When it comes to selecting an EDC flashlight, the decision can be perplexing due to the wide variety of options available. Olight, a renowned manufacturer of top-notch flashlights, offers two popular choices for EDC enthusiasts: the Baton 3 Pro Max and the Warrior 3S. In this article, we will delve into a comprehensive review of both EDC flashlights, enabling you to decide which one best suits your requirements.
Section 1: Design and Build Quality
Both the Baton 3 Pro Max and the Warrior 3S are meticulously crafted for everyday carry, prioritizing durability and functionality. The Baton 3 Pro Max has a sleek and compact design, measuring a mere 4.49 inches in length and weighing just 4.73 ounces. It boasts a construction of Magnesium Alloy(desert Tan). Conversely, the Warrior 3S is slightly larger and heavier, measuring 5.47 inches in length and weighing 6.21 ounces. Its construction is made of aircraft-grade aluminum complemented by a hard-anodized finish. Both models possess an IPX8 waterproof rating.
Section 2: Brightness and Beam Distance
Brightness and beam distance constitute key factors when selecting an EDC flashlight. The Baton 3 Pro Max impressively offers a maximum output of 2500 lumens and a beam distance of 145 meters. Its optimized optical system incorporates a concealed proximity sensor that affords protection without undue sensitivity or interference with the light's beam pattern. Furthermore, the sensor can be temporarily or permanently disabled. Conversely, the Warrior 3S yields a maximum output of 2300 lumens and a beam distance of 300 meters. It features a proximity sensor (deactivated by double-pressing the side switch within 5 seconds of auto-dimming) that reduces brightness levels to safeguard against nearby objects when operating in high, turbo, or strobe modes.
Section 3: Battery Life and Charging
Both the Baton 3 Pro Max and the Warrior 3S are rechargeable, delivering ample battery life. The Baton 3 Pro Max is equipped with a 5000mAh rechargeable lithium polymer battery that provides up to 60 days of runtime on its lowest setting, requiring only 3.5 hours for a full recharge via the included magnetic charging cable. Conversely, the Warrior 3S houses a 5000mAh rechargeable lithium-ion battery that affords up to 55 days of runtime on its lowest setting. Recharging it to capacity also just takes 3.5 hours using the supplied magnetic charging cable.
Section 4: Additional Features and Functionality
The Baton 3 Pro Max and the Warrior 3S distinguish themselves from other EDC flashlights through a lot of supplementary features and functionality. The Baton 3 Pro Max entails a magnetic tail cap for easy attachment to metallic surfaces, accompanied by a side switch for effortless one-handed operation. Additionally, it incorporates an intuitive Battery Indicator. Simply shake the Baton 3 Pro Max to activate its battery indicator light—displaying green for 60% to 100% charge, orange for 10% to 60%, red for 5% to 10%, and flashing red for less than 5%. Conversely, the Warrior 3S encompasses a magnetic tactical tail switch for convenient access to turbo or strobe modes. Furthermore, it boasts a Visualized battery indicator that indicates when recharge is necessary.
which one to choose?
Notwithstanding, it is worth noting that both flashlights share key features such as tail magnetic, rechargeable batteries, and magnetic charging cables, endowing them with convenience and practicality for everyday carry.
If you seek an EDC flashlight that combines power with portability, the Baton 3 Pro Max may be the ideal option for you. Its medium size ensures easy pocketability or inclusion in everyday carry bags, and its magnetic tail cap permits hands-free utilization when required. Moreover, its gentle and well-balanced beam proves perfect for tasks necessitating a stable light source, such as automotive repairs or working in dimly lit spaces.
On the other hand, if you yearn for a powerful flashlight boasting an extensive beam range, the Warrior 3S might represent a superior choice. Its smooth reflector generates a concentrated beam capable of spanning up to 300 meters, making it an excellent companion for outdoor activities like camping, hiking, or hunting. The tactical tail switch additionally allows swift access to turbo or strobe modes—proving invaluable in emergency scenarios.
Regardless of your chosen flashlight, rest assured that both the Baton 3 Pro Max and the Warrior 3S epitomize premium products engineered for durability. Their versatile attributes make them indispensable for a range of tasks, while their rechargeable batteries guarantee a dependable light source whenever required.
In conclusion, the selection between the Baton 3 Pro Max and the Warrior 3S hinges ultimately upon your specific needs and preferences. Consider the intended purpose of the flashlight, as well as the manner in which you plan to carry it, before opting for the model that best harmonizes with your lifestyle. Regardless of your decision, be confident that Olight delivers a first-rate and reliable EDC flashlight.
