use suitable, calibrated instrumentation or a qualified lab when you need to verify the actual wavelength or output. Keep the light pointed away from people and reflective surfaces.
A household object that glows can help you notice that the scene changed. It gives no calibrated reading of the source. Another object may respond differently even with the same lamp. Build your notes around the documented equipment, the thing you observed and the conditions, so someone else can evaluate whether the comparison addressed the original question.
The National Park Service distinguishes long-wave UV from shorter wavelength bands. Both 365 and 395 nanometers are in the long-wave range it describes. Two lamps in that range can make the same materials look different because the excitation wavelength and visible spill differ. Follow the reference for the object and use the exact setting its method calls for. Olight's UV flashlight primer explains the wavelength terms.
An optical filter can reduce visible light from the source that competes with a weak visible response. A filter built into a device is part of how that model is designed, and supplementary filters need their own technical specifications. Leave the light's optics as the manufacturer supplies them. Use purpose-made protection for the wavelength and follow the directions for the selected light and environment.
Use an ordinary phone camera to document the visible light emitted by a fluorescent object. A phone photograph is a record of how the scene looked with that camera and its settings. Direct UV measurement depends on suitable calibrated equipment. For an object that needs imaging beyond visible light, ask a conservator or qualified examiner what equipment and handling they require.
A phone may adjust exposure, sharpening and white balance between photographs. Try labeling shots by condition, such as “white light” and “visible response under documented long-wave lamp.” Leave the image as captured and keep the white-light reference with it. If you annotate an image, save the annotation as a copy. The comparison is easier to interpret when the unmarked files are still available.
The place where you put the object can matter in a photo. An already clean, plain surrounding surface and a clear view of the margins make the image easier to interpret. If a mount or frame makes the reflection hard to place, write down the limitation. Keep your ordinary-light photograph even when the UV view looks more dramatic. The context can help someone locate the mark you are asking about.
UV can show a documented feature on some U.S. banknote designs. Verify the denomination and design, then use multiple visible and tactile checks from the U.S. Currency Education Program. A glow or lack of glow can lead to another check. Use the program's current reporting guidance when the full set of observations gives you reason to suspect a counterfeit.
Keep the banknote question narrow. If you are looking at the security thread, record what you see at that feature and consult the matching official design page. If you are comparing notes from two different designs, make separate records. When you are still uncertain, avoid making a statement about the bill based on a photograph or the reaction from one lamp.
Read the instructions and warnings for the exact light before opening a collection or taking a photo. Use eye protection designed for the relevant UV wavelength and follow all manufacturer precautions. Check the eyewear rating even if you already wear prescription glasses. Avoid looking into the emitter or pointing it toward another person, animal or reflective surface. Limit exposure of skin and the object. The National Park Service recommends reducing UV exposure to collections and using appropriate protective eyewear during examination. National Park Service examination and safety guidance
Set out the object and note card under ordinary white light. Read the controls and prepare the photo before using the UV setting. Switch back to ordinary light to reposition anything or put the object away. Stop early if you cannot work without stray exposure or if the item is difficult to handle safely. For a valuable paper item, professional advice can save further handling and illumination.
Compare an Olight UV flashlight using the exact model designation, documented wavelength and a way to select the intended output. A compact flashlight with a documented white setting is another option for setting out items and checking the workspace. Keep whichever visible light you choose separate from the observation in your notes.
The official selector graphic distinguishes the model's UV output from its white modes. Use the manual to choose the intended setting.
If a light has multiple outputs, read the markings and instructions in ordinary light. The goal is to know what will turn on before you position the object. Keep the emitter pointed away from your face while checking the controls and put the light down securely between tasks. Take a break if you cannot identify the setting by the control information that came with the exact model.
The official indicator and lockout illustration shows the controls to check before storing the light.
Put the light away following its manual. Use the specified lockout when storing or carrying it as directed. On the ArkPro Ultra, the center button is the lockout control. Check that there are no loose items pressing on the switch and keep the light away from children and pets. Keep your photos and notes with the object record so you can revisit the evidence before deciding whether more inspection is worth doing.
A second look is useful when you know what changed between observations. If the light, the mounting or the camera settings have changed since yesterday, write that down before comparing a pale strip in two images. The strip may look stronger simply because the new picture picked up more light. Keep the original pictures and one note describing the difference you actually observed.
Keep the visible-light overview framed wide enough to show which side of the object you examined. A tightly framed detail may leave out every recognizable marking. A margin, crease or edge can give you a reference point when the next photo is darker. For a paper object that cannot be moved, photograph the visible area from an accessible position and let a specialist decide whether another view is needed.
If you already have a clearly identified item to use as a reference, confirm that it belongs to the same issue and format. A stamp from a booklet can require a different comparison from a stamp with similar artwork from a pane. The first comparison can take place entirely under white light. Record any differences in mount or condition that would make a later comparison harder to interpret.
If a second person is looking at your notes, ask them to point to the feature in the ordinary-light photo first. If they cannot, add a wider view or an arrow on a copy. Ask them to describe the limited finding in their own words. A reader's ability to locate and describe the feature is a more useful check of your record than agreement about a color name.
Leave an unobserved area clearly marked as such. You might have been unable to see the reverse because the object is hinged, or a frame may have covered the lower edge. It is fine for a record to be incomplete. The point is to tell a later examiner what the photographs and notes actually cover, so they can decide what information is still needed.
An inherited album or group of documents may contain unidentified items alongside pieces with old labels. Photograph those labels separately before making new notes. Keep the old attribution with the object record as a historical description. It gives a collector or conservator context while leaving the identification open for a closer examination.
| Your question | Useful items to share | Next step |
| Did I identify this stamp issue correctly? | Front and back views when safe, format, markings and mount notes | Ask a philatelic expert about the specific issue |
| Does this current banknote match its documented design? | Exact design and observations from the official checks | Use the official guidance if suspicion remains |
| What caused a pale band on old paper? | Full white-light view, detail, location and any known handling history | Ask a paper conservator which examination is appropriate |
| Can I reproduce this observation with another lamp? | Exact source, stated wavelength, photo settings if available and what was visible | Keep it as a question until the setup can be matched |
Gather the information you know before contacting someone. Send or show only what is appropriate for their process. A paper conservator may want to know the condition and previous repairs. A stamp expert may need measurements, the format or the original item. An official authority gives the current instructions for a suspected banknote. Keep each request focused on the decision that person can help you make.
In a collection note, keep the seller's description, your own observations, and any expert conclusion separate. Add dates to the notes and photos. If you later learn that the item was the wrong issue or the image used a different wavelength, correct the record. The original photos can still help someone understand why you initially had the question.
For an inexpensive item kept for interest, it may be enough to record what you saw and leave the identification open. The same uncertainty can matter more if an individual piece is fragile, expensive, contested or part of an insurance record. In those cases, save the piece from further tinkering and get the right kind of help before making a decision about condition, value or authenticity.
